I'm using the Custom service example as by base. Now this was really itching me to not know the reason which causes it. I'm giving an "if-else" condition inside a "switch-case" condition as shown below inside the custom ble service handler as follows. In the BLE_CUS_EVT_NOTIFICATION_ENABLED case to be specific and inside it the if condition checking for the received_data variable :
static void on_cus_evt(ble_cus_t * p_cus_service,
ble_cus_evt_t * p_evt)
ret_code_t err_code;
BaseType_t xHigherPriorityTaskWoken = pdFALSE;
switch(p_evt->evt_type)
case BLE_CUS_EVT_NOTIFICATION_ENABLED:
if (pdPASS != xTimerStartFromISR(m_cus_notification_timer, &xHigherPriorityTaskWoken))
APP_ERROR_HANDLER(NRF_ERROR_NO_MEM);
if(received_data==1){
// Enter here, set a breakpoint here
xTaskResumeFromISR(m_mpu_thread_0);
case BLE_CUS_EVT_NOTIFICATION_DISABLED:
if (pdPASS != xTimerStopFromISR(m_cus_notification_timer, &xHigherPriorityTaskWoken))
case BLE_CUS_EVT_CONNECTED:
case BLE_CUS_EVT_DISCONNECTED:
// No implementation needed.
received_data is the variable which stores the data written to the service. It is a global variable so I think scope isn't the issue here. When I see my "received_data" in the debug terminal it shows that the value is 1 but it never enters the "if(received_data==1)" condition.
But if the same thing is done in ble event handler callback function then it's working fine . In the BLE_GATTS_EVT_WRITE event to specific and if condition works here fine :
uint32_t err_code;
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Disconnected");
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTS_EVT_WRITE:
received_data = p_ble_evt->evt.gatts_evt.params.write.data[0];
else if(received_data==2){
xTaskResumeFromISR(m_thread_1);
what's the reason that if works in on ble event handler and not in the custom service event handler. Aren't if-else cases applicable anywhere in the code?
