nrf52840 Bluetooth and 802.15.4 multiprotocol example project
 For a number of upcoming projects we require 802.15.4 and BLE dynamic multiprotocol support. We need to select a SoC to implement this.
 We like the look of the nrf52840 and see multiprotocol  should be possible using the nRF-IEEE-802.15.4-radio-driver.
 A number of people have already asked about this but is there an example showing this working yet? Or if someone has got it working would firstly say they've done it and then, maybe, let us have the code ( or even binary ) please?
 We have just had Silicon Labs pull 802.15.4 support from their modules that we were just about to design in so time is critical for us. We don't have the time to learn an API and get to grips with new hardware/software and the inevitable debugging to get to the point deciding to use the nrf52840. If we can prove multiprotocol works we will almost certainly use the nrf52840.
kind regards
Liam
  • Yes. The 802.15.4 IEEE driver is independent of the MAC layer, so you have to write this.
    You can see if you can reuse anything from the Thread SDK:
    nRF5_SDK_for_Thread_and_Zigbee_2.0.0_29775ac\external\nRF-IEEE-802.15.4-radio-driver\src\mac_features.
    BR,
    Edvin
  • Hi Edwin,
     I'm having a problem getting this to work.
    Firstly I got the single phy IEEE15.4 Radio Driver examples working.
    I then modified the ble_zigbee_dynamic_light_switch_nus by stripping out any zigbee code.
    I added the Radio Driver source files in. I've setup as described in the Radio Driver Wiki (i.e. RAAL_SOFTDEVICE defined, nrf_raal_softdevice.c added etc ). I used nrf_802154_clock_sdk.c, nrf_802154_lp_timer_nodrv.c. The nrf_802154_config,h files I left as is.
    I call nrf_802154_init after setting up Bluetooth.
        err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
    	/* Initialize loging system and GPIOs. */
        log_init();
        timer_init();
        leds_buttons_init();
        /* Bluetooth initialization. */
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        printf("Initialise 802.15.4 ...");
        nrf_802154_init();
        nrf_802154_channel_set(11);
        nrf_802154_receive();
        printf("Done\n");
    	while (1)
    	    if (!m_tx_in_progress)
    			printf("Send ");
    			m_tx_in_progress = nrf_802154_transmit(message, sizeof(message), true);
    				printf("Fail\n");
    My understanding is the nrf_802154_init sets up the arbiter.
    Running shows the bluetooth is working but it only sends a few 802.15.4 packets and then stops. nrf_raal_softdevice_soc_evt_handler is no longer being called.
    Can you help please? I can post the project if required.
    kind regards
    Liam
  • Hello Liam,
    If you could send the project, that would be great. If I can't figure it out, I could send it to someone who has worked with the 802.15.4 radio driver, which will probably know what is going on.
    Edvin
  • Thanks Edvin,
     I think thats best. Zip of project attached. Output should be placed within SDK as below
    nRF5_SDK_for_Thread_and_Zigbee_2.0.0_29775ac\examples\multiprotocol\ble_802154_dynamic_nus
    kind regards
    Liam
    ble_802154_dynamic_nus.zip
  • Is the nrf_raal_softdevice_soc_evt_handler ever called?
    I seem to recall that I had to register the SOC_OBSERVER separately. IIRC that was not done by the nrf802154_init()
