Serial + BLE + I2C + Timer + GPIO -> serial not works
We are developing an application on the nRF52840 kit with SDK 15.2. We are using Keil as compiler. I have started developmet my application with the example ble_app_cscs. In this example I added the libraries for use the serial, I2C, timer and GPIO.
After that, when I start the application and I connecting the nRF52840 device with app and I receiveng data from UART, after a random time the serial stops to work, while the I2C, GPIO and timer works correctly.
The firmare is running and it communicate with the App but the function that receive from the Uart return always no data. The data continue to come from Uart, I can see them with oscylloscope, but the receive function say always no data. This happen after a random time, it can be immediatly or after some minutes.
When te uart stops to receive data, the error that it return is the numer 13 : timeout.
If I use the BLE or the UART separatly they work fine. I attached all project.
Do you have any idea about this problem?
ble_app_cscs.zip
  • I see you are using IRQ mode with the timeout parameter set. Did you notice the warning in the library documentation?
    Warning
    Do not use synchronous API (timeout_ms parameter > 0) in IRQ context. It may lead to a deadlock because the timeout interrupt cannot preempt the current IRQ context.
    I have tried setting timeout_ms = 0 in all function that concern the serial. But the UART is alway stops working. I have attacched the file main.c .
     * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    /** @file
     * @defgroup ble_sdk_app_csc_main main.c
     * @ingroup ble_sdk_app_csc
     * @brief Cycling Speed and Cadence Service Sample Application main file.
     * This file contains the source code for a sample application using the Cycling Speed and Cadence
     * Service.
     * It also includes the sample code for Battery and Device Information services.
     * This application uses the @ref srvlib_conn_params module.
     * This application implements supports for both Wheel revolution Data and Crank Revolution Data.
     * In addition, this application also has support for all 'Speed and Cadence Control Point'.
    #include <stdint.h>
    #include <string.h>
    #include <stdbool.h> // add
    #include <stddef.h>	// add
    #include "nrf_drv_clock.h"	// add
    #include "nrf_gpio.h"	// add
    #include "nrf_delay.h"	// add
    #include "nrf_drv_power.h"	// add
    #include "nrf_serial.h"	// add
    #include "app_error.h"	// add
    #include "app_util.h"	// add
    #include "boards.h"	// add
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble.h"
    #include "ble_err.h"
    #include "ble_hci.h"
    #include "ble_srv_common.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_bas.h"
    #include "ble_cscs.h"
    #include "ble_dis.h"
    #include "ble_conn_params.h"
    #include "sensorsim.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "app_timer.h"
    #include "peer_manager.h"
    #include "peer_manager_handler.h"
    #include "bsp_btn_ble.h"
    #include "fds.h"
    #include "ble_conn_state.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "BNO055.h"
    #include "nrf_drv_twi.h"
    #include "nrf_drv_timer.h"
    #include "shared_data.h"
    #define DEVICE_NAME                     "U-Tech NRF-BLE"                            /**< Name of device. Will be included in the advertising data. */
    #define MANUFACTURER_NAME               "NordicSemiconductor"                       /**< Manufacturer. Will be passed to Device Information Service. */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define APP_ADV_INTERVAL                40                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 25 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define BATTERY_LEVEL_MEAS_INTERVAL     APP_TIMER_TICKS(10) //APP_TIMER_TICKS(2000)/**< Battery level measurement interval (ticks). */
    #define MIN_BATTERY_LEVEL               81                                          /**< Minimum battery level as returned by the simulated measurement function. */
    #define MAX_BATTERY_LEVEL               100                                         /**< Maximum battery level as returned by the simulated measurement function. */
    #define BATTERY_LEVEL_INCREMENT         1                                           /**< Value by which the battery level is incremented/decremented for each call to the simulated measurement function. */
    #define SPEED_AND_CADENCE_MEAS_INTERVAL 80	                               						/**< Speed and cadence measurement interval (milliseconds). */
    #define WHEEL_CIRCUMFERENCE_MM          2100                                        /**< Simulated wheel circumference in millimeters. */
    #define KPH_TO_MM_PER_SEC               278                                         /**< Constant to convert kilometers per hour into millimeters per second. */
    #define MIN_SPEED_KPH                   10                                          /**< Minimum speed in kilometers per hour for use in the simulated measurement function. */
    #define MAX_SPEED_KPH                   40                                          /**< Maximum speed in kilometers per hour for use in the simulated measurement function. */
    #define SPEED_KPH_INCREMENT             1                                           /**< Value by which speed is incremented/decremented for each call to the simulated measurement function. */
    #define DEGREES_PER_REVOLUTION          360                                         /**< Constant used in simulation for calculating crank speed. */
    #define RPM_TO_DEGREES_PER_SEC          6                                           /**< Constant to convert revolutions per minute into degrees per second. */
    #define MIN_CRANK_RPM                   20                                          /**< Minimum cadence in RPM for use in the simulated measurement function. */
    #define MAX_CRANK_RPM                   110                                         /**< Maximum cadence in RPM for use in the simulated measurement function. */
    #define CRANK_RPM_INCREMENT             3                                           /**< Value by which cadence is incremented/decremented in the simulated measurement function. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS ( 10 , UNIT_1_25_MS )         /**< Minimum acceptable connection interval (10 milliseconds). */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS ( 100 , UNIT_1_25_MS )        /**< Maximum acceptable connection interval (100 milliseconds). */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS ( 30000 , UNIT_10_MS )        /**< Connection supervisory timeout (30 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS ( 100 ) // APP_TIMER_TICKS(5000)                    /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS ( 100 ) // APP_TIMER_TICKS(30000)                  	/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define SEC_PARAM_BOND                  1                                           /**< Perform bonding. */
    #define SEC_PARAM_MITM                  0                                           /**< Man In The Middle protection not required. */
    #define SEC_PARAM_LESC                  0                                           /**< LE Secure Connections not enabled. */
    #define SEC_PARAM_KEYPRESS              0                                           /**< Keypress notifications not enabled. */
    #define SEC_PARAM_IO_CAPABILITIES       BLE_GAP_IO_CAPS_NONE                        /**< No I/O capabilities. */
    #define SEC_PARAM_OOB                   0                                           /**< Out Of Band data not available. */
    #define SEC_PARAM_MIN_KEY_SIZE          7                                           /**< Minimum encryption key size. */
    #define SEC_PARAM_MAX_KEY_SIZE          16                                          /**< Maximum encryption key size. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    /******************* SERIAL DECLARATION. ******************
    static void 	sleep_handler ( void )
        __WFE ( ) ;
        __SEV ( ) ;
        __WFE ( ) ;
    NRF_SERIAL_DRV_UART_CONFIG_DEF ( m_uart0_drv_config ,
                          RX_PIN_UART_BADGE , TX_PIN_UART_BADGE ,
                          RTS_PIN_NUMBER , CTS_PIN_NUMBER ,
                          NRF_UART_HWFC_DISABLED , NRF_UART_PARITY_EXCLUDED ,
                          NRF_UART_BAUDRATE_115200 ,
                          UART_DEFAULT_CONFIG_IRQ_PRIORITY ) ;
    #define SERIAL_FIFO_TX_SIZE 	1024
    #define SERIAL_FIFO_RX_SIZE 	1024
    NRF_SERIAL_QUEUES_DEF ( serial_queues , SERIAL_FIFO_TX_SIZE , SERIAL_FIFO_RX_SIZE ) ;
    #define SERIAL_BUFF_TX_SIZE 	1
    #define SERIAL_BUFF_RX_SIZE 	1
    NRF_SERIAL_BUFFERS_DEF ( serial_buffs , SERIAL_BUFF_TX_SIZE , SERIAL_BUFF_RX_SIZE ) ;
    NRF_SERIAL_CONFIG_DEF (serial_config , NRF_SERIAL_MODE_IRQ ,	// NRF_SERIAL_MODE_DMA
                          &serial_queues , &serial_buffs , NULL , sleep_handler ) ;
    NRF_SERIAL_UART_DEF ( serial_uart , 1 ) ;
    // ID LED
    #define ID_LED_1	0
    #define ID_LED_2	1
    #define ID_LED_3	2
    #define ID_LED_4	3
    // Macro
    #define OK	1
    #define KO	0
    #define BUFF_EQUAL		0
    #define MAX_TRY_AGAIN_AUTOLISTCARD_COMMAND	3
    // 5 millisecondi
    #define TIME_MS_5		5
    // Timeout
    #define TIMEOUT_READING_BADGE			2000	// 2 sec
    // MaxSonar
    #define TIMEOUT_PULSE_MAXSONAR		10000	// us -> 5ms
    #define RANGE_MINIMUM		300	// 30 mm
    // State pulse
    #define HIGH_PULSE_MAXSONAR				1
    #define LOW_PULSE_MAXSONAR				0
    #define ACTIVE_READING_TIME_PULSE_MAXSONAR		1
    // Timer
    #define TIMER_CONFIG_BIT_WIDTH_32bit	3
    #define TIMER_CONFIG_FREQUENCY				4
    #define TIMER_CONFIG_MODE							0
    // TWI instance ID.
    #if TWI0_ENABLED
    #define TWI_INSTANCE_ID     0
    #elif TWI1_ENABLED
    #define TWI_INSTANCE_ID     1
    BLE_BAS_DEF ( m_bas ) ;                                                             /**< Battery service instance. */
    BLE_CSCS_DEF ( m_cscs ) ;                                                           /**< Cycling speed and cadence service instance. */
    NRF_BLE_GATT_DEF ( m_gatt ) ;                                                       /**< GATT module instance. */
    NRF_BLE_QWR_DEF ( m_qwr ) ;                                                         /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF ( m_advertising ) ;                                             /**< Advertising module instance. */
    APP_TIMER_DEF ( m_battery_timer_id ) ;                                              /**< Battery timer. */
    APP_TIMER_DEF ( m_csc_meas_timer_id ) ;                                             /**< CSC measurement timer. */
    static uint16_t          m_conn_handle = BLE_CONN_HANDLE_INVALID ;                  /**< Handle of the current connection. */
    static sensorsim_cfg_t   m_battery_sim_cfg ;                                        /**< Battery Level sensor simulator configuration. */
    static sensorsim_state_t m_battery_sim_state ;                                      /**< Battery Level sensor simulator state. */
    static sensorsim_cfg_t   m_speed_kph_sim_cfg ;                                      /**< Speed simulator configuration. */
    static sensorsim_state_t m_speed_kph_sim_state ;                                    /**< Speed simulator state. */
    static sensorsim_cfg_t   m_crank_rpm_sim_cfg ;                                      /**< Crank simulator configuration. */
    static sensorsim_state_t m_crank_rpm_sim_state ;                                    /**< Crank simulator state. */
    static uint32_t m_cumulative_wheel_revs ;                                           /**< Cumulative wheel revolutions. */
    static bool     m_auto_calibration_in_progress ;                                    /**< Set when an autocalibration is in progress. */
    // Variable
    char  				ACK [ ] = { 0x50 , 0x00 , 0x00 , 0x23 , 0x73 } ;
    char					buff_received_uart_badge [ 30 ] = "" ;
    char					UID_badge [ MAX_BUFF_BADGE ] = "" ;
    char					char_UID_badge [ 10 ] = "" ;
    uint8_t				buffer [ 512 ] = "" ;
    int						index = 0 ;
    uint8_t				error_system = false ;
    bool					new_badge = false ;
    uint16_t	  	pulse_width_MaxSonar = 0 ;
    char					reading_pulse_active = OFF ;
    uint32_t	  	tmp_pulse_width_MaxSonar = 0 ;
    uint32_t	  	counter_reading_badge = 0 ;
    bool					badge_update = false ;
    // TWI instance
    const 	nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE ( TWI_INSTANCE_ID ) ;
    /**< Supported location for the sensor location. */
    static ble_sensor_location_t supported_locations [ ] =
        BLE_SENSOR_LOCATION_FRONT_WHEEL,
        BLE_SENSOR_LOCATION_LEFT_CRANK,
        BLE_SENSOR_LOCATION_RIGHT_CRANK,
        BLE_SENSOR_LOCATION_LEFT_PEDAL,
        BLE_SENSOR_LOCATION_RIGHT_PEDAL,
        BLE_SENSOR_LOCATION_FRONT_HUB,
        BLE_SENSOR_LOCATION_REAR_DROPOUT,
        BLE_SENSOR_LOCATION_CHAINSTAY,
        BLE_SENSOR_LOCATION_REAR_WHEEL,
        BLE_SENSOR_LOCATION_REAR_HUB
    static ble_uuid_t m_adv_uuids [ ] =                                                   /**< Universally unique service identifiers. */
        {BLE_UUID_CYCLING_SPEED_AND_CADENCE,  BLE_UUID_TYPE_BLE},
        {BLE_UUID_BATTERY_SERVICE,            BLE_UUID_TYPE_BLE},
        {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
    // EXTERN
    extern bno055_data 	data_BNO055 ;
    extern bool					update_data_BNO055 ;
    extern char					tmp_UID_badge [ MAX_BUFF_BADGE ] ;
    extern uint8_t			package_send ;
    // FUNCTION
    static void 	advertising_start ( bool erase_bonds ) ;
    char					init_autolistcard ( void ) ;
    bool 					twi_init ( void ) ;
    uint16_t			read_pulse_MaxSonar ( void ) ;
    /**@brief Callback function for asserts in the SoftDevice.
     * @param[in] line_num   Line number of the failing ASSERT call.
     * @param[in] file_name  File name of the failing ASSERT call.
    /**@brief Function for handling Peer Manager events.
     * @param[in] p_evt  Peer Manager event.
    static void pm_evt_handler(pm_evt_t const * p_evt)
        pm_handler_on_pm_evt(p_evt);
        pm_handler_flash_clean(p_evt);
        switch (p_evt->evt_id)
                advertising_start(false);
    /**@brief Function for performing battery measurement and updating the Battery Level characteristic
     *        in Battery Service.
    static void battery_level_update(void)
        ret_code_t err_code;
        uint8_t  battery_level;
        // battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
        err_code = ble_bas_battery_level_update(&m_bas, battery_level, BLE_CONN_HANDLE_ALL);
        if ((err_code != NRF_SUCCESS) &&
            (err_code != NRF_ERROR_INVALID_STATE) &&
            (err_code != NRF_ERROR_BUSY) &&
            (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
            APP_ERROR_HANDLER(err_code);
    /**@brief Function for handling the Battery measurement timer timeout.
     * @details This function will be called each time the battery level measurement timer expires.
     * @param[in] p_context  Pointer used for passing some arbitrary information (context) from the
     *                       app_start_timer() call to the timeout handler.
    static void battery_level_meas_timeout_handler(void * p_context)
        UNUSED_PARAMETER(p_context);
        //battery_level_update();
    /**@brief Function for populating simulated cycling speed and cadence measurements.
    static void csc_sim_measurement(ble_cscs_meas_t * p_measurement)
        static uint16_t cumulative_crank_revs = 0;
        static uint16_t event_time            = 0;
        static uint16_t wheel_revolution_mm   = 0;
        static uint16_t crank_rev_degrees     = 0;
        uint16_t mm_per_sec;
        uint16_t degrees_per_sec;
        uint16_t event_time_inc;
        // Per specification event time is in 1/1024th's of a second.
        event_time_inc = (1024 * SPEED_AND_CADENCE_MEAS_INTERVAL) / 1000;
        // Calculate simulated wheel revolution values.
        p_measurement->is_wheel_rev_data_present = true;
        mm_per_sec = KPH_TO_MM_PER_SEC * sensorsim_measure(&m_speed_kph_sim_state,
                                                           &m_speed_kph_sim_cfg);
        wheel_revolution_mm     += mm_per_sec * SPEED_AND_CADENCE_MEAS_INTERVAL / 1000;
        m_cumulative_wheel_revs += wheel_revolution_mm / WHEEL_CIRCUMFERENCE_MM;
        wheel_revolution_mm     %= WHEEL_CIRCUMFERENCE_MM;
        p_measurement->cumulative_wheel_revs = m_cumulative_wheel_revs;
        p_measurement->last_wheel_event_time =
            event_time + (event_time_inc * (mm_per_sec - wheel_revolution_mm) / mm_per_sec);
        // Calculate simulated cadence values.
        p_measurement->is_crank_rev_data_present = true;
        degrees_per_sec = RPM_TO_DEGREES_PER_SEC * sensorsim_measure(&m_crank_rpm_sim_state,
        &m_crank_rpm_sim_cfg);
        crank_rev_degrees     += degrees_per_sec * SPEED_AND_CADENCE_MEAS_INTERVAL / 1000;
        cumulative_crank_revs += crank_rev_degrees / DEGREES_PER_REVOLUTION;
        crank_rev_degrees     %= DEGREES_PER_REVOLUTION;
        p_measurement->cumulative_crank_revs = cumulative_crank_revs;
        p_measurement->last_crank_event_time =
            event_time + (event_time_inc * (degrees_per_sec - crank_rev_degrees) / degrees_per_sec);
        event_time += event_time_inc;
    /**@brief Function for handling the Cycling Speed and Cadence measurement timer timeouts.
     * @details This function will be called each time the cycling speed and cadence
     *          measurement timer expires.
    static void csc_meas_timeout_handler ( void * p_context )
        uint32_t        err_code;
        ble_cscs_meas_t cscs_measurement ;
        UNUSED_PARAMETER ( p_context ) ;
    		/* VERIFICO SE DEVO INVIARE UN PACCHETTO ALL'APP */
    		// Se il codice del badge non � valorizzato invio il pacchetto successivo
    		if ( badge_update == true )
    			if ( strncmp ( UID_badge , tmp_UID_badge , 16 ) != STR_EQUAL )
    				package_send = PACKAGE_1_SEND_BLE ;
    				package_send = PACKAGE_1_SEND_RESET_BLE ;
    		else if ( update_data_BNO055 == true )
    			package_send = PACKAGE_2_SEND_BLE ;
    				package_send = DATA_NOT_AVAILABLE ;
    		/* SE CI SONO DATI DISPONIBILI LI INVIO ALL'APP */
    		if ( package_send != DATA_NOT_AVAILABLE )
    			err_code = ble_cscs_measurement_send ( &m_cscs , &cscs_measurement ) ;
    			if ( err_code == NRF_SUCCESS )
    				// Dati inviati correttamente aggiorno le variabili che
    				// gestiscono l'invio dei dati ( attesa nuovo badge e
    				// nuovi dati disponibili dal sensore BNO055 )
    				if ( package_send == PACKAGE_1_SEND_BLE )
    					// Dati inviati correttamente, resetto la variabile
    					strncpy ( tmp_UID_badge , UID_badge , 16 ) ;
    					// Se invio il badge il led blinka una volta
    					bsp_board_led_invert ( ID_LED_3 ) ;
    					nrf_delay_ms ( 10 ) ;
    				else if ( package_send == PACKAGE_1_SEND_RESET_BLE )
    					// Nota : non aggiorno l'array tmp_UID_badge perch� il codice badge passato � sempre lo stesso
    					// Badge eliminato resetto i buffer per poter inserire nuovamente quello cancellato
    					memset ( tmp_UID_badge , 0 , sizeof ( tmp_UID_badge ) ) ;
    					memset ( UID_badge , 0 , sizeof ( UID_badge ) ) ;
    					// Se passo lo stesso badge il led blinka due volta
    					nrf_delay_ms ( 200 ) ;
    				else if ( package_send == PACKAGE_2_SEND_BLE )
    					update_data_BNO055 = false ;
    /**@brief Function for the Timer initialization.
     * @details Initializes the timer module. This creates and starts application timers.
    static void timers_init(void)
        // Initialize timer module.
        err_code = app_timer_init();
        // Create timers.
    //    err_code = app_timer_create(&m_battery_timer_id,
    //                                APP_TIMER_MODE_SINGLE_SHOT,
    //                                battery_level_meas_timeout_handler);
    //    APP_ERROR_CHECK(err_code);
        // Create battery timer.
        err_code = app_timer_create(&m_csc_meas_timer_id,
                                    APP_TIMER_MODE_REPEATED,
                                    csc_meas_timeout_handler);
     * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
     *          device including the device name, appearance, and the preferred connection parameters.
                                              (const uint8_t *)DEVICE_NAME,
                                              strlen(DEVICE_NAME));
        err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_CYCLING_SPEED_CADENCE_SENSOR);
    /**@brief Function for initializing the GATT module.
    static void gatt_init(void)
        ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling Speed and Cadence Control point events
     * @details Function for handling Speed and Cadence Control point events.
     *          This function parses the event and in case the "set cumulative value" event is received,
     *          sets the wheel cumulative value to the received value.
    ble_scpt_response_t sc_ctrlpt_event_handler(ble_sc_ctrlpt_t     * p_sc_ctrlpt,
                                                ble_sc_ctrlpt_evt_t * p_evt)
        switch (p_evt->evt_type)
            case BLE_SC_CTRLPT_EVT_SET_CUMUL_VALUE:
                m_cumulative_wheel_revs = p_evt->params.cumulative_value;
            case BLE_SC_CTRLPT_EVT_START_CALIBRATION:
                m_auto_calibration_in_progress = true;
                // No implementation needed.
        return (BLE_SCPT_SUCCESS);
     * @details Initialize the Cycling Speed and Cadence, Battery and Device Information services.
        uint32_t              err_code;
        ble_cscs_init_t       cscs_init;
        ble_bas_init_t        bas_init;
        ble_dis_init_t        dis_init;
        ble_sensor_location_t sensor_location;
        nrf_ble_qwr_init_t    qwr_init = {0};
        // Initialize Cycling Speed and Cadence Service.
        memset(&cscs_init, 0, sizeof(cscs_init));
        cscs_init.evt_handler = NULL;
        cscs_init.feature     = BLE_CSCS_FEATURE_WHEEL_REV_BIT | BLE_CSCS_FEATURE_CRANK_REV_BIT |
                                BLE_CSCS_FEATURE_MULTIPLE_SENSORS_BIT;
        // Here the sec level for the Cycling Speed and Cadence Service can be changed/increased.
        cscs_init.csc_meas_cccd_wr_sec  = SEC_OPEN;
        cscs_init.csc_feature_rd_sec    = SEC_OPEN;
        cscs_init.csc_location_rd_sec   = SEC_OPEN;
        cscs_init.sc_ctrlpt_cccd_wr_sec = SEC_OPEN;
        cscs_init.sc_ctrlpt_wr_sec      = SEC_OPEN;
        cscs_init.ctrplt_supported_functions = BLE_SRV_SC_CTRLPT_CUM_VAL_OP_SUPPORTED
                                               | BLE_SRV_SC_CTRLPT_SENSOR_LOCATIONS_OP_SUPPORTED
                                               | BLE_SRV_SC_CTRLPT_START_CALIB_OP_SUPPORTED;
        cscs_init.ctrlpt_evt_handler            = sc_ctrlpt_event_handler;
        cscs_init.list_supported_locations      = supported_locations;
        cscs_init.size_list_supported_locations = sizeof(supported_locations) /
                                                  sizeof(ble_sensor_location_t);
    		// initializes the sensor location to add the sensor location characteristic.
        sensor_location           = BLE_SENSOR_LOCATION_FRONT_WHEEL;
        cscs_init.sensor_location = &sensor_location;
        err_code = ble_cscs_init(&m_cscs, &cscs_init);
        // Initialize Battery Service.
        memset(&bas_init, 0, sizeof(bas_init));
        // Here the sec level for the Battery Service can be changed/increased.
        bas_init.bl_rd_sec        = SEC_OPEN;
        bas_init.bl_cccd_wr_sec   = SEC_OPEN;
        bas_init.bl_report_rd_sec = SEC_OPEN;
        bas_init.evt_handler          = NULL;
        bas_init.support_notification = true;
        bas_init.p_report_ref         = NULL;
        bas_init.initial_batt_level   = 100;
        err_code = ble_bas_init(&m_bas, &bas_init);
        // Initialize Device Information Service.
        memset(&dis_init, 0, sizeof(dis_init));
        ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, MANUFACTURER_NAME);
        dis_init.dis_char_rd_sec = SEC_OPEN;
        err_code = ble_dis_init(&dis_init);
    /**@brief Function for initializing the sensor simulators.
    static void sensor_simulator_init(void)
        m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
        m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
        m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
        m_battery_sim_cfg.start_at_max = true;
        sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
        m_speed_kph_sim_cfg.min          = MIN_SPEED_KPH;
        m_speed_kph_sim_cfg.max          = MAX_SPEED_KPH;
        m_speed_kph_sim_cfg.incr         = SPEED_KPH_INCREMENT;
        m_speed_kph_sim_cfg.start_at_max = false;
        sensorsim_init(&m_speed_kph_sim_state, &m_speed_kph_sim_cfg);
        m_crank_rpm_sim_cfg.min          = MIN_CRANK_RPM;
        m_crank_rpm_sim_cfg.max          = MAX_CRANK_RPM;
        m_crank_rpm_sim_cfg.incr         = CRANK_RPM_INCREMENT;
        m_crank_rpm_sim_cfg.start_at_max = false;
        sensorsim_init(&m_crank_rpm_sim_state, &m_crank_rpm_sim_cfg);
        m_cumulative_wheel_revs        = 0;
        m_auto_calibration_in_progress = false;
    /**@brief Function for starting application timers.
    static void application_timers_start(void)
        uint32_t csc_meas_timer_ticks;
        // Start application timers.
    //    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
        csc_meas_timer_ticks = APP_TIMER_TICKS(SPEED_AND_CADENCE_MEAS_INTERVAL);
        err_code = app_timer_start(m_csc_meas_timer_id, csc_meas_timer_ticks, NULL);
    /**@brief Function for handling the Connection Parameter events.
     * @details This function will be called for all events in the Connection Parameters Module which
     *          are passed to the application.
     *          @note All this function does is to disconnect. This could have been done by simply
     *                setting the disconnect_on_fail configuration parameter, but instead we use the
     *                event handler mechanism to demonstrate its use.
    /**@brief Function for handling a Connection Parameters error.
        ble_conn_params_init_t connection_params_init;
        memset(&connection_params_init, 0, sizeof(connection_params_init));
        connection_params_init.p_conn_params                  = NULL;
        connection_params_init.first_conn_params_update_delay = FIRST_CONN_PARAMS_UPDATE_DELAY;
        connection_params_init.next_conn_params_update_delay  = NEXT_CONN_PARAMS_UPDATE_DELAY;
        connection_params_init.max_conn_params_update_count   = MAX_CONN_PARAMS_UPDATE_COUNT;
        connection_params_init.start_on_notify_cccd_handle    = m_cscs.meas_handles.cccd_handle;
        connection_params_init.disconnect_on_fail             = false;
        connection_params_init.evt_handler                    = on_conn_params_evt;
        connection_params_init.error_handler                  = conn_params_error_handler;
        err_code = ble_conn_params_init(&connection_params_init);
        ret_code_t err_code = bsp_indication_set(BSP_INDICATE_IDLE);
        // Prepare wakeup buttons.
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
                NRF_LOG_INFO("Fast advertising");
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        ret_code_t err_code = NRF_SUCCESS;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
    						// Se si disconnette il BLE invio qualsiasi badge viene letto,
    						// anche se uguale al precedente
                break ;
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
     * @param[in]   event   Event generated by button press.
    static void bsp_event_handler(bsp_event_t event)
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
            case BSP_EVENT_WHITELIST_OFF:
    /**@brief Function for the Peer Manager initialization.
    static void peer_manager_init(void)
        err_code = pm_init();
        sec_param.bond           = SEC_PARAM_BOND;
        sec_param.mitm           = SEC_PARAM_MITM;
        sec_param.lesc           = SEC_PARAM_LESC;
        sec_param.keypress       = SEC_PARAM_KEYPRESS;
        sec_param.io_caps        = SEC_PARAM_IO_CAPABILITIES;
        sec_param.oob            = SEC_PARAM_OOB;
        sec_param.min_key_size   = SEC_PARAM_MIN_KEY_SIZE;
        sec_param.max_key_size   = SEC_PARAM_MAX_KEY_SIZE;
        sec_param.kdist_own.enc  = 1;
        sec_param.kdist_own.id   = 1;
        sec_param.kdist_peer.enc = 1;
        sec_param.kdist_peer.id  = 1;
    /**@brief Clear bond information from persistent storage.
    static void delete_bonds(void)
        NRF_LOG_INFO("Erase bonds!");
        err_code = pm_peers_delete();
        ble_advertising_init_t init;
        init.advdata.name_type               = BLE_ADVDATA_FULL_NAME;
        init.advdata.include_appearance      = true;
        init.advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
        init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
        init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
            nrf_pwr_mgmt_run();
    static void advertising_start(bool erase_bonds)
        if (erase_bonds == true)
            delete_bonds ( ) ;
            // Advertising is started by PM_EVT_PEERS_DELETE_SUCCEEDED event.
            err_code = ble_advertising_start ( &m_advertising , BLE_ADV_MODE_FAST ) ;
            APP_ERROR_CHECK ( err_code ) ;
    *		@brief 		function name  :  init_autolistcard ( void )
    *		@details 	return			OK :	comando impostato correttamente
    	//		SEND ->  50 00 05 23 04 64 03 01 00 14
    	//              a  b  c  d  e  f  g  h  i  l
    	// a = ACK
    	// b = Data lenght 1 to be transmitted exluding header and XOR
    	// c = Data lenght 2 to be transmitted exluding header and XOR
    	// d = Command
    	// e = Card Type -> TYPE is 0x04: ISO15693 Only ( bit 2 )
    	// f = Period -> The time interval between the antenna scanning. Generally set to 100ms, that is 0x64
    	// g = ANT -> Which ant use to list the card ( 8 bit ) -> 0x00 will list card cooperatively of all antenna in one time. (Default setting)
    	// h = NOTICE -> 0x01 = NOTICE when a tag enters the field
    	// i = RFU -> Reserved
    	// l = Checksum XOR
    	// To more info read, pag.20 "OEM-DES devices Communication Protocol_4.4_EN.pdf"
    	char					tmp_buff_send [ 10 ] = { 0x50 , 0x00 , 0x05 , 0x23 , 0x04 , 0x64 , 0x03 , 0x01 , 0x00 , 0x14 } ;
    	unsigned int	try_again_index = 0 ;
    	#ifdef DEBUG_ON
    	ret_code_t 		ret_error ;
    	// Se ci sono errori ritento MAX_TRY...
    	for ( try_again_index = 0 ; try_again_index < MAX_TRY_AGAIN_AUTOLISTCARD_COMMAND ; try_again_index ++ )
    		// Resetto il buffer
    		memset ( buff_received_uart_badge , 0 , sizeof ( buff_received_uart_badge ) ) ;
    		( void ) nrf_serial_flush ( &serial_uart , 0 ) ;
    		// Attivo la funzione autolistcard
    		nrf_serial_write ( &serial_uart , &tmp_buff_send , 10 , NULL , 0 ) ;
    		ret_code_t ret ;
    		ret = nrf_serial_read ( &serial_uart , &buff_received_uart_badge , 5 , NULL , 0 ) ;
    		// Verifico se ho ricevuto l'ACK
    		if ( strncmp ( buff_received_uart_badge , ACK , 5 ) == BUFF_EQUAL )
    			// ACK ricevuto ...
    			#ifdef DEBUG_ON
    			// Debug
    			print_Debug ( "ACK autolistcard ricevuto\r\n" ) ;
    			// Spengo il led
    			return OK ;
    		#ifdef DEBUG_ON
    		// Salvo l'errore da visualizzare
    		// Nota: non posso inizializzare la variabile ret = 0 perch� NRF_SUCCESS � uguale a 0
    		ret_error = ret ;
    		nrf_delay_ms ( 100 ) ;
    	#ifdef DEBUG_ON
    	// DEBUG //
    	// Stampo il codice letto
    	memset ( tmp_buff_debug , 0 , sizeof ( tmp_buff_debug ) ) ;
    	sprintf ( tmp_buff_debug , "Comando autolistcard non eseguito correttamente per %i tentativi, codice:%i\r\n" , MAX_TRY_AGAIN_AUTOLISTCARD_COMMAND , ret_error ) ;
    	print_Debug ( tmp_buff_debug ) ;
    	// Spengo il led
    	// Rimango bloccato qui e segnalo l'errore facendo blinkare il LED 2
    	while ( true )
    		bsp_board_led_invert ( ID_LED_4 ) ;
    		nrf_delay_ms ( 500 ) ;
     * @brief TWI initialization.
        ret_code_t err_code ;
        const nrf_drv_twi_config_t twi_config = {
           .scl                = PIN_SCL_BNO055 ,	// SCL 26
           .sda                = PIN_SDA_BNO055 ,	// SDA 27
           .frequency          = NRF_DRV_TWI_FREQ_100K ,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH ,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init ( &m_twi , &twi_config , NULL , NULL ) ;
    		if ( err_code != NRF_SUCCESS )
    			return false ;
        // APP_ERROR_CHECK ( err_code ) ;
        nrf_drv_twi_enable ( &m_twi ) ;
    		return true ;
    /** @brief Function for reading pulse MaxSonar sensor.
    	uint32_t counter_pulse = 0 ;
    	uint32_t counter_time = 0 ;
    	// 1 - Inizio a leggere l'onda quando il segnale � basso
    	if ( nrf_gpio_pin_read ( RX_PIN_NUMBER ) == LOW_PULSE_MAXSONAR )
    		// Attivo il sengale
    		NRF_TIMER2->TASKS_CLEAR = ON ;
    		NRF_TIMER2->TASKS_START = ON ;
    		// Time-put 10 ms
    		while ( counter_time <= TIMEOUT_PULSE_MAXSONAR )
    			// 2 - Attendo di vederlo alto
    			if ( nrf_gpio_pin_read ( RX_PIN_NUMBER ) == HIGH_PULSE_MAXSONAR )
    				// Fermo il time-out che attendeva di vedere il segnale alto
    				NRF_TIMER2->TASKS_STOP = ON ;
    				// Cancello il timer e lo riattivo per conteggiare l'ampiezza del segnale
    				// Ho trovato il segnale alto, continuo a leggerlo
    				reading_pulse_active = ON ;
    				break ;
    			// Rchiamando TASKS_CAPTURE [ 0 ] aggiorno il valore del registro CC[0]
    			NRF_TIMER2->TASKS_CAPTURE [ 0 ] = ACTIVE_READING_TIME_PULSE_MAXSONAR ;
    			// Leggo il timer
    			counter_time = NRF_TIMER2->CC [ 0 ] ;
    		// Resetto la variabile
    		counter_time = 0 ;
    		// Continuo la lettura del segnale alto per verificare l'ampiezza dell'onda e di
    		// conseguenza il valore del altezza restituito dal sensore
    		if ( reading_pulse_active == ON )
    			// Time-put 10 ms
    					;	// 3 - Leggo l'ampiezza dell'onda
    					// 4 - Il segnale � tornato a 0, onda terminata
    					// Salvo il valore
    					counter_pulse = counter_time ;
    					break ;
    				// Leggo il timer
    	return counter_pulse ;
    /**@brief Function for application main entry.
    int 	main ( void )
        bool 				erase_bonds ;
    		ret_code_t 	ret ;
        // Initialize.
    		//log_init ( ) ;
        timers_init ( ) ;
        buttons_leds_init ( &erase_bonds ) ;
        power_management_init ( ) ;
        ble_stack_init ( ) ;
        gap_params_init ( ) ;
        gatt_init ( ) ;
        advertising_init ( ) ;
        services_init ( ) ;
        sensor_simulator_init ( ) ;
        conn_params_init ( ) ;
        peer_manager_init ( ) ;
    		// GPIO
    		// param1 - pin_number Specifies the pin number.
    		// param2 - pull_config State of the pin range pull resistor (no pull, pulled down, or pulled high).
    		nrf_gpio_cfg_input ( RX_PIN_NUMBER , NRF_GPIO_PIN_NOPULL ) ;
    		// Inizializzazione necessaria per comunicare con la UART
        nrf_drv_clock_lfclk_request ( NULL ) ;
        ret = app_timer_init ( ) ;
        APP_ERROR_CHECK ( ret ) ;
    		// Inizializzo il Timer
    		// Frequenza 1 MHz
    		// Bit width 32 bit
    		// Config mode timer
    		NRF_TIMER2->BITMODE = TIMER_CONFIG_BIT_WIDTH_32bit ;
    		NRF_TIMER2->PRESCALER = TIMER_CONFIG_FREQUENCY ;
    		NRF_TIMER2->MODE = TIMER_CONFIG_MODE ;
    		// Inizializzol la comuncazione I2C
    		error_system = twi_init ( ) ;
    		// Controllo se inizializzato correttamente
    		if ( error_system == false )
    			while ( true )
    		// Inizializzo il sensore
    		error_system = BNO055_init ( ) ;
    			while ( true )
    		// Se ricevo dati blinka il LED 3
    		// Inizializzo la UART
    		ret = nrf_serial_init ( &serial_uart , &m_uart0_drv_config , &serial_config ) ;
    		nrf_delay_ms ( 3000 ) ;
    		// Inizializzo la lettura continua
    		init_autolistcard ( ) ;
        // Start execution.
        NRF_LOG_INFO ( " Cycling Speed and Cadence example started." ) ;
        application_timers_start ( ) ;
        advertising_start ( erase_bonds ) ;
    		ret_code_t ret_loop ;
        // Enter main loop.
        for (;;)
    				/******************* I2C. *****************************
    				readLIADataYBNO055 ( &data_BNO055 ) ;
    				readQUADataXBNO055 ( &data_BNO055 ) ;
    				/******************* BLE IDLE STATE. ******************
            // idle_state_handle ( ) ;
    				/******************* PULSE WIDTH MAX SONAR. ***********
    				tmp_pulse_width_MaxSonar = read_pulse_MaxSonar ( ) ;
    				if ( ( tmp_pulse_width_MaxSonar != 0 ) && ( pulse_width_MaxSonar != tmp_pulse_width_MaxSonar ) )
    					pulse_width_MaxSonar = tmp_pulse_width_MaxSonar ;
    				/******************* SERIAL COMUNICATION. *************
    				if ( ( ( pulse_width_MaxSonar > 0 ) && ( pulse_width_MaxSonar	<= ( RANGE_MINIMUM + 5 ) ) ) && ( counter_reading_badge < TIMEOUT_READING_BADGE ) )
    					uint8_t p_read ;
    					// Attendo che viene passato il badge
    					// ret_loop = nrf_serial_read ( &serial_uart , &buff_received_uart_badge , 18 , NULL , 5 ) ;
    					ret_loop = nrf_serial_read ( &serial_uart , &p_read , 1 , NULL , 0 ) ;
    					if ( ( ret_loop != NRF_SUCCESS ) && ( ret_loop != NRF_ERROR_TIMEOUT ) )
    						APP_ERROR_CHECK ( ret_loop ) ;
    					// Utilizzo per temporizzare il ciclo il timeout di attesa del messaggio contenente il badge
    					counter_reading_badge += TIME_MS_5 ;
    					if ( ret_loop != NRF_SUCCESS )
    						continue ;
    					// Se ricevo dati blinka il LED 1
    					// Resetto il counter
    					// Passato il badge, aggiorno il codice tramite sull'app
    					badge_update = true ;
    					/******************* SAVING BADGE CODE. ***************
    					// Salvo il codice UID del badge
    					memcpy ( char_UID_badge , buff_received_uart_badge + 9 , 8 ) ;
    					sprintf ( UID_badge , "%02X%02X%02X%02X%02X%02X%02X%02X" , char_UID_badge [ 0 ] , char_UID_badge [ 1 ] , char_UID_badge [ 2 ] ,
    																																		 char_UID_badge [ 3 ] , char_UID_badge [ 4 ] , char_UID_badge [ 5 ] ,
    																																		 char_UID_badge [ 6 ] , char_UID_badge [ 7 ] ) ;
    					// nrf_delay_ms ( 100 ) ;
    					// Elimino due letture del badge ravvicinate di fila
    					nrf_serial_read ( &serial_uart , &buff_received_uart_badge , 18 , NULL , 0 ) ;
    				else if ( pulse_width_MaxSonar >= ( RANGE_MINIMUM + 5 ) )
    					// Resetto il timer
  • Are you still getting timeout error code? Some other error code? It still looks like you do not check error code from every call to nrf_serial_*.
    When the RFID reader read badge no particular error occurs after the UART is stops working. I have checked with the function APP_ERROR_CHECK.
    uint8_t p_read ;
            continue ;
    I'm posting the solution here in case anyone else should be experiencing similar issues:
    The issue seems to occur when the UARTE0 peripheral detects an error. If you set a breakpoint inside case NRFX_UARTE_EVT_ERROR in uart_event_handler() in nrf_serial.c, you can check the UARTE0 ERRORSRC register when the issue occurs (note that you should disable UARTE1 when doing this, to avoid errors caused by that instance). In my case it reads 0x0000000C (FRAMING + BREAK errors).
    The reason that the UARTE peripheral stops working when these errors occur, is that there is no NRFX_UARTE_EVT_RX_DONE event received afterwards. NRFX_UARTE_EVT_RX_DONE event is the only place after nrf_serial_init that nrfx_uarte_rx() is called. When this is not called, the UARTE will no longer be in RX mode.
    The solution to this issue is to re-init the serial interface. My recommended solution for doing this, is to implement the nrf_serial event handler and set a re-init flag when the NRF_SERIAL_EVENT_DRV_ERR event is received, and re-init if the flag is set after every call to nrf_serial_read. It is not possible to re-init direcly in the event handler, as the read mutex is locked by the read operation.
    Below code show necessary code and changes:
    static void serial_event_handler( struct nrf_serial_s const *p_serial, nrf_serial_event_t event ); // Forward declaration
    NRF_SERIAL_CONFIG_DEF ( serial_uart_badge_reading_config , NRF_SERIAL_MODE_IRQ ,
                            &serial_uart_badge_reading_queues , &serial_uart_badge_reading_buffs , serial_event_handler , sleep_handler ) ; // sostituito NULL ( il secondo ) a sleep_handler
    bool badge_reinit = false;
    	switch (event)
    		case NRF_SERIAL_EVENT_DRV_ERR:
    			nrf_serial_t const * p_ser = p_serial;
    			if(p_ser == &serial_uart_badge_reading)  // Unless events from multiple serial instances is passed to same event_handler, this check should not be necessary
    				badge_reinit = true;
    nrf_serial_read(..);
    if(badge_reinit)
    	ret_code_t ret = nrf_serial_uninit(&serial_uart_badge_reading);
    	ret = nrf_serial_init ( &serial_uart_badge_reading , &m_serial_uart_badge_reading_drv_config , &serial_uart_badge_reading_config ) ;
    Technically you can also call the function to start RX again when you receive the event inside nrf_serial.c, but this would mean modifying the SDK libraries, which I would not recommend.
    Jørgen
