CPS/SEN/SPE/BI-04-C [Procedure Already In Progress] inconc
Hello ,
The test of CPS/SEN/SPE/BI-04-C [Procedure Already In Progress]  failed.
While this test, the tester sometimes received the unexpected ATT Disconnect which our product might send.
Could you tell me how to stop the ATT Disconnect?
The test-log
  +0 ms
  Initialize Test Case: Build date: Jul 18 2018, 09:31:58
  +0 ms
  Start Test Case: CPS/SEN/SPE/BI-04-C
  +0 ms
  Message: PTS Log started on Tuesday, October 02, 2018, 16:34:18
  +0 ms
  Message: PTS: v7.3.0 Build 40
  +0 ms
  Message: OS: Microsoft Windows NT 6.1.7601 Service Pack 1
  +0 ms
  Message: OS Name: Microsoft Windows 7 Home Premium
  +4009 ms
  Preliminary Verdict: PASS
  +4056 ms
  Send Event: HCI!HCI_RESET
  +4180 ms
  Receive Event: HCI?HCI_RESET_COMPLETE_EVENT{
  status=HCI_OK
  +4180 ms
  +4180 ms
  Send Event: HCI!HCI_SET_EVENT_MASK{
  eventMask=0x3FFFFFFFFFFFFFFF
  +4180 ms
  Receive Event: HCI?HCI_SET_EVENT_MASK_COMPLETE_EVENT{
  status=HCI_OK
  +4180 ms
  +4180 ms
  Send Event: HCI!HCI_READ_LOCAL_VERSION_INFORMATION
  +4180 ms
  Receive Event: HCI?HCI_READ_LOCAL_VERSION_INFORMATION_COMPLETE_EVENT{
  status=HCI_OK,
  hciVersion=HCI_VERSION_4_0,
  hciRevision=0x2031,
  lmpVersion=0x06,
  manufacturerName=0x000A,
  lmpSubversion=0x2031
  +4180 ms
  +4180 ms
  Send Event: HCI!HCI_READ_BD_ADDR
  +4196 ms
  Receive Event: HCI?HCI_READ_BD_ADDR_COMPLETE_EVENT{
  status=HCI_OK,
  bdAddress=0x001BDC0808A3
  +4196 ms
  +4196 ms
  Send Event: HCI!HCI_LE_SET_EVENT_MASK{
  leEventMask=0x000000000000001F
  +4196 ms
  Receive Event: HCI?HCI_LE_SET_EVENT_MASK_COMPLETE_EVENT{
  status=HCI_OK
  +4196 ms
  +4196 ms
  Send Event: HCI!HCI_WRITE_LE_HOST_SUPPORTED{
  leSupportedHost=HCI_LE_SUPPORTED_HOST_ENABLED,
  simultaneousLeHost=HCI_SIMULTANEOUS_LE_HOST_ENABLED
  +4196 ms
  Receive Event: HCI?HCI_WRITE_LE_HOST_SUPPORTED_COMPLETE_EVENT{
  status=HCI_OK
  +4196 ms
  +4196 ms
  Send Event: HCI!HCI_LE_CLEAR_WHITE_LIST
  +4196 ms
  Receive Event: HCI?HCI_LE_CLEAR_WHITE_LIST_COMPLETE_EVENT{
  status=HCI_OK
  +4196 ms
  +4196 ms
  Send Event: HCI!HCI_WRITE_SIMPLE_PAIRING_MODE{
  simplePairingMode=HCI_SIMPLE_PAIRING_ENABLED
  +4212 ms
  Receive Event: HCI?HCI_WRITE_SIMPLE_PAIRING_MODE_COMPLETE_EVENT{
  status=HCI_OK
  +4212 ms
 +4212 ms
  +4212 ms
  Send Event: HCI!HCI_LE_ADD_DEVICE_TO_WHITE_LIST{
  addressType=HCI_LE_PUBLIC_DEVICE_ADDRESS,
  address=0xC58DCE70012F
  +4212 ms
  Receive Event: HCI?HCI_LE_ADD_DEVICE_TO_WHITE_LIST_COMPLETE_EVENT{
  status=HCI_OK
  +4212 ms
  +4212 ms
  addressType=HCI_LE_RANDOM_DEVICE_ADDRESS,
  +4212 ms
  status=HCI_OK
  +4212 ms
  +4212 ms
  +4212 ms
  +4212 ms
  Send Event: HCI!HCI_LE_SET_SCAN_PARAMETERS{
  leScanType=HCI_LE_ACTIVE_SCANNING,
  leScanInterval=0x001E,
  leScanWindow=0x001E,
  ownAddressType=HCI_LE_PUBLIC_DEVICE_ADDRESS,
  scanningFilterPolicy=HCI_LE_ACCEPT_WHITE_LIST_ADVERTISING_PACKETS
  +4212 ms
  Receive Event: HCI?HCI_LE_SET_SCAN_PARAMETERS_COMPLETE_EVENT{
  status=HCI_OK
  +4212 ms
  +4227 ms
  Send Event: HCI!HCI_LE_SET_SCAN_ENABLE{
  leScanEnable=HCI_LE_SCAN_ENABLE,
  filterDuplicates=HCI_LE_DUPLICATE_FILTERING_DISABLE
  +5506 ms
  +5506 ms
  +7519 ms
  +7519 ms
  +9516 ms
  +9516 ms
  leScanEnable=HCI_LE_SCAN_DISABLE,
  +9531 ms
  +9562 ms
  Send Event: ATT!ATT_CONNECT_REQ{
  peerAddr=0xC58DCE70012F,
  peerAddrType=HCI_LE_RANDOM_DEVICE_ADDRESS,
  ownAddrType=HCI_LE_PUBLIC_DEVICE_ADDRESS,
  minInterval=0x0032,
  maxInterval=0x0046,
  latency=0x0000
  +13556 ms
  Receive Event: SEC?SEC_LE_REMOTE_CSRK_REQUEST_REQ{
  +13556 ms
  Receive Event: ATT?ATT_CONNECT_RSP{
  bdAddr=0xC58DCE70012F,
  lcid=0x0040,
  status=HCI_OK
  +13556 ms
  Receive Event: HCI?HCI_LE_CONNECTION_COMPLETE_EVENT{
  status=HCI_OK,
  connectionHandle=0x004D,
  role=HCI_ROLE_MASTER,
  peerAddressType=HCI_LE_RANDOM_DEVICE_ADDRESS,
  peerAddress=C58DCE70012F,
  connInterval=0x0046,
  connLatency=0x0000,
  supervisionTimeout=0x07D0,
  clockAccuracy=HCI_LE_CLOCK_ACCURACY_500PPM
  +13556 ms
  Send Event: SEC!SEC_LE_REMOTE_CSRK_REQUEST_RSP{
  accept=FALSE,
  keyType=HCI_UNAUTHENTICATED_COMBINATION_KEY,
  csrk=0x00000000000000000000000000000000,
  signCounter=0x00000000
  +13556 ms
  +13556 ms
  Verdict Description: Connection setup successfully.
  +13556 ms
  Pass: Tester successfully initiated connection.
  +13556 ms
  Verdict Description: Tester successfully initiated connection.
  +13556 ms
  Verdict Description: LE Security not initiated due to TSPX_security_enabled value.
  +13556 ms
  Send Event: ATT!ATT_FIND_BY_TYPE_VALUE_REQ{
  lcid=0x0040,
  startingHandle=0x0001,
  endingHandle=0xFFFF,
  attributeType=0x2800,
  length=0x0002,
  PrimaryService=0x1818
  +13681 ms
  Receive Event: ATT?ATT_FIND_BY_TYPE_VALUE_RSP{
  lcid=0x0040,
  HandleRange={
  foundAttributeHandle=0x000F,
  endFoundHandle=0x0019
  +13852 ms
  Receive Event: ATT?ATT_FIND_BY_TYPE_VALUE_CFM{
  lcid=0040,
  result=0x0100,
  errorHandle=0x0000,
  HandleRanges={
  endFoundHandle=0x0019,
  +13852 ms
  +13852 ms
  Verdict Description: Discover Primary Service by Service UUID Request completed successfully.
  +13852 ms
  Pass: The IUT successfully returned the UUID for Cycling Power
  +13852 ms
  Verdict Description: The IUT successfully returned the UUID for Cycling Power
  +13852 ms
  Send Event: ATT!ATT_READ_BY_TYPE_REQ{
  lcid=0x0040,
  startingHandle=0x000F,
  endingHandle=0x0019,
  attributeTypeSize=0x02,
  attributeType=0x2803
  +14024 ms
  Receive Event: ATT?ATT_READ_BY_TYPE_RSP{
  handle=0x0010
  value{
  Properties=0x10,
  Handle=0x0011,
  UUID=0x2A63
  handle=0x0013
  value{
  Properties=0x02,
  Handle=0x0014,
  UUID=0x2A65
  handle=0x0015
  value{
  Properties=0x02,
  Handle=0x0016,
  UUID=0x2A5D
  +14196 ms
  handle=0x0017
  value{
  Properties=0x28,
  Handle=0x0018,
  UUID=0x2A66
  +14383 ms
  Receive Event: ATT?ATT_READ_BY_TYPE_CFM{
  lcid=0x0040,
  attributeType=0x2803,
  result=0x0100,
  errorHandle=0x0000
  +14383 ms
  handle=0x0010
  value{
  Properties=0x10,
  Handle=0x0011,
  UUID=0x2A63
  handle=0x0013
  value{
  Properties=0x02,
  Handle=0x0014,
  UUID=0x2A65
  handle=0x0015
  value{
  Properties=0x02,
  Handle=0x0016,
  UUID=0x2A5D
  handle=0x0017
  value{
  Properties=0x28,
  Handle=0x0018,
  UUID=0x2A66
  +14383 ms
  +14383 ms
  Verdict Description: Discover All Characteristics of Service Request completed successfully.
  +14383 ms
  Send Event: ATT!ATT_FIND_INFO_REQ{
  lcid=0x0040,
  startingHandle=0x0012,
  endingHandle=0x0012
  +14554 ms
  Receive Event: ATT?ATT_FIND_INFO_CFM{
  lcid=0x0040,
  result=0x0100,
  errorHandle=0x0000
  +14554 ms
  Receive Event: ATT?ATT_FIND_INFO_RSP{
  handle=0x0012,
  uuid=0x2902
  +14554 ms
  handle=0x0012,
  uuid=0x2902,
  +14554 ms
  +14554 ms
  Verdict Description: Discover All Characteristic Descriptors Request completed successfully.
  +14554 ms
  lcid=0x0040,
  startingHandle=0x0019,
  endingHandle=0x0019
  +14726 ms
  lcid=0x0040,
  result=0x0100,
  errorHandle=0x0000
  +14726 ms
  handle=0x0019,
  uuid=0x2902
  +14726 ms
  handle=0x0019,
  uuid=0x2902,
  +14726 ms
  +14726 ms
  +14726 ms
  Send Event: ATT!ATT_WRITE_REQ{
  lcid=0x0040,
  attributeHandle=0x0019,
  length=0x0002,
  value{
  Properties=0x0000
  +14991 ms
  Receive Event: ATT?ATT_WRITE_CFM{
  lcid=0x0040,
  result=0x0100,
  errorHandle=0x0000
  +14991 ms
  +17987 ms
  lcid=0x0040,
  length=0x0002,
  value{
  Properties=0x0002
  +18143 ms
  lcid=0x0040,
  result=0x0100,
  errorHandle=0x0000
  +18143 ms
  +18143 ms
  lcid=0x0040,
  attributeHandle=0x0012,
  length=0x0002,
  value{
  Properties=0x0000
  +18314 ms
  lcid=0x0040,
  result=0x0100,
  errorHandle=0x0000
  +18314 ms
  +21309 ms
  lcid=0x0040,
  length=0x0002,
  value{
  Properties=0x0001
  +21543 ms
  lcid=0x0040,
  result=0x0100,
  errorHandle=0x0000
  +21543 ms
  +21559 ms
  Send Event: ATT!ATT_READ_REQ{
  lcid=0x0040,
  attributeHandle=0x0014
  +21731 ms
  Receive Event: ATT?ATT_READ_CFM{
  lcid=0x0040,
  length=0x0004,
  result=0x0100,
  errorHandle=0x0000,
  value{
  CyclingPowerFeature=0x0019020A
  +21731 ms
  +21731 ms
  Verdict Description: Read Request completed successfully.
  +21731 ms
  +21731 ms
  Pass: The data received for 'Cycling Power Feature' conforms to the schema
  +21731 ms
  Verdict Description: The data received for 'Cycling Power Feature' conforms to the schema
  +21777 ms
  lcid=0x0040,
  attributeHandle=0x0018,
  length=0x0001,
  value{  OpCode=0x0C,  CyclingPowerVectorControlValue=0x0063  }  }   +21902 ms  Receive Event: ATT?ATT_WRITE_CFM{  lcid=0x0040,  result=0x0100,  errorHandle=0x0000  }   +21902 ms  Preliminary Verdict: PASS   +22511 ms  Receive Event: ATT?ATT_HANDLE_VALUE_NOTIFICATION_REQ{  lcid=0x0040,  attributeHandle=0x0011,  length=0x000A,  attributeValue=0x00000000005B0000002C  }   +22511 ms  Receive Event: ATT?ATT_HANDLE_VALUE_IND{  lcid=0x0040,  attributeHandle=0x0018,  length=0x0005,  attributeValue=0x00FFFF010C20  }   +22511 ms  Preliminary Verdict: PASS   +22511 ms  Pass: The value for 'Cycling Power Control Point' sent by the IUT was correctly formatted.   +22511 ms  Verdict Description: The value for 'Cycling Power Control Point' sent by the IUT was correctly formatted.   +22511 ms  Send Event: ATT!ATT_WRITE_REQ{  lcid=0x0040,  attributeHandle=0x0018,  length=0x0001,  value{  OpCode=0x0C,  CyclingPowerVectorControlValue=0x006E  }  }   +22682 ms  Receive Event: ATT?ATT_WRITE_CFM{  lcid=0x0040,  result=0x0100,  errorHandle=0x0000
  +22682 ms
  +22682 ms
  Verdict Description: Write Request completed successfully.
  +43383 ms
  Receive Event: ATT?ATT_DISCONNECT_REQ{
  lcid=0x0040
  +43383 ms
  Verdict Description: Unexpected ATT Disconnect received.
  +43383 ms
  Receive Event: HCI?HCI_LE_DISCONNECTION_COMPLETE_EVENT{
  status=HCI_OK,
  reason=HCI_CONNECTION_TIMEOUT
  +43383 ms
  +43383 ms
  Inconclusive: Non-passing verdict returned from APICOM, see log for more details.
  +43383 ms
  Verdict Description: Non-passing verdict returned from APICOM, see log for more details.
  +45021 ms
  Final Verdict: INCONC
  +45021 ms
  Encrypted Verdict:
 A1#ZWY4MzQ5MDg3MmQwNTIxOGQzMzQ5YjY2ODA5M2MzNjQ5ZDY4NmY0Yjc2MzIzM2VkNTUyNTFhNGU4Mjg1MjI0NA==#S7tk81R4UBM+y2jy+jTqSwIFbmqou/dBe0rGBnSk5Rd1NLMNsmJ6x0apjF5t71xW
  +45021 ms
  Test Case Ended: CPS/SEN/SPE/BI-04-C
Kiyoshi Iwai
  • Hello Kioshi,
    Can I ask you how did you solve this problem?
    Marcin Kawalec
  • I have also problem with pass this test CPS/SEN/SPE/BI-04-C
    At the step 5 of this precedure, you can find that "the Lower Tester does not send any Confirmation to acknowledge this indication".
    After that IUT sent:
    +18236 ms
    Receive Event:           L2CAP?L2CAP_LE_CONNECTION_UPDATE_IND{
                               peerAddr=0xCC52D3B4B51F,
                               minInterval=0x0014,
                               maxInterval=0x0028,
                               slaveLatency=0x0000,
                               supervision_timeout=0x01F4
    +18236 ms
    Send Event:              L2CAP!L2CA_LE_CONNECTION_UPDATE_RSP{
                               peerAddrType=0x01,
                               paramAccepted=1
    and next:
    +40544 ms
    Receive Event:           ATT?ATT_DISCONNECT_IND{
                               lcid=0x1205
    +40544 ms
                               status=HCI_OK,
                               connectionHandle=0x0063,
    +40544 ms
    What sould I do in situation when Lower Tester does not send any Confirmation to acknowledge this indication? As Kiyoshi said it is abnormal situation.
    I will be grateful for help.
    Full log here:
    <?xml version="1.0" encoding="utf-8"?>
    <ARCHIVE>
      <VERSION>2.0</VERSION>
      <PicsPixit>Test Case Started: CPS v. 7.6.0.15, CPS/SEN/SPE/BI-04-C started on Friday, April 24, 2020, 10:37:18
    ICS VALUES:
    TSPC_ALL FALSE
    TSPC_CPS_0_1 FALSE
    TSPC_CPS_0_2 TRUE
    TSPC_CPS_0a_1 TRUE
    TSPC_CPS_1_1 FALSE
    TSPC_CPS_1_2 TRUE
    TSPC_CPS_2_1 FALSE
    TSPC_CPS_2_2 TRUE
    TSPC_CPS_2_3 FALSE
    TSPC_CPS_2_4 TRUE
    TSPC_CPS_2_5 FALSE
    TSPC_CPS_2_6 FALSE
    TSPC_CPS_2_7 FALSE
    TSPC_CPS_2_8 FALSE
    TSPC_CPS_2_9 FALSE
    TSPC_CPS_2_10 TRUE
    TSPC_CPS_2_11 FALSE
    TSPC_CPS_2_12 FALSE
    TSPC_CPS_2_13 FALSE
    TSPC_CPS_2_14 FALSE
    TSPC_CPS_2_15 FALSE
    TSPC_CPS_2_16 FALSE
    TSPC_CPS_2_17 FALSE
    TSPC_CPS_2_18 TRUE
    TSPC_CPS_2_19 FALSE
    TSPC_CPS_2_20 FALSE
    TSPC_CPS_2_21 FALSE
    TSPC_CPS_2_22 FALSE
    TSPC_CPS_2_23 FALSE
    TSPC_CPS_2_24 TRUE
    TSPC_CPS_3_1 TRUE
    TSPC_CPS_3_2 TRUE
    TSPC_CPS_3_3 TRUE
    TSPC_CPS_3_4 TRUE
    TSPC_CPS_3_5 FALSE
    TSPC_CPS_3_6 TRUE
    TSPC_CPS_3_7 FALSE
    TSPC_CPS_3_8 TRUE
    TSPC_CPS_3_9 FALSE
    TSPC_CPS_3_10 FALSE
    TSPC_CPS_3_11 FALSE
    TSPC_CPS_3_12 FALSE
    TSPC_CPS_3_13 FALSE
    TSPC_CPS_3_14 FALSE
    TSPC_CPS_3_15 FALSE
    TSPC_CPS_3_16 TRUE
    TSPC_CPS_3_17 TRUE
    TSPC_CPS_3_18 FALSE
    TSPC_CPS_3_19 FALSE
    TSPC_CPS_3_20 FALSE
    TSPC_CPS_3_21 FALSE
    TSPC_CPS_3_22 FALSE
    TSPC_CPS_3_23 FALSE
    TSPC_CPS_3_24 FALSE
    TSPC_CPS_3_25 FALSE
    TSPC_CPS_3_26 FALSE
    TSPC_CPS_3_27 FALSE
    TSPC_CPS_3_28 FALSE
    TSPC_CPS_3_29 FALSE
    TSPC_CPS_3_30 TRUE
    TSPC_CPS_3_31 FALSE
    TSPC_CPS_3_32 FALSE
    TSPC_CPS_3_33 FALSE
    TSPC_CPS_3_34 FALSE
    TSPC_CPS_3_35 FALSE
    TSPC_CPS_3_36 FALSE
    TSPC_CPS_3_37 FALSE
    TSPC_CPS_3_38 FALSE
    TSPC_CPS_3_39 FALSE
    TSPC_CPS_3a_1 FALSE
    TSPC_CPS_4_1 TRUE
    TSPC_CPS_4_2 TRUE
    TSPC_CPS_4_3 TRUE
    TSPC_CPS_4_4 TRUE
    TSPC_CPS_4_5 TRUE
    TSPC_CPS_4_6 TRUE
    TSPC_CPS_5_1 FALSE
    TSPC_CPS_5_2 FALSE
    TSPC_CPS_5_3 FALSE
    IXIT VALUES:
    TSPX_bd_addr_iut CC52D3B4B51F
    TSPX_iut_device_name_in_adv_packet_for_random_address
    TSPX_time_guard 180000
    TSPX_use_implicit_send TRUE
    TSPX_tester_database_file C:\Program Files\Bluetooth SIG\Bluetooth PTS\Data\SIGDatabase\PTS_CPP_db.xml
    TSPX_mtu_size 23
    TSPX_secure_simple_pairing_pass_key_confirmation FALSE
    TSPX_delete_link_key FALSE
    TSPX_pin_code 0000
    TSPX_use_dynamic_pin FALSE
    TSPX_delete_ltk FALSE
    TSPX_security_enabled FALSE
    TSPX_iut_setup_att_over_br_edr FALSE
    TSPX_run_as_tester2 FALSE
    TSPX_iut_slowest_connection_interval_vector_notification 50
    TSPX_tester_appearance 0000
    </PicsPixit>
      <LOG>
    +140 ms
    Message:                 MindTree Stack Version - 016.004.000
    +140 ms
    Initialize Test Case:    Build date: Jan  7 2020, 19:20:07
    +140 ms
    +140 ms
    Message:                   PTS Log started on Friday, April 24, 2020, 10:37:18
    +140 ms
    Message:                   PTS: v7.6.0 Build 15
    +140 ms
    +140 ms
    Message:                   OS Name: Microsoft Windows 7 专业版
    +4165 ms
    +4196 ms
    +4321 ms
                               status=HCI_OK
    +4321 ms
    +4321 ms
    +4321 ms
                               status=HCI_OK
    +4321 ms
    +4321 ms
    +4321 ms
                               status=HCI_OK,
                               hciVersion=0x08,
                               hciRevision=0x30E8,
                               lmpVersion=0x08,
                               lmpSubversion=0x30E8
    +4321 ms
    +4321 ms
    +4321 ms
                               status=HCI_OK,
                               bdAddress=0x001BDCF21BF2
    +4321 ms
    +4321 ms
    +4336 ms
    Send Event:              HCI!HCI_LE_LOCAL_SUPPORTED_FEATURES
    +4336 ms
    Receive Event:           HCI?HCI_LE_READ_LOCAL_SUPPORTED_FEATURES_COMPLETE_EVENT{
                               status=HCI_OK,
                               leFeatures=0x000000000000001F
    +4336 ms
                               leEventMask=0x000000000000003F
    +4336 ms
                               status=HCI_OK
    +4336 ms
    +4336 ms
                               status=HCI_OK
    +4336 ms
                               address=0xCC52D3B4B51F
    +4336 ms
                               status=HCI_OK
    +4336 ms
    +4336 ms
    +4336 ms
                               status=HCI_OK
    +4336 ms
    +4336 ms
    +4336 ms
    +4336 ms
    +4352 ms
                               status=HCI_OK
    +4352 ms
    +4352 ms
    +4352 ms
    Receive Event:           HCI?HCI_LE_SET_SCAN_ENABLE_COMPLETE_EVENT{
                               status=HCI_OK
    +5569 ms
    +5584 ms
                               status=HCI_OK
    +5584 ms
    +5600 ms
    Send Event:              HCI!HCI_LE_CREATE_CONNECTION{
                               scanInterval=0x0020,
                               scanWindow=0x0012,
                               filterPolicy=0x00,
                               minConnInterval=0x0032,
                               maxConnInterval=0x0046,
                               latency=0x0000,
                               minCELength=0x0000,
                               maxCELength=0x0000
    +5616 ms
    Receive Event:           HCI?HCI_LE_CREATE_CONNECTION_STATUS_EVENT{
                               status=HCI_OK
    +6411 ms
    Receive Event:           ATT?ATT_CONNECT_IND{
                               bdAddr=0xCC52D3B4B51F,
                               lcid=0x1205,
                               status=0x0000
    +6411 ms
    +6411 ms
                               status=HCI_OK,
                               peerAddress=CC52D3B4B51F,
                               connInterval=0x003C,
                               connLatency=0x0000,
    +6411 ms
    +6411 ms
    +6411 ms
    +8424 ms
    +8424 ms
    Send Event:              HCI!GET_CONNECTION_HANDLE{
                               addr=0xCC52D3B4B51F,
                               addr_type=0x01,
                               conn_handle=0x0063
    +8424 ms
                               lcid=0x1205,
                               length=0x0002,
                               1818
    +8642 ms
                               lcid=0x1205,
                               HandleRange={
                                   foundAttributeHandle=0x000E,
                                   endFoundHandle=0x0018
    +8782 ms
                               lcid=1205,
                               result=0x0000,
                               errorHandle=0x0000,
                               HandleRanges={
                                   endFoundHandle=0x0018,
    +8782 ms
    +8782 ms
    +8782 ms
    +8782 ms
    +8782 ms
                               lcid=0x1205,
                               startingHandle=0x000E,
                               endingHandle=0x0018,
    +8923 ms
    Receive Event:           ATT?ATT_READ_BY_TYPE_IND{
                               lcid=0x1205,
                               length=0x0017,
                               ElementCount=03,
                               AttributeSize=07,
                               Handle=000F,
                               AttrValue=2A63001010,
                               Handle=0012,
                               AttrValue=2A65001302,
                               Handle=0014,
                               AttrValue=2A5D001502
    +8938 ms
                                 handle=0x000F
    					value{
                                   Properties=0x10,
                                   Handle=0x0010,
                                   UUID=0x2A63
                                 handle=0x0012
    					value{
                                   Properties=0x02,
                                   Handle=0x0013,
                                   UUID=0x2A65
                                 handle=0x0014
    					value{
                                   Properties=0x02,
                                   Handle=0x0015,
                                   UUID=0x2A5D
    +9079 ms
                               lcid=0x1205,
                               length=0x0009,
                               ElementCount=01,
                               AttributeSize=07,
                               Handle=0016,
                               AttrValue=2A66001728
    +9079 ms
                                 handle=0x0016
    					value{
                                   Properties=0x28,
                                   Handle=0x0017,
                                   UUID=0x2A66
    +9235 ms
                               lcid=0x1205,
                               result=0x0000,
                               errorHandle=0x0000
    +9235 ms
                                 handle=0x000F
    					value{
                                   Properties=0x10,
                                   Handle=0x0010,
                                   UUID=0x2A63
                                 handle=0x0012
    					value{
                                   Properties=0x02,
                                   Handle=0x0013,
                                   UUID=0x2A65
                                 handle=0x0014
    					value{
                                   Properties=0x02,
                                   Handle=0x0015,
                                   UUID=0x2A5D
                                 handle=0x0016
    					value{
                                   Properties=0x28,
                                   Handle=0x0017,
                                   UUID=0x2A66
    +9235 ms
    +9235 ms
    +9235 ms
                               lcid=0x1205,
                               startingHandle=0x0011,
                               endingHandle=0x0011
    +9453 ms
                                 handle=0x0011,
                                 uuid=0x2902
    +9453 ms
                                 handle=0x0011,
                                 uuid=0x2902,
    +9453 ms
    +9453 ms
    +9453 ms
                               lcid=0x1205,
                               startingHandle=0x0018,
                               endingHandle=0x0018
    +9609 ms
                                 handle=0x0018,
                                 uuid=0x2902
    +9609 ms
                                 handle=0x0018,
                                 uuid=0x2902,
    +9609 ms
    +9609 ms
    +9609 ms
                               lcid=0x1205,
                               length=0x0002,
                               0000
    +9750 ms
                               lcid=0x1205,
                               result=0x0000,
                               errorHandle=0x0000
    +9750 ms
    +11263 ms
                               lcid=0x1205,
                               length=0x0002,
                               0002
    +11403 ms
                               lcid=0x1205,
                               result=0x0000,
                               errorHandle=0x0000
    +11403 ms
    +11403 ms
                               lcid=0x1205,
                               length=0x0002,
                               0000
    +11622 ms
                               lcid=0x1205,
                               result=0x0000,
                               errorHandle=0x0000
    +11622 ms
    +13150 ms
                               lcid=0x1205,
                               length=0x0002,
                               0001
    +13275 ms
                               lcid=0x1205,
                               result=0x0000,
                               errorHandle=0x0000
    +13275 ms
    +13275 ms
                               lcid=0x1205,
                               attributeHandle=0x0013
    +13431 ms
                               lcid=0x1205,
                               length=0x0004,
                               result=0x0100,
                               errorHandle=0x0000,
                               value{
                                 CyclingPowerFeature=0x0011020A
    +13431 ms
    +13431 ms
    Verdict Description:     Read Request completed successfully. Handle=0x0013
    +13431 ms
    +13431 ms
    +13431 ms
    +13431 ms
                               lcid=0x1205,
                               attributeHandle=0x0017,
                               length=0x0001,
                               0C
    +13572 ms
                               lcid=0x1205,
                               result=0x0000,
                               errorHandle=0x0000
    +13572 ms
    +13572 ms
    Verdict Description:     Waiting for indication on handle = 0x0017 for Characteristic 'Cycling Power Control Point' (UUID = 0x2A66)
    +13587 ms
    Receive Event:           ATT?ATT_HANDLE_VALUE_NOTIFICATION_IND{
                               lcid=0x1205,
                               attributeHandle=0x0010,
                               length=0x000A,
                               attributeValue=0x0000000000000000002C
    +14632 ms
                               lcid=0x1205,
                               length=0x000A,
    +15600 ms
                               lcid=0x1205,
                               length=0x000A,
    +16582 ms
                               lcid=0x1205,
                               length=0x000A,
    +16582 ms
                               lcid=0x1205,
                               length=0x0005,
                               attributeValue=0x0001010C20
    +16582 ms
    +16598 ms
    +16598 ms
    +16598 ms
                               lcid=0x1205,
                               length=0x0001,
                               0C
    +16723 ms
                               lcid=0x1205,
                               result=0x0000,
                               errorHandle=0x0000
    +16723 ms
    +16723 ms
    +16723 ms
    +17628 ms
                               lcid=0x1205,
                               length=0x000A,
    +18236 ms
                               minInterval=0x0014,
                               maxInterval=0x0028,
    +18236 ms
                               peerAddrType=0x01,
                               paramAccepted=1
    +18610 ms
                               lcid=0x1205,
                               length=0x000A,
    +19578 ms
                               lcid=0x1205,
                               length=0x000A,
    +40544 ms
                               lcid=0x1205
    +40544 ms
                               status=HCI_OK,
    +40544 ms
    +40544 ms
    +40544 ms
    +42697 ms
                               status=HCI_OK
    +43633 ms
    +43633 ms
    Encrypted Verdict:       A1#ZWY4MzQ5MDg3MmQwNTIxOGQzMzQ5YjY2ODA5M2MzNjQ5ZDY4NmY0Yjc2MzIzM2VkNTUyNTFhNGU4Mjg1MjI0NA==#mpduB7T8LvovABj6T4Gu+NaqZZp5djc+JHVvJvU+j6aMa6oiCklRuq5sE+AhiaFT
    +43633 ms
    </LOG>
      <SUMMARY>Test case : CPS/SEN/SPE/BI-04-C started
    	- Connection setup successfully.
    	- Tester successfully initiated connection.
    	- LE Security not initiated due to TSPX_security_enabled value.
    	- Discover Primary Service by Service UUID Request completed successfully.
    	- The IUT successfully returned the UUID for Cycling Power
    	- Discover All Characteristics of Service Request completed successfully.
    	- Discover All Characteristic Descriptors Request completed successfully.
    	- Read Request completed successfully. Handle=0x0013
    	- The data received for 'Cycling Power Feature' conforms to the schema
    	- Waiting for indication on handle = 0x0017 for Characteristic 'Cycling Power Control Point' (UUID = 0x2A66)
    	- The value for 'Cycling Power Control Point' sent by the IUT was correctly formatted.
    	- Write Request completed successfully.
    	- Unexpected ATT Disconnect received.
    	- Non-passing verdict returned from APICOM, see log for more details.
    Final Verdict:INCONC
    CPS/SEN/SPE/BI-04-C finished
    </SUMMARY>
    </ARCHIVE>
  • It's been a while since I looked at this.
    Do you have an on-air sniffer log? Is there any difference if you are using TSPX_security_enabled (presuming bonding is supported)?
    Is it the same if you are using the default SDK example? For example:
    https://infocenter.nordicsemi.com/topic/com.nordic.infocenter.sdk5.v15.2.0/ble_sdk_app_csc.html
    I notice the disconnect reason is HCI_CONNECTION_TIMEOUT, this may be caused by an assert (fault_handler()), have you checked that?
