cli
I am using cli and made my own command like bellow, as you see i have a command with 3 sub commands. But i think my idea is primitive because if i have 1000 sub command so i have to write many functions!!!!
Another problem of using this method is that in putty first i have to write N1 as a sub command and in the next line SEND as a command and then i can see my results. For example :
uart_cli:~$   Do A
uart_cli:~$   DO
But i want  to type like  "SEND N1'' which is contain command and sub command and then get my results. Kindly let me how to do that and let me know if it is possible, how many sub command i can type with that? is there any limitation? For example can i have something like bellow?
uart_cli:~$  DO A L g H Z K
which A, L,H,Z,K are sub commands of DO.
//sub commands
static void cmd_DO_A(nrf_cli_t const * p_cli, size_t argc, char **argv)
           A = 1;
static void cmd_DO_B(nrf_cli_t const * p_cli, size_t argc, char **argv)
          A = 2;
static void cmd_DO_C(nrf_cli_t const * p_cli, size_t argc, char **argv)
            A = 3;
// Command
static void cmd_DO(nrf_cli_t const * p_cli, size_t argc, char **argv)
      ASSERT(p_cli);
      switch(A)
        case 1:
         case 2:
         case 3:
     * Copyright (c) 2018 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include  "nrf_cli.h"
    #include "nrf_log.h"
    #include <ctype.h>
    #include "nrf_delay.h"
    #include "nrf_esb.h"
    /* commands counter */
    static uint8_t m_dynamic_cmd_cnt;
    uint8_t     m_pyload_active = 0;
    // INDIVIDUAL ADDRESSES SUBS
    //@ Choose Board_1 function
    static void b1(nrf_cli_t const * p_cli, size_t argc, char **argv)
               m_pyload_active = 1;
    static char m_dynamic_cmd_buffer[][20] = {"b1"};
    static void cmd_send(nrf_cli_t const * p_cli, size_t argc, char **argv)
        for (size_t i = 1; i < argc; i++)
        	if (!strcmp(argv[i], m_dynamic_cmd_buffer[i]))
                      // NRF_LOG_DEBUG("Transmitting packet %02x",'payload.data[1]');
                      payload.noack=false;
                   if(m_pyload_active == 1){
                               data[0] = 0x19;
                      if (nrf_esb_write_payload(&payload) == NRF_SUCCESS){
                        NRF_LOG_DEBUG("Transmiting Successful!");
                       else {
                        NRF_LOG_WARNING("Sending packet failed");
                        NRF_LOG_FLUSH();
    static void dynamic_cmd_get(size_t idx, nrf_cli_static_entry_t * p_static)
        ASSERT(p_static);
        if (idx < m_dynamic_cmd_cnt)
            /* m_dynamic_cmd_buffer must be sorted alphabetically to ensure correct CLI completion */
            p_static->p_syntax = m_dynamic_cmd_buffer[idx];
            p_static->handler  = NULL;
            p_static->p_subcmd = NULL;
            p_static->p_help = NULL;
            /* if there are no more dynamic commands available p_syntax must be set to NULL */
            p_static->p_syntax = NULL;
    NRF_CLI_CREATE_DYNAMIC_CMD(m_sub_dynamic_set, dynamic_cmd_get);
    NRF_CLI_CMD_REGISTER(send,
                         &m_sub_dynamic_set,
                         "Demonstrate dynamic command usage.",
                         cmd_send);
    NRF_CLI_CREATE_STATIC_SUBCMD_SET(m_sub_send)
        NRF_CLI_CMD(b1, &m_sub_dynamic_set, "Execute a command.", b1),
  • First things first. Inside a command context you should not use NRF_LOG because order of displayed text may be not according to your intention. Use nrf_cli_fprintf instead.
    May you please share complete project?
  • Im afraid i cant share it Jakub. My problem solved. Thank u so much for helpfull advices.
    i used this structure and it worked.
        if ((argc == 1) || nrf_cli_help_requested(p_cli))
