Bootloader shutdown after DFU instead of resetting
Hi ,
I am using the secure bootloader example (SDK 15) as a template for my DFU solution.
I am experiencing issue with the update process as the device shuts down after the update instead of reset.
I tried to debug and saw that it reach the function bootloader_reset and run the NVIC_SystemReset function however it then shutdown.
I am using a LDO for the voltage regulation in the circuit and initially i thought that it is related however i am using an app on the board that uses the same function to reset in order to go to the bootloader and that works fine.
I verified it with the example in the SDK  without changes as well as my modified version.
Please assist as i dont have any solid lead here.
 thanks in advance,
Ibrahim
