Unable to change VDD to 1.8V
Dear all
I am currently working with a nRF52840 Dongle, the ble_app_blinky_s140 example.
To power some external circuits i have to set VDD to 1.8V.
Until now i tried the following approaches.
https://devzone.nordicsemi.com/f/nordic-q-a/20528/why-data-can-not-be-wrote-into-the-registers-of-nrf52840/80038#80038
by adding this two lines to the uicr_config.h
const uint32_t UICR_ADDR_EXTSUPPLY __attribute__((at(0x10001300))) __attribute__((used)) = 0xFFFFFFFF;//Enabled
const uint32_t UICR_ADDR_REGOUT0 __attribute__((at(0x10001304))) __attribute__((used)) = 0xFFFFFFF5;//3.3V
The second approach was to change the GPIO_OUTPUT_VOLTAGE_SETUP Function to 1.8V
None of these changed the Output Voltage.
Any idea why this doesn't work?
Regards
Marcel
  • There is no way to read the value of the register directly over the USB port, without flashing a firmware that reads the value and transmit it over USB (USB CDC/MDS examples, etc.).
    Yes, the chip can be flashed using SWD interface in case of wrong values.
    I have found a solution for this problem by adding the following functions to the main of the blinky example.
     * @brief Function to erase UICR Registers.
    void nvmcErase(void)
      if (NRF_UICR->REGOUT0 != UICR_REGOUT0_VOUT_1V8)
          NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Een << NVMC_CONFIG_WEN_Pos;        //erase enable
          while (NRF_NVMC->READY == NVMC_READY_READY_Busy){}
          NRF_NVMC->ERASEUICR = NVMC_ERASEUICR_ERASEUICR_Erase << NVMC_ERASEUICR_ERASEUICR_Pos;   //erase UICR
          NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Ren << NVMC_CONFIG_WEN_Pos;  //read only enable
     * @brief Function for configuration of REGOUT0 register.
    void vddInit(void)
    	NRF_NVMC->CONFIG = NVMC_CONFIG_WEN_Wen << NVMC_CONFIG_WEN_Pos;    //write enable
    	NRF_UICR->REGOUT0 = UICR_REGOUT0_VOUT_1V8;                        //configurate REGOUT0
            NVIC_SystemReset();                                               // Reset device
    The first function is to clear the UICR Registers. The second one then writes the UICR with the new values.
    Keep in mind to delete or uncomment the bsp_board_leds_init function in the boards.c file if you use a dongle.
    Also the LEDs will not work properly if you use the dongle with 1.8V.
    Michel
  • Hi Michel
    It worked exactly as described. I have programmed the dongle over the P1 connector on the back with a nrf5280-DK. The VDD_OUT Pin is now on 1.8V as expected.
    Thank you
  • WARNING: If you follow the suggestion from , you will erase the BOOTLOADER address from UICR and you will not be able to flash the Dongle from nRF Connect through the USB port, you will require a debugger connected to the SWD interface.
    If you want to erase the UICR in code to update a value, you should read every register in UICR and write it back after erase to make sure no data is lost. At the very least, you need to write back the BOOTLAODER address located in register NRFFW[0].
  • Hi Jorgen
    Thank you for the follow up. I have also recognized this. But as i now have the connector on the dongle this doesn't matter for me.
    Regards
    Marcel
