NRF_LOG issues
I have two strange problems regarding the NRF_LOG.
1.
In a for loop, char string that has changed is not printed out as what it contains now, it is printed out as what is contained at the first cycle of the for loop.
2.
I cannot for some reason print %04X hex values with four digits.
For some reason the log output prints some hex values eight digits long and some four digits long. This happens randomly based on the hex value itself.
I just need to print float values from the log to serial port, however it did not work directly by just with %f and other ways to get it working did not want to work well also, so I decided to go around the problem and convert the float values into strings and display the string instead.
I have this code assigned to a button, it works ok everytime I press the button:
Fullscreen
1
2
3
memset(ConvertFloat,0,sizeof(ConvertFloat));
sprintf(ConvertFloat, "%g", FloatValue);
NRF_LOG_INFO("Value : %s", ConvertFloat);
XXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXXX
The FloatValue in this code is updated all the time by another function and all is fine.
The code is for an accelerometer.
The accelerometer produces 16bit signed hex values which are put in a buffer and I want to print the buffer contents in original hex and converted float values.
The problem is that the hex values get printed ok (but changing length), and the float values get printed once and in the loop where I print out the whole buffer, the float values get stuck in one value and do not change.
When I look how the variable contents work in the debugger, I can SEE that all the float values indeed change when they are calculated from the hex values.
The code works ok and does the calculation and char conversion as expected.
The changed values ARE converted to strings ok, and the strings always change between the loop runs - but for some reason I get the wrong float value from the log output, which is not the actual value the conversion buffers really contain.
This should be impossible in my opinion.
How can a value that is confirmed changed up until log output command, be printed something else in the log?
The loop in question is:
char ConvertFloat_X[20];
char ConvertFloat_Y[20];
char ConvertFloat_Z[20];
uint16_t ValueIndex;
Fullscreen
1
2
3
4
5
6
7
8
9
10
11
12
13
14
15
16
17
18
19
20
21
for (ValueIndex = 0; ValueIndex < 468; ValueIndex = ValueIndex + 1)
Accelerometer_XYZword[0] = Data_Current[ValueIndex];
ValueIndex++;
Accelerometer_XYZword[1] = Data_Current[ValueIndex];
ValueIndex++;
Accelerometer_XYZword[2] = Data_Current[ValueIndex];
// Impact X, Y and Z 16bit word values are now read from buffer, convert to float values
// and output to serial port log.
Accelerometer_X = (float)Accelerometer_XYZword[0]*Accelerometer_Scale;
Accelerometer_Y = (float)Accelerometer_XYZword[1]*Accelerometer_Scale;
Accelerometer_Z = (float)Accelerometer_XYZword[2]*Accelerometer_Scale;
Accelerometer_X = Accelerometer_X - AccelBias[0];
Here the Data_Current buffer contains accelerometer data points in signed 16bit values in the order of X, Y, Z, X, Y, Z....
I read those values to a small array of three (Accelerometer_XYZword[]) and convert each value to their corresponding float variable Accelerometer_X/Y/Z.
Then I convert the float values to ConvertFloat_X/Y/Z char buffers.
Then I need to print the hex values and float strings in the log.
What happens is:
All hex values are randomly printed either 8 digits or 4 digits long, regardless of specifically asking only four digits long output.
I get 8 digits long output when the hex value starts with FF and four digits when it starts with zero.
The float values are printed identical in every output run, when they should change according to the corresponding hex value from which the floats are calculated and indeed do contain changed values.
Regardless of actually seeing the real values and their conversion buffers get cleared and changed before every log output - still for some reason I get only one and the same float values, when the corresponding hex value below keeps changing normally.
Can someone see an obvious problem here why this would happen?
Thanks!
