BMI160 + NRF52832 + I2C
HI,
I want to develop a program to access Accelerometer and gyroscope value from BMI160 sensor. I have used this BMI160 library
I alter the TWI_SENSOR code and it works for self testing ACC code. but i need to calibrate the x, y, z axis value and i want to add BLE stack to read in mobile app.
1. How to collect all the X,Y,Z axis value
2. i need to see the LOGS in Bluetooth app by using BLE_UART. how to edit the BLE_UART code to get the respective ACC and GYRO value in BLE APP.
Is there any code for reading X,Y,Z axis for BMI160??
  • HI,
    I am trying to get the Accel X value and gyro X value but the rslt is 0 and data also 0.
    #include <stdio.h>
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    /* Sensor */
    #include "bmi160.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    /* TWI instance ID. */
    #define TWI_INSTANCE_ID     0
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    struct bmi160_dev sensor;
    int8_t rslt = BMI160_OK;
    struct bmi160_sensor_data accel;
    struct bmi160_sensor_data gyro;
    //struct bmi160_sensor_data.gyro Gyro;
    int8_t Acc_i2c_Write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    	int8_t rslt = 0;
    	uint8_t data[len + 1];
    	data[0] = reg_addr;
    	for (uint16_t i = 0; i < len; i++) {
    		data[i + 1] = reg_data[i];
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, data, len + 1, false);
    	return rslt;
    int8_t Acc_i2c_Read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    	int8_t rslt = 0;
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, &reg_addr, 1, false);
    	nrf_delay_ms(5);
    	if (rslt == 0)
    		rslt = nrf_drv_twi_rx(&m_twi, dev_id, reg_data, len);
    	return rslt;
    void Acc_delay_ms(uint32_t period)
    	// delay time
      nrf_delay_ms( period ) ;
    } // user_delay_ms()
    void twi_init (void)
        ret_code_t err_code;
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
        nrf_drv_twi_enable(&m_twi);
    void Acc_Gyro_config(void)
    /* Select the Output data rate, range of accelerometer sensor */
        sensor.accel_cfg.odr = BMI160_ACCEL_ODR_1600HZ;
        sensor.accel_cfg.range = BMI160_ACCEL_RANGE_2G;
        sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
        /* Select the power mode of accelerometer sensor */
        sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
        /* Select the Output data rate, range of Gyroscope sensor */
        sensor.gyro_cfg.odr = BMI160_GYRO_ODR_3200HZ;
        sensor.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS;
        sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
        /* Select the power mode of Gyroscope sensor */
        sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
        /* Set the sensor configuration */
        rslt = bmi160_set_sens_conf(&sensor);
        if(rslt == BMI160_OK){
        NRF_LOG_INFO("sensor Configured... \n");
        } else {
       NRF_LOG_INFO("sensor not Configured... \n");
        NRF_LOG_FLUSH();
    void Acc_Gyro_self_test(void)
      rslt = bmi160_perform_self_test(BMI160_ACCEL_ONLY, &sensor);
              if (rslt == BMI160_OK) {
                      NRF_LOG_INFO("ACCEL SELF TEST RESULT SUCCESS \n");
              } else {
                      NRF_LOG_INFO("ACCEL SELF TEST RESULT FAIL\n");
              }NRF_LOG_FLUSH();
      rslt = bmi160_perform_self_test(BMI160_GYRO_ONLY, &sensor);
                      NRF_LOG_INFO("gyro SELF TEST RESULT SUCCESS \n");
              } else {
                      NRF_LOG_INFO("gyro SELF TEST RESULT FAIL \n");
          NRF_LOG_FLUSH();
    void BMI_mode(void)
        sensor.id = BMI160_I2C_ADDR;
        sensor.interface = BMI160_I2C_INTF;
        sensor.read = Acc_i2c_Read;
        sensor.write = Acc_i2c_Write;
        sensor.delay_ms = Acc_delay_ms;
        rslt = bmi160_init(&sensor);
        NRF_LOG_INFO("BMI160 Initialized... \n");
        } else {
        NRF_LOG_INFO("BMI160 not Initialized... \n");
        NRF_LOG_FLUSH();
        NRF_LOG_INFO("BMI160 get started.\n");
        NRF_LOG_FLUSH();
        Acc_delay_ms(1000);
        twi_init();
        Acc_delay_ms(300);
        BMI_mode();
        Acc_delay_ms(300);
        Acc_Gyro_config();
        Acc_delay_ms(300);
        Acc_Gyro_self_test();
        Acc_delay_ms(300);
        bmi160_get_sensor_data(BMI160_ACCEL_SEL, &accel, NULL, &sensor);
        NRF_LOG_INFO("x is %ld \r\n",accel.x);// accelerometer x value
        rslt = bmi160_get_sensor_data(BMI160_GYRO_SEL, NULL, &gyro, &sensor);
    	NRF_LOG_INFO("rslt:%d, data: %d", rslt,gyro.x); // gyroscope x value
        NRF_LOG_FLUSH();
  • Most likely there is some error in your TWI read function. From the datasheet, it looks like the I2C read operation does not expect a stop condition between TX and RX. Try changing the no_stop parameter of nrf_drv_twi_tx() in Acc_i2c_Read() to true instead of false.
  • Even though it won't works.
    i got link as similar error obtain but here i don't know how to apply here is the link
    https://github.com/BoschSensortec/BMI160_driver/issues/44
    in that at last it says : " I got the data from the BMI160 by enable the chip with CS. However, When I integrate the code with the BLE-uart, I kept getting zero with the right configuration..."
  • Have you checked the TWI lines with a logic analyzer to see if any data is transmitted/received?
  • No, i didn't check that. but with rslt return data only. i checked
