BMI160 + NRF52832 + I2C
HI,
I want to develop a program to access Accelerometer and gyroscope value from BMI160 sensor. I have used this BMI160 library
I alter the TWI_SENSOR code and it works for self testing ACC code. but i need to calibrate the x, y, z axis value and i want to add BLE stack to read in mobile app.
1. How to collect all the X,Y,Z axis value
2. i need to see the LOGS in Bluetooth app by using BLE_UART. how to edit the BLE_UART code to get the respective ACC and GYRO value in BLE APP.
Is there any code for reading X,Y,Z axis for BMI160??
  • You seems to be getting a Fatal Error. Have you debugged to figure out what is causing it?
  • Finally I got the Accel data
    #include <stdio.h>
    #include "boards.h"
    #include "app_error.h"
    #include "nrf_drv_twi.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #include "bmi160.h"
    /* TWI instance ID. */
    #define TWI_INSTANCE_ID     0
    /* Indicates if operation on TWI has ended. */
    static volatile bool m_xfer_done = false;
    /* TWI instance. */
    static const nrf_drv_twi_t m_twi = NRF_DRV_TWI_INSTANCE(TWI_INSTANCE_ID);
    struct bmi160_dev sensor;
    struct bmi160_sensor_data accel;
    struct bmi160_sensor_data gyro;
    int8_t rslt = BMI160_OK;
    /*TWI initialization*/
    void twi_init (void)
        ret_code_t err_code;
        const nrf_drv_twi_config_t twi_config = {
           .scl                = ARDUINO_SCL_PIN,
           .sda                = ARDUINO_SDA_PIN,
           .frequency          = NRF_DRV_TWI_FREQ_100K,
           .interrupt_priority = APP_IRQ_PRIORITY_HIGH,
           .clear_bus_init     = false
        err_code = nrf_drv_twi_init(&m_twi, &twi_config, NULL, NULL);
        if (NRF_SUCCESS == err_code)
    		nrf_drv_twi_enable(&m_twi);
    		NRF_LOG_INFO("TWI init success...");
    int8_t Acc_i2c_Write(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
        //  NRF_LOG_INFO("WRITE: dev_id: %x reg_addr: %x reg_data: %x len: %i\n", dev_id, reg_addr, *reg_data, len);
    	int8_t rslt = 0;
    	uint8_t data[len + 1];
    	data[0] = reg_addr;
    	for (uint16_t i = 0; i < len; i++) {
    		data[i + 1] = reg_data[i];
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, reg_data, len + 1, false);
    	APP_ERROR_CHECK(rslt);
            return rslt;
    int8_t Acc_i2c_Read(uint8_t dev_id, uint8_t reg_addr, uint8_t *reg_data, uint16_t len)
    	int8_t rslt = 0;
       //     NRF_LOG_INFO("READ: dev_id: %x reg_addr: %x len: %i\n", dev_id, reg_addr, len);
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, &reg_addr, 1, false);
    	if (rslt == 0)
    		rslt = nrf_drv_twi_rx(&m_twi, dev_id, reg_data, len);
        //    NRF_LOG_INFO("READ: %x",*reg_data);
    	return rslt;
    void Acc_delay_ms(uint32_t period)
    /*if (period==NULL){
    period = 1;
    }// delay time*/
      nrf_delay_ms( period ) ;
    void BMI160_init (void)
        sensor.id = BMI160_I2C_ADDR;         //0x69
        sensor.interface = BMI160_I2C_INTF;  //0x00
        sensor.read = &Acc_i2c_Read;
        sensor.write = &Acc_i2c_Write;
        sensor.delay_ms = &Acc_delay_ms;
        rslt = bmi160_init(&sensor);
        if(rslt == BMI160_OK){
        NRF_LOG_INFO("BMI160 Initialized...");
        } else {
        NRF_LOG_INFO("BMI160 not Initialized...");
        }NRF_LOG_FLUSH();
        sensor.accel_cfg.odr = BMI160_ACCEL_ODR_1600HZ;
        sensor.accel_cfg.range = BMI160_ACCEL_RANGE_2G;
        sensor.accel_cfg.bw = BMI160_ACCEL_BW_NORMAL_AVG4;
        sensor.accel_cfg.power = BMI160_ACCEL_NORMAL_MODE;
        sensor.gyro_cfg.odr = BMI160_GYRO_ODR_100HZ;
        sensor.gyro_cfg.range = BMI160_GYRO_RANGE_2000_DPS;
        sensor.gyro_cfg.bw = BMI160_GYRO_BW_NORMAL_MODE;
        sensor.gyro_cfg.power = BMI160_GYRO_NORMAL_MODE;
        rslt = bmi160_set_sens_conf(&sensor);
        NRF_LOG_INFO("sensor Configured...");
        } else {
        NRF_LOG_INFO("sensor not Configured...");
        }NRF_LOG_FLUSH();
    static void read_sensor_data()
          bmi160_get_sensor_data(BMI160_ACCEL_SEL, &accel, NULL, &sensor);
          NRF_LOG_INFO("DataX:%d", accel.x);
          NRF_LOG_INFO("DataY:%d", accel.y);
          NRF_LOG_INFO("DataZ:%d", accel.z);
        NRF_LOG_INFO("BMI160 get started.\n");
        NRF_LOG_FLUSH();
        Acc_delay_ms(100);
        twi_init();
        Acc_delay_ms(50);
        BMI160_init();
        Acc_delay_ms(100);
        while(true)
          nrf_delay_ms( 1000 ) ;
          /* do
                __WFE();
            }while (m_xfer_done == false);*/
            read_sensor_data();
            NRF_LOG_FLUSH();
    RESULT :
    <info> app: BMI160 get started.
    <info> app: TWI init success...
    <info> app: BMI160 Initialized...
    <info> app: sensor Configured...
    <info> app: DataX:-1426
    <info> app: DataY:16050
    <info> app: DataZ:5149
    <info> app: DataX:-1397
    <info> app: DataY:16203
    <info> app: DataZ:5001
    I need to show this NRF_LOG  to be print in UART  .
    how to interface BLE CONFIG
    please give tutorial to add  BLE config to print this respective data in Mobile app..
  • The simplest solution to that would be to add the libraries and drivers you use in the TWI Sensor example into the ble_app_uart example. When you get the data from the sensor, forward it over BLE using the function ble_nus_data_send, as described in the example documentation.
  • HI,
    I have insert my code in BLE_UART and all my libraries.. but I got result like some Garbage values.
    i need to print as like as NRF_LOG in BLE UART
    for example...
    if i need to print  16 bit or 8 bit  as like printf with '\r' '\n'
    ACCx - 35466
    ACCx - 23455
    here is my code
    #include <stdint.h>
    #include <string.h>
    #include "nordic_common.h"
    #include "nrf.h"
    #include "ble_hci.h"
    #include "ble_advdata.h"
    #include "ble_advertising.h"
    #include "ble_conn_params.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_soc.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_ble_qwr.h"
    #include "app_timer.h"
    #include "ble_nus.h"
    #include "app_uart.h"
    #include "bsp_btn_ble.h"
    #include "nrf_pwr_mgmt.h"
    #if defined (UART_PRESENT)
    #include "nrf_uart.h"
    #if defined (UARTE_PRESENT)
    #include "nrf_uarte.h"
    #include "bmi160.h"
    #define G_TO_LSB (16384.0f)
    #define DPS_TO_LSB (131.072f)
    #define APP_BLE_CONN_CFG_TAG            1                                           /**< A tag identifying the SoftDevice BLE configuration. */
    #define DEVICE_NAME                     "Nordic_UART"                               /**< Name of device. Will be included in the advertising data. */
    #define NUS_SERVICE_UUID_TYPE           BLE_UUID_TYPE_VENDOR_BEGIN                  /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO           3                                           /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL                64                                          /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION                18000                                       /**< The advertising duration (180 seconds) in units of 10 milliseconds. */
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(20, UNIT_1_25_MS)             /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(75, UNIT_1_25_MS)             /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(5000)                       /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(30000)                      /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF                       0xDEADBEEF                                  /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define UART_TX_BUF_SIZE                256                                         /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE                256                                         /**< UART RX buffer size. */
    /* TWI instance. */
    BLE_NUS_DEF(m_nus, NRF_SDH_BLE_TOTAL_LINK_COUNT);                                   /**< BLE NUS service instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                                           /**< GATT module instance. */
    NRF_BLE_QWR_DEF(m_qwr);                                                             /**< Context for the Queued Write module.*/
    BLE_ADVERTISING_DEF(m_advertising);                                                 /**< Advertising module instance. */
    static uint16_t   m_conn_handle          = BLE_CONN_HANDLE_INVALID;                 /**< Handle of the current connection. */
    static uint16_t   m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - 3;            /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    static ble_uuid_t m_adv_uuids[]          =                                          /**< Universally unique service identifier. */
    /**@brief Function for assert macro callback.
     * @warning This handler is an example only and does not fit a final product. You need to analyse
     * @param[in] line_num    Line number of the failing ASSERT call.
     * @param[in] p_file_name File name of the failing ASSERT call.
    /**@brief Function for initializing the timer module.
    static void timers_init(void)
     *          the device. It also sets the permissions and appearance.
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        APP_ERROR_HANDLER(nrf_error);
    /**@brief Function for handling the data from the Nordic UART Service.
     * @details This function will process the data received from the Nordic UART BLE Service and send
     *          it to the UART module.
     * @param[in] p_evt       Nordic UART Service event.
    /**@snippet [Handling the data received over BLE] */
            uint32_t err_code;
            for (uint32_t i = 0; i < p_evt->params.rx_data.length; i++)
                do
                    err_code = app_uart_put(p_evt->params.rx_data.p_data[i]);
                    if ((err_code != NRF_SUCCESS) && (err_code != NRF_ERROR_BUSY))
                        NRF_LOG_ERROR("Failed receiving NUS message. Error 0x%x. ", err_code);
                } while (err_code == NRF_ERROR_BUSY);
            if (p_evt->params.rx_data.p_data[p_evt->params.rx_data.length - 1] == '\r')
                while (app_uart_put('\n') == NRF_ERROR_BUSY);
        uint32_t           err_code;
        ble_nus_init_t     nus_init;
        // Initialize NUS.
    /**@brief Function for handling an event from the Connection Parameters Module.
     * @details This function will be called for all events in the Connection Parameters Module
     *          which are passed to the application.
     * @note All this function does is to disconnect. This could have been done by simply setting
     *       the disconnect_on_fail config parameter, but instead we use the event handler
     *       mechanism to demonstrate its use.
        uint32_t err_code;
    /**@brief Function for handling errors from the Connection Parameters module.
        // Prepare wakeup buttons.
        uint32_t err_code;
        switch (ble_adv_evt)
            case BLE_ADV_EVT_FAST:
            case BLE_ADV_EVT_IDLE:
                sleep_mode_enter();
        uint32_t err_code;
            case BLE_GAP_EVT_CONNECTED:
                NRF_LOG_INFO("Connected");
                NRF_LOG_INFO("Disconnected");
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
                // Pairing not supported
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
                // No implementation needed.
    /**@brief Function for the SoftDevice initialization.
     * @details This function initializes the SoftDevice and the BLE event interrupt.
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if ((m_conn_handle == p_evt->conn_handle) && (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED))
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Data len is set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
        NRF_LOG_DEBUG("ATT MTU exchange completed. central 0x%x peripheral 0x%x",
                      p_gatt->att_mtu_desired_central,
                      p_gatt->att_mtu_desired_periph);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_periph_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in]   event   Event generated by button press.
        uint32_t err_code;
        switch (event)
            case BSP_EVENT_SLEEP:
                sleep_mode_enter();
            case BSP_EVENT_DISCONNECT:
                err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
            case BSP_EVENT_WHITELIST_OFF:
     *          a string. The string will be be sent over BLE when the last character received was a
     *          'new line' '\n' (hex 0x0A) or if the string has reached the maximum data length.
    /**@snippet [Handling the data received over UART] */
        static uint8_t index = 0;
        uint32_t       err_code;
        switch (p_event->evt_type)
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') ||
                    (data_array[index - 1] == '\r') ||
                    (index >= m_ble_nus_max_data_len))
                    if (index > 1)
                        do
                        } while (err_code == NRF_ERROR_RESOURCES);
                    index = 0;
            case APP_UART_FIFO_ERROR:
    /**@brief  Function for initializing the UART module.
    /**@snippet [UART Initialization] */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = NRF_UART_BAUDRATE_115200
    #else
            .baud_rate    = NRF_UARTE_BAUDRATE_115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
        ble_advertising_init_t init;
        init.advdata.name_type          = BLE_ADVDATA_FULL_NAME;
        init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
        init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
        bsp_event_t startup_event;
        uint32_t err_code = bsp_init(BSP_INIT_LEDS | BSP_INIT_BUTTONS, bsp_event_handler);
    static void log_init(void)
        UNUSED_RETURN_VALUE(NRF_LOG_PROCESS());
        nrf_pwr_mgmt_run();
    	int8_t rslt = 0;
    	data[0] = reg_addr;
    	rslt = nrf_drv_twi_tx(&m_twi, dev_id, data, len + 1, false);
            return rslt;
    	int8_t rslt = 0;
    	if (rslt == 0)
    	return rslt;
    period = 1;
    }// delay time*/
        } else {
        }//NRF_LOG_FLUSH();
        sensor.gyro_cfg.odr = BMI160_GYRO_ODR_3200HZ;
        } else {
        }//NRF_LOG_FLUSH();
          uint16_t data_array1;
          int length1 = 2;
          data_array1 = accel.x;
           //err_code = ble_mpu_update(&m_mpu, &accel_values);
          //              APP_ERROR_CHECK(err_code);
          rslt = ble_nus_data_send(&m_nus, &data_array1, &length1, m_conn_handle);
          bmi160_get_sensor_data((BMI160_ACCEL_SEL | BMI160_GYRO_SEL | BMI160_TIME_SEL), &accel, &gyro, &sensor);
          NRF_LOG_INFO("GyroX:%d", gyro.x);
          NRF_LOG_INFO("GyroY:%d", gyro.y);
          NRF_LOG_INFO("GyroZ:%d", gyro.z);
    /**@brief Application main function.
        bool erase_bonds;
         uint8_t sample_data[10];
        // Initialize.
        uart_init();
        log_init();
        timers_init();
        power_management_init();
        ble_stack_init();
        gap_params_init();
        gatt_init();
        services_init();
        advertising_init();
        conn_params_init();
        // Start execution.
        NRF_LOG_INFO("BMI160 getstarted...");
        advertising_start();
        Acc_delay_ms(100);
        twi_init();
        Acc_delay_ms(50);
        BMI160_init();
        Acc_delay_ms(100);
        // Enter main loop.
        for (;;)
            idle_state_handle();
            read_sensor_data();
            NRF_LOG_FLUSH();
        //    nrf_delay_ms( 100 ) ;
       //     sample_data[0] = 0x20;
       //     sample_data[1] = 0x21;
       //     nrf_drv_twi_tx(&m_twi, 0x69, sample_data, 2, false);
       //     nrf_drv_twi_rx(&m_twi, 0x69, sample_data, 2);
          //  NRF_LOG_INFO("Temperature:" NRF_LOG_FLOAT_MARKER,
          //  NRF_LOG_FLOAT((((sample_data[1]<<8|sample_data[0])*0.001953125)+23.0)));
          //  NRF_LOG_FLUSH();
         //   nrf_delay_ms( 300 ) ;
        //    float accelX = ((((float)accel.x) / G_TO_LSB) * 9.80655); // in m/s^2
        //    float gyrX = ((((float)gyro.x) / DPS_TO_LSB) * 0.0174532925); // in rad/sec
        //    NRF_LOG_INFO("DataX in m/s^2   : " NRF_LOG_FLOAT_MARKER,
       //     NRF_LOG_FLOAT( accelX));
       //     NRF_LOG_INFO("DataY in rad/sec : " NRF_LOG_FLOAT_MARKER,
       //     NRF_LOG_FLOAT(gyrX));
           // NRF_LOG_FLUSH();
    the output which i get is
