Buttonless Secure DFU - Preparing for Production
I am porting an application with buttonless DFU from SDK 14.2 to SDK 15.2 to target nRF52840 and in the process working to prepare the code for production.
After some effort to get the environment set up correctly (I initially missed the compile time pre-processor configuration for enabling NRF_DFU in the SES project, which created some very cyptic macro errors - not sure why the DFU config is not included in sdk_config like everything else!!) it is working and I managed to flash new firmware OTA with our application on SDK 15.2.
However, the skeleton code in the buttonless DFU template is sparsely documented and I would appreciate assistance with the following questions:
  1. What is the purpose of the buttonless_dfu_sdh_state_observer function? What drives the need to enter system off here?
  2. In app_shutdown_handler -> NRF_PWR_MGMT_EVT_PREPARE_DFU there is code (but commented out) that would disable the softdevice and stop the application timers. Is this required and if so why given the system is about to be reset to enter DFU?
I would also appreciate any additional advice on best practice to "productionise" the DFU process beyond the skeleton code in the SDK, for example:
  1. It it usual to change the name advertised by the bootloader to be application specific or leave it as the generic DfuTarg in production?
  2. What is the correct way to handle the situation where a device gets stuck in DFU mode (e.g. due to link loss part way through an update)? How does our central (smartphone application) identify the device and recover it to a working state?
  3. Our application is bonded but at present we are doing open DFU. Is this a common approach and if so are there any security risks when doing secure DFU without bonding?
  4. Is it recommended to use the same private key for signing firmware to all devices or should each device be coded with an individual key? If so how can the key in the bootloader be set without needing to recompile each time?
  5. Any other security/logistics considerations around the DFU process we should be aware of before entering production?
All advice gratefully received!
