Going low power in freertos app
I have an app based on freertos_hrs example (nRF52832, SDK14.2)
I'm trying to get it into low power(sleep) mode, however the idle task keep on running and the system consumes ~4.5mA constantly (ble is off most of the time)
I tried the following:
  • Setting #define configUSE_TICKLESS_IDLE   1 in freeRTOSConfig.h but is does not seem to help.
  • Disabled NRF_Log options in sdk_config.h as several posts suggested
  • Verified that none of my app's tasks is running (All are blocked), neither is the timer task. The only task that seem to run is the idle task.
  • Verified that the idle task handler portTASK_FUNCTION() (part of freertos port) do get to the line portSUPPRESS_TICKS_AND_SLEEP() that eventually calls sd_app_evt_wait()
  • I tried to forcefully call sd_app_evt_wait() from within  the applications idle hook (vApplicationIdleHook(), #define configUSE_IDLE_HOOK  1)
    It does lower the consumed power to few uA, but I keep getting hard faults when ble activity is encountered (not sure exactly what is the cause) - e.g. advertising goes well but when connection is established ble_evt_handler() crashes in case BLE_GAP_EVT_CONNECTED block
Reading the doc it seems that implementing the 1st bullet above should take care of lowering the power but apparently something else is not set correctly.
Any help will be highly appreciated
Thanks in advance
  • For me it looks like
    0x02002801 are
    0- POWER/CLOCK,
    11 - RTC0
    13 RNG
    25 SWI5
    all of which should owned by softdevice.
    I am sorry, there is a flaw in my suggestion, if your application has any higher priority interrupt that is waking your system then our breakpoint here will not work as that interrupt will already have been serviced by the time your breakpoint is hit.
    Can you start by looking at NVIC->ISER[0] bit to see which application interrupts are enabled and start by  disabling those interrupts from your application at the peripheral level. I mean you need to disable that application interrupt inside the peripheral module that is generating that interrupt (NRF_XXX->INTENCLR) and leave it as it is in NVIC. This way we disable the interrupt at the source one by one to see which interrupt is causing your system to wake that frequently.
  • Hi Susheel
    I've done some 'binary search', deactivarting increasing pieces of my code, eventually I've found that the problems lies with the 'ble related' functionality - specifically softdevice_task.
    When the full app is running, the idle task hook is called every ~23us (~43KHz) (its only toggling a pin for debug) even if there's no ble activity (advertising/connection)
    void vApplicationIdleHook( void )
    	static uint32_t cnt = 0;
    	static TickType_t ticks = 0;
    //#if NRF_LOG_ENABLED
    //        NRF_LOG_FLUSH();
    //#endif
    //	(void) sd_app_evt_wait();
    //	do{
    //		__WFE();
    //	} while (0 == (NVIC->ISPR[0] | NVIC->ISPR[1]));
    	nrf_gpio_pin_set(BSP_TP1);
    	nrf_gpio_pin_clear(BSP_TP1);
    	cnt++;
    	ticks = xTaskGetTickCount();
    When 'ble stuff' (below) is left out, the idle task hook does not run at all (app's 4 tasks are blocked and so is the idle task and timer task)
    #define BLE_DISABLE
    #ifndef BLE_DISABLE
        ble_stack_init();
        // Initialize modules.
    	buttons_leds_init();
    #ifndef BLE_DISABLE
    	timers_init();
        gap_params_init();
        gatt_init();
        services_init();	// services_init() preceeds advertising_init() as it defines vendor speciic uuid that is used in
        advertising_init();
        conn_params_init();
        // Create a FreeRTOS task for the BLE stack.
        // The task will run advertising_start() before entering its loop.
        //nrf_sdh_freertos_init(advertising_start, &erase_bonds);	// don't erase bonds
    	nrf_sdh_freertos_init(NULL, NULL);	// don't start with advertising
        // Start FreeRTOS scheduler.
        vTaskStartScheduler();
        while (true)
            APP_ERROR_HANDLER(NRF_ERROR_FORBIDDEN);
    I'm using sdk 14.2 on nRF52832
    What can be the reason for that ?
  • I am guessing that since nothing is expected to happen, the wakeup time is programmed to be large and there is absolutely no activity on your chip when you define BLE_DISABLE and the chip does not wake up from __WFE
  • you are correct.
    When I define BLE_DISABLE idle task hook is not being called (as expected).
    The problem occurs when the BLE stack is initialized - ble_stack_init() and softdevice task is created - nrf_sdh_freertos_init(), then the idle task hook is constantly been called every ~23us....
  • something is weird with application idle hook here, but can you not use application idle hook and toggle the pin after the system wakes up in vPortSuppressTicksAndSleep?
    make sure you disable application idle hook in FreeRTOSConfig.h file
