Dimming Example Client on nRF52840 DK not detected by nRF Mesh Provisioning App.
An nRF5 SDK for Mesh v2.2.0 dimming example client running on a nRF52840 Preview DK is not detected for provisioning by a nRF Mesh smartphone provisioner.
Running the example in debuger delivers the following output on startup:
<t:          0>, main.c,  353, ----- BLE Mesh Light Switch Client Demo -----
<t:          0>, mesh_softdevice_init.c,  117, Initializing SoftDevice...
<t:          0>, mesh_softdevice_init.c,   75, Enabling BLE...
<t:         16>, mesh_softdevice_init.c,  109, sd_ble_enable: app_ram_base should be adjusted to 0x20002DA0
<t:        479>, main.c,  320, Initializing and adding models
<t:       5328>, main.c,  385, Device UUID : 0059CCBB0000000050B5B3E4BD11F856
  • Thank you for your tip, but it does not solve the issue unfortunately.
  • Do you mean it doesn't get rid of the message?
    Or getting rid of the message doesn't fix the issue of not being detected?
  • The message still exists and the issue not being detected is still there.
    I guess the instructions in the given links are not correct. However, I found the correct place in SEGGER IDE where to set the "app_ram_base" to the required value 0x20002DA0. it is here:
    Now the warning message has disappeared.
    However, the issue of not being detected is still there!
    What is besides quite confusing in this example is the following:
    According to the examples description it is possible to "Instead of using a provisioner board, you can also use the nRF Mesh app:". However, in code nrf_mesh_config_core.h there are following definitions:
    /** GATT feature, should only be enabled in combination with linking GATT files. */
    #ifndef MESH_FEATURE_GATT
    #define MESH_FEATURE_GATT 0
    /** GATT proxy feature, should only be enabled in combination with linking GATT proxy files. */
    #ifndef GATT_PROXY
    #define GATT_PROXY 0
    Which means, provisioning via nRF Mesh App is not supported as this would require GATT Proxy feature.
  • Update 2: Below is the preprocessor definition for the light switch proxy client example. If you compare that with the experimental dimming client preprocessor definition, you notice that MESH_FEATURE_GATT=1 & GATT_PROXY=1 are missing (which you correctly pointed out).
    As you have correctly pointed out, MESH_FEATURE_GATT & GATT_PROXY are not defined in the dimming example.
    Once these preprocessor definitions are defined, it can be helpful to close the Segger project & open it up again. That way, the sections that were uncommented under #if MESH_FEATURE_GATT should not be grayed out anymore.
    I had to add the following files:
    nrf_sdh.c into the Others folder. The c file can be found here:
    nrf5_SDK_for_Mesh_v2.2.0_src\external\sdk_fix
    I also added nrf_sdh_ble.c from (added it to the nRF5 SDK folder):
    nRF5_SDK_15.0.0_a53641a\components\softdevice\common
    I also added the ble_conn_params.c folder from:
    nRF5_SDK_15.0.0_a53641a\components\ble\common
    The ble_srv_common.c was also added to nRF5 SDK (path: nRF5_SDK_15.0.0_a53641a\components\ble\common)
    Also add ble_advdata.c (path: C:\NordicSemi\SDKs\nRF5_SDK_15.0.0_a53641a\components\ble\common)
    I then also added the following c files to a new GATT folder (proxy_filter.c, mesh_gatt.c & proxy.c). The files can be found here:
    nrf5_SDK_for_Mesh_v2.2.0_src\mesh\gatt\src
    I also added nrf_mesh_prov_bearer_gatt.c into the Provisioning folder (see path: nrf5_SDK_for_Mesh_v2.2.0_src\mesh\prov\src)
    nrf_section_iter.c was added into the nRF5 SDK folder (path: nRF5_SDK_15.0.0_a53641a\components\libraries\experimental_section_vars)
    mesh_adv.c was added into the Application folder (path: nrf5_SDK_for_Mesh_v2.2.0_src\examples\common\src)
    Then, I had to add the following header files & make the code changes below:
    In main.c:
    added following defines after APP_UNACK_MSG_REPEAT_COUNT (2):
    #define DEVICE_NAME                     "nRF5x Mesh Switch"
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(150,  UNIT_1_25_MS)           /**< Minimum acceptable connection interval. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(250,  UNIT_1_25_MS)           /**< Maximum acceptable connection interval. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(100)                        /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called. */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(2000)                       /**< Time between each call to sd_ble_gap_conn_param_update after the first call. */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    static void gap_params_init(void);
    static void conn_params_init(void);
    added header files under Core comment in main.c:
    #include "mesh_adv.h" // added by BK
    #include "nrf_sdh.h" // added by BK
    #include "ble_conn_params.h" // added by BK
    #include "proxy.h" // added by BK
    added gap_params_init() & conn_params_init() right below mesh_init():
    static void gap_params_init(void) // added by BK
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        ble_gap_conn_params_t  gap_conn_params;
        cp_init.p_conn_params                  = &gap_conn_params;
    added on_conn_params_evt() & conn_params_error_handler() below models_init_cb in main.c
        uint32_t err_code;
            err_code = sd_ble_gap_disconnect(p_evt->conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
        else if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_SUCCEEDED)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully updated connection parameters\n");
        APP_ERROR_HANDLER(nrf_error);
    In app_config.h, I added the following lines under
    /** Override default sdk_config.h values. */
    C:\NordicSemi\SDKs\nRF5_SDK_15.0.0_a53641a\components\libraries\experimental_log\src\nrf_log_internal.h
    In the preprocessor definitions, I had to add the following lines:
    $(SDK_ROOT:../../../../nRF5_SDK_15.0.0_a53641a)/components/softdevice/common
    $(SDK_ROOT:../../../../nRF5_SDK_15.0.0_a53641a)/components/libraries/experimental_log
    $(SDK_ROOT:../../../../nRF5_SDK_15.0.0_a53641a)/components/libraries/experimental_log/src
    $(SDK_ROOT:../../../../nRF5_SDK_15.0.0_a53641a)/components/libraries/strerror
    $(SDK_ROOT:../../../../nRF5_SDK_15.0.0_a53641a)/components/ble/common
    $(SDK_ROOT:../../../../nRF5_SDK_15.0.0_a53641a)/components/libraries/atomic
    In nrf_sdh.c, I also commented out this code:
    //void SD_EVT_IRQHandler(void)
    // nrf_sdh_evts_poll();
    Summary: As you can see, quite a few changes were made to integrate the proxy functionality into this example.
    I have gotten the experimental dimming example to build correctly, but unfortunately there is still an issue with identifying the different elements & other parameters when testing with the nRF Mesh for iOS app. There is a similar issue for Android. I have not figured this out yet, but will continue looking at the issue.
    I would recommend making the same changes that I made & try to figure out what the issue could be yourself too.
    Update: The below info is wrong. Embarrassingly enough I provisioned someone elses DK, while I thought it was mine. You are correct that proxy & gatt is not enabled. This issue has been reported internally a week or so ago & should make it out into the next mesh release. I will take a closer look & get back to you on a fix for sdk v2.2.0.
    Wrong Info Here:
    I have just tested this example with mesh sdk v2.2.0 & the nRF Mesh app for iOS & I was able to provision & configure the experimental dimming client example successfully. I did not make any changes to the regular example.
    Did you set the Mesh SDK & nRF5 SDK paths (i.e. SDK_ROOT & MESH_ROOT) correctly in Tools -> Options -> Building -> Global Macros.
    Are you using nRF Mesh for Android? What phone are you using? Have you tried clearing the Bluetooth cache (turn Bluetooth off for 10 seconds or so & then turn Bluetooth back on) before trying to provision via nRF Mesh?
    I am also using Segger Embedded Studio v3.40.
    Kind Regards,
    Bjørn
  • Ok, so I'm looking forward to hear from you for a fix for SDK v2.2.0.
    Thank you for your support.
