No communication after Port from Mesh-SDK 2.0.0 to Mesh-SDK 2.2.0
Dear Nordic-Support,
I have implemented some functionality with user defined models on the Mesh2.0.0-SDK. I had implemented both sides (server-client) and i,plemented the provisioning. All the implemnetation seems to work fine (some data loss in the communication occured occasionaly). Now I wanted to switch to the new SDK(2.2.0) I wanted to check if the reliability would be better on the newest SDK, but I have no communication on the 2.2.0-SDK. I have just taken my application and coiped it over, so there is no change in the models. Also the node_setup.c in the provisioner is taken from the old 2.0.0 SDK. After provisoning with the SDK 2.2.0 there is no error during the provisioning itself. I made some debugging, there are no errors on the 'sending' side, on the receiving side the data could be seen, here my debug add in the function access_incoming_handle:
/* ********** Private API ********** */
void access_incoming_handle(const access_message_rx_t * p_message)
    const nrf_mesh_address_t * p_dst = &p_message->meta_data.dst;
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "RxED opcode: 0x%04x\n", p_message->opcode);
    if (dsm_address_is_rx(p_dst))
        uint16_t element_index;
        dsm_handle_t address_handle = DSM_HANDLE_INVALID;
        bool is_element_message = is_element_rx_address(p_dst, &element_index);
        if (!is_element_message)
            /* If it's not one of the element addresses, it has to be a subscription address. */
            NRF_MESH_ERROR_CHECK(dsm_address_handle_get(p_dst, &address_handle));
        for (int i = 0; i < ACCESS_MODEL_COUNT; ++i)
            access_common_t * p_model = &m_model_pool[i];
            uint32_t opcode_index;
            bool address_match =
              (is_element_message ? (p_model->model_info.element_index == element_index)
                                  : (model_subscribes_to_addr(p_model, address_handle)));
            if (ACCESS_INTERNAL_STATE_IS_ALLOCATED(p_model->internal_state) &&
                address_match &&
                bitfield_get(p_model->model_info.application_keys_bitfield, p_message->meta_data.appkey_handle) &&
                is_opcode_of_model(p_model, p_message->opcode, &opcode_index))
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Rx found\n");
                if (p_dst->type == NRF_MESH_ADDRESS_TYPE_UNICAST)
                   access_reliable_message_rx_cb(i, p_message, p_model->p_args);
                 p_model->p_opcode_handlers[opcode_index].handler(i, p_message, p_model->p_args);
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "No Acc, match %u model opcode %u bitfield get %u is element msg %u manuf: 0x%04x, modelid 0x%04x\n",
                      address_match,
                      is_opcode_of_model(p_model, p_message->opcode, &opcode_index),
                      bitfield_get(p_model->model_info.application_keys_bitfield, p_message->meta_data.appkey_handle),
                      is_element_message,
                      p_model->model_info.model_id.company_id,
                      p_model->model_info.model_id.model_id);
Here my output corresponding to the printf in the code above:
<t: 973811>, access.c,  940, RxED opcode: 0xFFFF0052
<t: 973814>, access.c,  983, No Acc, match 0 model opcode 0 bitfield get 0 is element msg 0 manuf: 0xFFFF, modelid 0x0000
<t: 973819>, access.c,  983, No Acc, match 0 model opcode 0 bitfield get 0 is element msg 0 manuf: 0xFFFF, modelid 0x0002
<t: 973824>, access.c,  983, No Acc, match 0 model opcode 0 bitfield get 0 is element msg 0 manuf: 0xFFFF, modelid 0x1000
<t: 973829>, access.c,  983, No Acc, match 0 model opcode 0 bitfield get 0 is element msg 0 manuf: 0xFFFF, modelid 0x1002
<t: 973834>, access.c,  983, No Acc, match 1 model opcode 0 bitfield get 0 is element msg 0 manuf: 0xFFFF, modelid 0x1100
<t: 973838>, access.c,  983, No Acc, match 0 model opcode 1 bitfield get 1 is element msg 0 manuf: 0xFFFF, modelid 0x1102
<t: 973843>, access.c,  983, No Acc, match 0 model opcode 0 bitfield get 0 is element msg 0 manuf: 0xFFFF, modelid 0x1013
It looks like the adress match occour on the wrong model. As I said it was working on the SDK 2.0.0. What has changed between them?
Tell me please if I should send more details.
Best regards:
Roland
