nRF52840 wireless mesh network set up
Hi, all. I am in need of serious help. I need to set up a wireless mesh network using the nRF52840 SoC. It must have 9 nodes and be capable of multi-hopping. I need to set up the mesh in a building with obstacles and  each nodes may need to relay packets to other nodes to help with the communications. I also need help with logging the latency and packet delivery ratios. Is it possible to detect the dynamic routing within the mesh?  I am only a beginner and i have done the examples successfully but i simply cannot do the mesh-it seems out of my league for now and so i need help. I have even gone through the You Tube videos but they have no code and mostly show only the 'blinky examples'. Please help. I tried  to contact other developers on the forum who wanted the same solutions but they have not responded and so i decided to contact the general community. Thank you in advance.
P.S. I am new to this and so please be more plain in your explanations.
  • Use the Quick start guide to run the mesh first , then the pyaci and then do the examples yourself (links are in my previous post)
  • Done. I have ran through the dimming examples and using RTT viewer i was able to connect to each one of the nodes in succession and send 0/1 to turn on and off  LED1. How do i constantly turn on/off the LED?
  • Have you done the pyACI / serial , they should allow python script control for the Mesh Models so you can send on and off commands in a more programmable fashion.
  • Hi
    For range and other tests i also need a permanent on and off toggle so i modified the proxy_client code a little bit.
    I make a copy of the proxy_client folder, rename the folder proxy_client_toggle and add to main.c some app_timer code. The timer handler is executed every 2000ms. The Handler call the same method what the button event handler is doing to switch on and off the server(s).
    See my_test1_timeout_handler(...) in attached main.c file.
    ....\nrf5_SDK_for_Mesh\examples\light_switch\proxy_client_toggle\src
    /* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
     // Toggle on and off every 2000ms
     // search for Modified ....
    #include <stdint.h>
    #include <string.h>
    /* HAL */
    #include "boards.h"
    #include "simple_hal.h"
    #include "app_timer.h"
    /* Core */
    #include "nrf_mesh_configure.h"
    #include "nrf_mesh.h"
    #include "mesh_stack.h"
    #include "device_state_manager.h"
    #include "access_config.h"
    #include "sdk_config.h"
    #include "mesh_adv.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "ble_conn_params.h"
    #include "ble_hci.h"
    #include "proxy.h"
    /* Provisioning and configuration */
    #include "mesh_provisionee.h"
    #include "mesh_app_utils.h"
    #include "mesh_softdevice_init.h"
    /* Models */
    #include "generic_onoff_client.h"
    /* Logging and RTT */
    #include "log.h"
    #include "rtt_input.h"
    /* Example specific includes */
    #include "app_config.h"
    #include "nrf_mesh_config_examples.h"
    #include "light_switch_example_common.h"
    #include "example_common.h"
    #define APP_STATE_OFF                (0)
    #define APP_STATE_ON                 (1)
    #define APP_UNACK_MSG_REPEAT_COUNT   (2)
    #define DEVICE_NAME                     "nRF5x Mesh Switch"
    #define MIN_CONN_INTERVAL               MSEC_TO_UNITS(150,  UNIT_1_25_MS)           /**< Minimum acceptable connection interval. */
    #define MAX_CONN_INTERVAL               MSEC_TO_UNITS(250,  UNIT_1_25_MS)           /**< Maximum acceptable connection interval. */
    #define SLAVE_LATENCY                   0                                           /**< Slave latency. */
    #define CONN_SUP_TIMEOUT                MSEC_TO_UNITS(4000, UNIT_10_MS)             /**< Connection supervisory timeout (4 seconds). */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY  APP_TIMER_TICKS(100)                        /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called. */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY   APP_TIMER_TICKS(2000)                       /**< Time between each call to sd_ble_gap_conn_param_update after the first call. */
    #define MAX_CONN_PARAMS_UPDATE_COUNT    3                                           /**< Number of attempts before giving up the connection parameter negotiation. */
    // Modified
    #define my_test1_cycle_ms         2000
    APP_TIMER_DEF(m_my_test1_timer);
    /* Forward declaration */
    static void gap_params_init(void);
    static void conn_params_init(void);
    static void on_sd_evt(uint32_t sd_evt, void * p_context)
        (void) nrf_mesh_on_sd_evt(sd_evt);
    NRF_SDH_SOC_OBSERVER(mesh_observer, NRF_SDH_BLE_STACK_OBSERVER_PRIO, on_sd_evt, NULL);
    static generic_onoff_client_t m_clients[CLIENT_MODEL_INSTANCE_COUNT];
    static bool                   m_device_provisioned;
    static void app_gen_onoff_client_publish_interval_cb(access_model_handle_t handle, void * p_self);
    static void app_generic_onoff_client_status_cb(const generic_onoff_client_t * p_self,
                                                   const access_message_rx_meta_t * p_meta,
                                                   const generic_onoff_status_params_t * p_in);
    static void app_gen_onoff_client_transaction_status_cb(access_model_handle_t model_handle,
                                                           void * p_args,
                                                           access_reliable_status_t status);
    const generic_onoff_client_callbacks_t client_cbs =
        .onoff_status_cb = app_generic_onoff_client_status_cb,
        .ack_transaction_status_cb = app_gen_onoff_client_transaction_status_cb,
        .periodic_publish_cb = app_gen_onoff_client_publish_interval_cb
    static void provisioning_complete_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
        /* Restores the application parameters after switching from the Provisioning service to the Proxy  */
        gap_params_init();
        conn_params_init();
        dsm_local_unicast_address_t node_address;
        dsm_local_unicast_addresses_get(&node_address);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
        hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
    /* This callback is called periodically if model is configured for periodic publishing */
         __LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Publish desired message here.\n");
    /* Acknowledged transaction status callback, if acknowledged transfer fails, application can
    * determine suitable course of action (e.g. re-initiate previous transaction) by using this
    * callback.
                                                           void * p_args,
        switch(status)
            case ACCESS_RELIABLE_TRANSFER_SUCCESS:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer success.\n");
            case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
                hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer timeout.\n");
            case ACCESS_RELIABLE_TRANSFER_CANCELLED:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer cancelled.\n");
                ERROR_CHECK(NRF_ERROR_INTERNAL);
    /* Generic OnOff client model interface: Process the received status message in this callback */
        if (p_in->remaining_time_ms > 0)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d, Target OnOff: %d, Remaining Time: %d ms\n",
                  p_meta->src.value, p_in->present_on_off, p_in->target_on_off, p_in->remaining_time_ms);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d\n",
                  p_meta->src.value, p_in->present_on_off);
    static void node_reset(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
        /* This function may return if there are ongoing flash operations. */
        mesh_stack_device_reset();
    static void config_server_evt_cb(const config_server_evt_t * p_evt)
        if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
            node_reset();
    static void button_event_handler(uint32_t button_number)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        uint32_t status = NRF_SUCCESS;
        generic_onoff_set_params_t set_params;
        model_transition_t transition_params;
        static uint8_t tid = 0;
    	 * Button 1: ON, Button 2: Off, Client[0]
         * Button 2: ON, Button 3: Off, Client[1]
        switch(button_number)
            case 0:
            case 2:
                set_params.on_off = APP_STATE_ON;
            case 1:
            case 3:
                set_params.on_off = APP_STATE_OFF;
        set_params.tid = tid++;
        transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;
        transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: ONOFF SET %d\n", set_params.on_off);
        switch (button_number)
            case 0:
            case 1:
                /* Demonstrate acknowledged transaction, using 1st client model instance */
                /* In this examples, users will not be blocked if the model is busy */
                (void)access_model_reliable_cancel(m_clients[0].model_handle);
                status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
                hal_led_pin_set(BSP_LED_0, set_params.on_off);
            case 2:
            case 3:
                /* Demonstrate un-acknowledged transaction, using 2nd client model instance */
                status = generic_onoff_client_set_unack(&m_clients[1], &set_params,
                                                        &transition_params, APP_UNACK_MSG_REPEAT_COUNT);
                hal_led_pin_set(BSP_LED_1, set_params.on_off);
        switch (status)
            case NRF_SUCCESS:
            case NRF_ERROR_NO_MEM:
            case NRF_ERROR_BUSY:
            case NRF_ERROR_INVALID_STATE:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Client %u cannot send\n", button_number);
            case NRF_ERROR_INVALID_PARAM:
                /* Publication not enabled for this client. One (or more) of the following is wrong:
                 * - An application key is missing, or there is no application key bound to the model
                 * - The client does not have its publication state set
                 * It is the provisioner that adds an application key, binds it to the model and sets
                 * the model's publication state.
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Publication not configured for client %u\n", button_number);
                ERROR_CHECK(status);
    static void rtt_input_handler(int key)
        if (key >= '0' && key <= '3')
            uint32_t button_number = key - '0';
            button_event_handler(button_number);
    // Modified
    // Permanent toggle test
    bool last_send_light_state = false;
    static void my_test1_timeout_handler(void * p_context)
      // button 0 = on
      // button 1 = off
      if (last_send_light_state == false) {
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "\nmy_test1_timeout_handler send ON\n");
        button_event_handler(0);
        last_send_light_state = true;
      } else {
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "\nmy_test1_timeout_handler send OFF\n");
        button_event_handler(1);
    static void models_init_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
        for (uint32_t i = 0; i < CLIENT_MODEL_INSTANCE_COUNT; ++i)
            m_clients[i].settings.p_callbacks = &client_cbs;
            m_clients[i].settings.timeout = 0;
            m_clients[i].settings.force_segmented = APP_CONFIG_FORCE_SEGMENTATION;
            m_clients[i].settings.transmic_size = APP_CONFIG_MIC_SIZE;
            ERROR_CHECK(generic_onoff_client_init(&m_clients[i], i + 1));
        uint32_t err_code;
            err_code = sd_ble_gap_disconnect(p_evt->conn_handle, BLE_HCI_CONN_INTERVAL_UNACCEPTABLE);
        else if (p_evt->evt_type == BLE_CONN_PARAMS_EVT_SUCCEEDED)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully updated connection parameters\n");
        APP_ERROR_HANDLER(nrf_error);
    static void mesh_init(void)
        uint8_t dev_uuid[NRF_MESH_UUID_SIZE];
        uint8_t node_uuid_prefix[NODE_UUID_PREFIX_LEN] = CLIENT_NODE_UUID_PREFIX;
        ERROR_CHECK(mesh_app_uuid_gen(dev_uuid, node_uuid_prefix, NODE_UUID_PREFIX_LEN));
        mesh_stack_init_params_t init_params =
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .core.p_uuid             = dev_uuid,
            .models.models_init_cb   = models_init_cb,
            .models.config_server_cb = config_server_evt_cb
        ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
        uint32_t                err_code;
                                              strlen(DEVICE_NAME));
        ble_gap_conn_params_t  gap_conn_params;
        cp_init.p_conn_params                  = &gap_conn_params;
    static void initialize(void)
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS, LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Light Switch Client Demo -----\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ERROR_CHECK(hal_buttons_init(button_event_handler));
        uint32_t err_code = nrf_sdh_enable_request();
    #if defined S140 // todo remove that after S140 priority fixing
        softdevice_irq_priority_checker();
        uint32_t ram_start = 0;
        /* Set the default configuration (as defined through sdk_config.h). */
        err_code = nrf_sdh_ble_default_cfg_set(MESH_SOFTDEVICE_CONN_CFG_TAG, &ram_start);
        gap_params_init();
        conn_params_init();
        mesh_init();
    static void start(void)
        rtt_input_enable(rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        ERROR_CHECK(mesh_stack_start());
        if (!m_device_provisioned)
            static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
            mesh_provisionee_start_params_t prov_start_params =
                .p_static_data    = static_auth_data,
                .prov_complete_cb = provisioning_complete_cb,
                .p_device_uri = NULL
            ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
        const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
        __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
        initialize();
        // Modified
         APP_ERROR_CHECK(app_timer_create(&m_my_test1_timer, APP_TIMER_MODE_REPEATED, my_test1_timeout_handler));
        execution_start(start);
        // Modified
        APP_ERROR_CHECK(app_timer_start(m_my_test1_timer, APP_TIMER_TICKS(my_test1_cycle_ms), NULL));
        for (;;)
            (void)sd_app_evt_wait();
    See button_event_handler(uint32_t button_number)
    button_number   / behavior
      0  /   send ON to Client[0]      same as Button 1 is pressed
      1  /   send OFF to Client[0]    same as Button 2 is pressed
      2  /   send ON to Client[1]      same as Button 3 is pressed
      3  /   send OFF to Client[1]    same as Button 4 is pressed
    Hope that helps.....
  • Working on those now. Thanks very much for your help thus far. I have learnt so much. Please do not get tired of my asking so many questions.
