PWM implementation for dimming.
I tried adding PWM for turning on/off the LED's on the DK for the Enocean switch example. It worked well.
I tried to perform dimming on the switch example by restricting the increasing or decreasing brightness using the RELEASE_ACTION as follows.
       if (p_status->b0 && timer_diff(timestamp, m_switch_state[index].b0_ts) > SWITCH_DEBOUNCE_INTERVAL_US)
            m_switch_state[index].b0_ts = timestamp;
            set_params.on_off = APP_STATE_ON;
            app_pwm_enable(&PWM1);
            for (uint32_t i=90; i > 50; i--)
			while ( app_pwm_channel_duty_set(&PWM1, 0, i) == NRF_ERROR_BUSY);
                        nrf_delay_ms(100);
if(p_status->action == RELEASE_ACTION)
} } status = generic_onoff_client_set_unack(&m_clients[1], &set_params, &transition_params, APP_UNACK_MSG_REPEAT_COUNT);
But when I release the button to stop the dimming, the release action is not getting recorded immediately. I can see the release action after the PWM is implemented completely(till duty cycle of 50). How can I solve the issue to stop the dimming once I release the switch. I know that the experimental_dimming example contains generic level model but I would like to know why this code isn't functioning properly.
Thank you.
  • Sure. But I am unable to understand how?
    You mean to say by adding another parameter into the enocean switch parameters apart from buttons and status?
    Or you meant some other way? If so, can you give me a little more insight on how to do it?
    Because I feel that the status action is more or less doing the same, reporting the press and release. Even if I define a new parameter, may be the same thing might repeat. Just wanted to make sure what you meant.
    Thank you.
  • Hi!, So we have tried many things, adding additional variables to store ACTION_CHANGE for example, or moving the PWM loops to app_enocean_cb... nothing seems to work, as soon as I many a loop the action parameter doesn't get updated... do you have an EnOcean switch to run this example and replicate the issue? can you make any loop and break it with the release_action? and start it with the press_action?
    I have attached a file. Search for modified in the code and you should see the parts I modified. I have removed a little bit of code just to show what I mean. This is just to show you how you can do it, and might need some modifications to suit your needs. The idea is to have a volatile variable that you can update whenever a button is pressed/released. The code will be running in main, and since the interrupt have higher priority the variable will be updated when you press/release button and then returned to main.
    /* Copyright (c) 2010 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
     * list of conditions and the following disclaimer.
    #include <stdio.h>
    /* HAL */
    #include "boards.h"
    #include "nrf_delay.h"
    #include "simple_hal.h"
    #include "app_timer.h"
    /* Core */
    #include "nrf_mesh.h"
    #include "nrf_mesh_events.h"
    #include "nrf_mesh_assert.h"
    #include "flash_manager.h"
    #include "mesh_stack.h"
    #include "access_config.h"
    /* Provisioning and configuration */
    #include "nrf_mesh_configure.h"
    #include "mesh_provisionee.h"
    #include "mesh_app_utils.h"
    #include "mesh_softdevice_init.h"
    /* Models */
    #include "generic_onoff_client.h"
    /* Logging and RTT */
    #include "rtt_input.h"
    #include "log.h"
    /* Example specific includes */
    #include "app_config.h"
    #include "enocean_switch_example.h"
    #include "nrf_mesh_config_examples.h"
    #include "enocean.h"
    #include "flash_helper.h"
    #include "example_common.h"
    /* Configure switch debounce timeout for EnOcean switch here */
    #define SWITCH_DEBOUNCE_INTERVAL_US (MS_TO_US(500))
    /* Two EnOcean switches can be used in parallel */
    #define MAX_ENOCEAN_DEVICES_SUPPORTED (2)
    #define APP_STATE_OFF                 (0)
    #define APP_STATE_ON                  (1)
    #define APP_UNACK_MSG_REPEAT_COUNT    (2)
    #define LIGHT_SWITCH_CLIENTS          (PTM215B_NUMBER_OF_SWITCHES/2)
    // modified_
    volatile bool m_dim = false;
    volatile bool m_dim_state = 0;
    typedef struct
        uint32_t a0_ts;
        uint32_t a1_ts;
        uint32_t b0_ts;
        uint32_t b1_ts;
    } app_switch_debounce_state_t;
    /** Single advertiser instance. May periodically transmit one packet at a time. */
    static generic_onoff_client_t m_clients[LIGHT_SWITCH_CLIENTS];
    static bool m_device_provisioned;
    static app_secmat_flash_t m_app_secmat_flash[MAX_ENOCEAN_DEVICES_SUPPORTED];
    static enocean_commissioning_secmat_t m_app_secmat[MAX_ENOCEAN_DEVICES_SUPPORTED];
    static uint8_t  m_enocean_dev_cnt;
    static app_switch_debounce_state_t m_switch_state[MAX_ENOCEAN_DEVICES_SUPPORTED];
    /* Forward declaration */
    static void app_gen_onoff_client_publish_interval_cb(access_model_handle_t handle, void * p_self);
    static void app_generic_onoff_client_status_cb(const generic_onoff_client_t * p_self,
                                                   const access_message_rx_meta_t * p_meta,
                                                   const generic_onoff_status_params_t * p_in);
    static void app_gen_onoff_client_transaction_status_cb(access_model_handle_t model_handle,
                                                           void * p_args,
                                                           access_reliable_status_t status);
    static void app_mesh_core_event_cb (const nrf_mesh_evt_t * p_evt);
    static void app_start(void);
    static nrf_mesh_evt_handler_t m_mesh_core_event_handler = { .evt_cb = app_mesh_core_event_cb };
    const generic_onoff_client_callbacks_t client_cbs =
        .onoff_status_cb = app_generic_onoff_client_status_cb,
        .ack_transaction_status_cb = app_gen_onoff_client_transaction_status_cb,
        .periodic_publish_cb = app_gen_onoff_client_publish_interval_cb
    /* Try to store app data. If busy, ask user to manually initiate operation. */
    static void app_data_store_try(void)
        uint32_t status = app_flash_data_store(APP_DATA_ENTRY_HANDLE, &m_app_secmat_flash[0], sizeof(m_app_secmat_flash));
        if (status == NRF_SUCCESS)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Storing: Enocean security material\n");
        else if (status == NRF_ERROR_NOT_SUPPORTED)
           __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Cannot store: Persistent storage not enabled\n");
            __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Flash busy. Cannot store. Press Button 2 to try again. \n");
    static uint8_t enocean_device_index_get(enocean_evt_t * p_evt)
        uint8_t i;
        for (i = 0; i < m_enocean_dev_cnt; i++)
            if (memcmp(p_evt->p_ble_gap_addr, m_app_secmat[i].p_ble_gap_addr, BLE_GAP_ADDR_LEN) == 0)
        /* This should never assert. */
        if (i == m_enocean_dev_cnt)
            APP_ERROR_CHECK(false);
        return i;
    /* Forward the ADV packets to the Enocean module */
    static void rx_callback(const nrf_mesh_adv_packet_rx_data_t * p_rx_data)
        enocean_packet_process(p_rx_data);
    static void app_switch_debounce(enocean_switch_status_t * p_status, uint8_t index)
        uint32_t timestamp = timer_now();
        uint32_t status = NRF_ERROR_INTERNAL;
        generic_onoff_set_params_t set_params;
        model_transition_t transition_params;
        static uint8_t tid = 0;
        set_params.tid = tid++;
        transition_params.delay_ms = APP_CONFIG_ONOFF_DELAY_MS;
        transition_params.transition_time_ms = APP_CONFIG_ONOFF_TRANSITION_TIME_MS;
        if (p_status->action == PRESS_ACTION)
    		// modified_
            // start dimmming;
            m_dim = true;
    //        /* Change state on the unicast server address using 1st on/off client */
    //        if (p_status->a0 && timer_diff(timestamp, m_switch_state[index].a0_ts) > SWITCH_DEBOUNCE_INTERVAL_US)
    //            m_switch_state[index].a0_ts = timestamp;
    //            set_params.on_off = APP_STATE_ON;
    //            hal_led_pin_set(BSP_LED_0, set_params.on_off);
    //            status = generic_onoff_client_set(&m_clients[0], &set_params, &transition_params);
    //        else if (p_status->a1 && timer_diff(timestamp, m_switch_state[index].a1_ts) > SWITCH_DEBOUNCE_INTERVAL_US)
    //            m_switch_state[index].a1_ts = timestamp;
    //            set_params.on_off = APP_STATE_OFF;
    //        if (status == NRF_SUCCESS)
    //            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: Client[0]: ONOFF SET %d\n", set_params.on_off);
    //        status = NRF_ERROR_INTERNAL;
    //        /* Change state on the nodes subscribed to the Odd group address using 2nd on/off client */
    //        if (p_status->b0 && timer_diff(timestamp, m_switch_state[index].b0_ts) > SWITCH_DEBOUNCE_INTERVAL_US)
    //            m_switch_state[index].b0_ts = timestamp;
    //            hal_led_pin_set(BSP_LED_1, set_params.on_off);
    //            status = generic_onoff_client_set_unack(&m_clients[1], &set_params, &transition_params, APP_UNACK_MSG_REPEAT_COUNT);
    //        else if (p_status->b1 && timer_diff(timestamp, m_switch_state[index].b1_ts) > SWITCH_DEBOUNCE_INTERVAL_US)
    //            m_switch_state[index].b1_ts = timestamp;
    //            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sending msg: Client[1]: ONOFF SET %d\n", set_params.on_off);
    	// modified_
        else if (p_status->action == PRESS_ACTION)
            // stop dimming;
            m_dim = false;
    /* This example translates the messages from the PTM215B switches to on/off client model messages.
    The mapping of the switches and corresponding client model messages is as follows:
    Pressing Switch 1 will turn ON LED 1 on the servers with ODD addresses.
    Pressing Switch 2 will turn OFF LED 1 on the servers with ODD addresses.
    Pressing Switch 3 will turn ON LED 1 on the servers with EVEN addresses.
    Pressing Switch 4 will turn OFF LED 1 on the servers with EVEN addresses.
    static void app_enocean_cb(enocean_evt_t * p_evt)
        if  (p_evt->type == ENOCEAN_EVT_DATA_RECEIVED)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Sw data A0: %d A1: %d B0: %d B1: %d Action: %d\n",
                  p_evt->params.data.status.a0,p_evt->params.data.status.a1,p_evt->params.data.status.b0,
                  p_evt->params.data.status.b1,p_evt->params.data.status.action);
            app_switch_debounce(&p_evt->params.data.status, enocean_device_index_get(p_evt));
        else if (p_evt->type == ENOCEAN_EVT_SECURITY_MATERIAL_RECEIVED)
            if (m_enocean_dev_cnt < MAX_ENOCEAN_DEVICES_SUPPORTED)
                m_app_secmat_flash[m_enocean_dev_cnt].seq = p_evt->params.secmat.seq;
                memcpy(&m_app_secmat_flash[m_enocean_dev_cnt].ble_gap_addr[0],
                       p_evt->p_ble_gap_addr, BLE_GAP_ADDR_LEN);
                memcpy(&m_app_secmat_flash[m_enocean_dev_cnt].key[0],
                       p_evt->params.secmat.p_key, PTM215B_COMM_PACKET_KEY_SIZE);
                app_data_store_try();
                m_app_secmat[m_enocean_dev_cnt].p_seq =  &m_app_secmat_flash[m_enocean_dev_cnt].seq;
                m_app_secmat[m_enocean_dev_cnt].p_ble_gap_addr = &m_app_secmat_flash[m_enocean_dev_cnt].ble_gap_addr[0];
                m_app_secmat[m_enocean_dev_cnt].p_key = &m_app_secmat_flash[m_enocean_dev_cnt].key[0];
                enocean_secmat_add(&m_app_secmat[m_enocean_dev_cnt]);
                m_enocean_dev_cnt++;
                hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_PROV);
                __LOG(LOG_SRC_APP, LOG_LEVEL_ERROR, "Cannot add new device. Max number of supported devices: %d\n", MAX_ENOCEAN_DEVICES_SUPPORTED);
    /* This callback is called periodically if model is configured for periodic publishing */
         __LOG(LOG_SRC_APP, LOG_LEVEL_WARN, "Publish desired message here.\n");
    /* Acknowledged transaction status callback, if acknowledged transfer fails, application can
    * determine suitable course of action (e.g. re-initiate previous transaction) by using this
    * callback.
                                                           void * p_args,
        switch(status)
            case ACCESS_RELIABLE_TRANSFER_SUCCESS:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer success.\n");
            case ACCESS_RELIABLE_TRANSFER_TIMEOUT:
                hal_led_blink_ms(LEDS_MASK, LED_BLINK_SHORT_INTERVAL_MS, LED_BLINK_CNT_NO_REPLY);
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer timeout.\n");
            case ACCESS_RELIABLE_TRANSFER_CANCELLED:
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Acknowledged transfer cancelled.\n");
                ERROR_CHECK(NRF_ERROR_INTERNAL);
    /* Generic OnOff client model interface: Process the received status message in this callback */
        if (p_in->remaining_time_ms > 0)
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d, Target OnOff: %d, Remaining Time: %d ms\n",
                  p_meta->src.value, p_in->present_on_off, p_in->target_on_off, p_in->remaining_time_ms);
            __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "OnOff server: 0x%04x, Present OnOff: %d\n",
                  p_meta->src.value, p_in->present_on_off);
    static void node_reset(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- Node reset  -----\n");
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_RESET);
        /* This function may return if there are ongoing flash operations. */
        mesh_stack_device_reset();
    static void config_server_evt_cb(const config_server_evt_t * p_evt)
        if (p_evt->type == CONFIG_SERVER_EVT_NODE_RESET)
            node_reset();
    static void button_event_handler(uint32_t button_number)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Button %u pressed\n", button_number);
        switch (button_number)
            /* Press SW1 to store latest sequence number.
            USER_NOTE: End product should implement a mechanism to trigger this process upon
            external event, such as power fail interrupt, and ensure that the device finishes flash writes
            before running out of power. */
            case 1:
            /* Initiate node reset */
            case 3:
                /* Clear all the states to reset the node. */
                mesh_stack_config_clear();
                app_flash_clear(&m_app_secmat_flash[0], sizeof(m_app_secmat_flash));
                node_reset();
    static void app_mesh_core_event_cb(const nrf_mesh_evt_t * p_evt)
        /* USER_NOTE: User can insert mesh core event proceesing here */
        switch (p_evt->type)
            /* Start user application specific functions only when flash is stable */
            case NRF_MESH_EVT_FLASH_STABLE:
                __LOG(LOG_SRC_APP, LOG_LEVEL_DBG1, "Mesh evt: FLASH_STABLE \n");
                    static bool s_app_started;
                    if (!s_app_started)
                        /* Flash operation initiated during initialization has been completed */
                        app_start();
                        s_app_started = true;
    static void models_init_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Initializing and adding models\n");
        /* Model initialization */
        for (uint32_t i = 0; i < LIGHT_SWITCH_CLIENTS; ++i)
            m_clients[i].settings.p_callbacks = &client_cbs;
            m_clients[i].settings.timeout = 0;
            m_clients[i].settings.force_segmented = APP_CONFIG_FORCE_SEGMENTATION;
            m_clients[i].settings.transmic_size = APP_CONFIG_MIC_SIZE;
            ERROR_CHECK(generic_onoff_client_init(&m_clients[i], i + 1));
    static void provisioning_complete_cb(void)
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Successfully provisioned\n");
        dsm_local_unicast_address_t node_address;
        dsm_local_unicast_addresses_get(&node_address);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Node Address: 0x%04x \n", node_address.address_start);
        hal_led_mask_set(LEDS_MASK, LED_MASK_STATE_OFF);
    static void app_rtt_input_handler(int key)
        if (key >= '0' && key <= '3')
            uint32_t button_number = key - '0';
            button_event_handler(button_number);
    static void mesh_init(void)
        uint8_t dev_uuid[NRF_MESH_UUID_SIZE];
        uint8_t node_uuid_prefix[NODE_UUID_PREFIX_LEN] = CLIENT_NODE_UUID_PREFIX;
        ERROR_CHECK(mesh_app_uuid_gen(dev_uuid, node_uuid_prefix, NODE_UUID_PREFIX_LEN));
        mesh_stack_init_params_t init_params =
            .core.irq_priority       = NRF_MESH_IRQ_PRIORITY_LOWEST,
            .core.lfclksrc           = DEV_BOARD_LF_CLK_CFG,
            .core.p_uuid             = dev_uuid,
            .models.models_init_cb   = models_init_cb,
            .models.config_server_cb = config_server_evt_cb
        ERROR_CHECK(mesh_stack_init(&init_params, &m_device_provisioned));
        /* Register event handler to receive NRF_MESH_EVT_FLASH_STABLE. Application functionality will
        be started after this event */
        nrf_mesh_evt_handler_add(&m_mesh_core_event_handler);
    static void initialize(void)
        __LOG_INIT(LOG_SRC_APP | LOG_SRC_ACCESS , LOG_LEVEL_INFO, LOG_CALLBACK_DEFAULT);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "----- BLE Mesh Enocean Switch Translator Demo -----\n");
        ERROR_CHECK(app_timer_init());
        hal_leds_init();
    #if BUTTON_BOARD
        ERROR_CHECK(hal_buttons_init(button_event_handler));
        nrf_clock_lf_cfg_t lfc_cfg = DEV_BOARD_LF_CLK_CFG;
        ERROR_CHECK(mesh_softdevice_init(lfc_cfg));
        mesh_init();
        app_flash_init();
        enocean_translator_init(app_enocean_cb);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Starting application \n");
        /* Load app specific data */
        if (app_flash_data_load(APP_DATA_ENTRY_HANDLE, &m_app_secmat_flash[0], sizeof(m_app_secmat_flash)) == NRF_SUCCESS)
            for (uint8_t i = 0; i < MAX_ENOCEAN_DEVICES_SUPPORTED; i++)
                m_app_secmat[i].p_ble_gap_addr = &m_app_secmat_flash[i].ble_gap_addr[0];
                m_app_secmat[i].p_key = &m_app_secmat_flash[i].key[0];
                m_app_secmat[i].p_seq = &m_app_secmat_flash[i].seq;
                enocean_secmat_add(&m_app_secmat[i]);
                __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Restored: Enocean security materials\n");
            m_enocean_dev_cnt = 0;
        /* Install rx callback to intercept incoming ADV packets so that they can be passed to the
        EnOcean packet processor */
        nrf_mesh_rx_cb_set(rx_callback);
    static void start(void)
        rtt_input_enable(app_rtt_input_handler, RTT_INPUT_POLL_PERIOD_MS);
        ERROR_CHECK(mesh_stack_start());
        if (!m_device_provisioned)
            static const uint8_t static_auth_data[NRF_MESH_KEY_SIZE] = STATIC_AUTH_DATA;
            mesh_provisionee_start_params_t prov_start_params =
                .p_static_data    = static_auth_data,
                .prov_complete_cb = provisioning_complete_cb,
                .p_device_uri = NULL
            ERROR_CHECK(mesh_provisionee_prov_start(&prov_start_params));
        const uint8_t *p_uuid = nrf_mesh_configure_device_uuid_get();
        __LOG_XB(LOG_SRC_APP, LOG_LEVEL_INFO, "Device UUID ", p_uuid, NRF_MESH_UUID_SIZE);
        hal_led_blink_ms(LEDS_MASK, LED_BLINK_INTERVAL_MS, LED_BLINK_CNT_START);
    #if !PERSISTENT_STORAGE
        app_start();
        initialize();
        execution_start(start);
        for (;;)
    		//modified_
            while(m_dim)
    			if(m_dim_state == 0){
    				CURRENT_LIGHT_INTENSITY--
    				if(CURRENT_LIGHT_INTENSITY < 50){
    					m_dim_state = 1
    			else{
    				CURRENT_LIGHT_INTENSITY++
    				if(CURRENT_LIGHT_INTENSITY > 99){
    					m_dim_state = 0;
                while ( app_pwm_channel_duty_set(&PWM1, 0, CURRENT_LIGHT_INTENSITY) == NRF_ERROR_BUSY);
                nrf_delay_ms(10);
            (void)sd_app_evt_wait();
  • Thanks for the reply.
    That works and we will try to modify it as per our requirements.
