Problems with OUT reports on USB HID
I'm using the NRF52840 PDK version:
PCA10056
0.11.0
2018.3
With SDK version 15.2
I've been trying to develop an application based on the HID Generic example and am seeing some strange behaviours on the USB HID OUT endpoint.
I try to obtain the data in the APP_USBD_HID_USER_EVT_OUT_REPORT_READY event, at which point I use app_usbd_hid_generic_out_report_get to retrieve the data for processing in my main loop.
After more tracing and debugging, I've found that the hid_generic_ep_transfer_out handler is called when the OUT endpoint is busy.  When this happens the app_usbd_ep_transfer fails and app_usbd proceeds to stall the endpoint (in app_usbd_event_execute).
How can I avoid this situation?
Larry
  • They have found an issue in your application, do the following:
    • replace bluink_process_usb_events() with:
    void bluink_process_usb_events( void )
       while ( 1 )
          app_usbd_event_queue_process();
    • in hid_u2f_user_ev_handler() in switch, replace case for APP_USBD_HID_USER_EVT_OUT_REPORT_READY with:
    case APP_USBD_HID_USER_EVT_OUT_REPORT_READY:
          m_report_received += 1;
          size_t recv_size;
          uint8_t *p_recv_buf = (uint8_t *)app_usbd_hid_generic_out_report_get(&m_app_hid_u2f, &recv_size);
          app_usbd_hid_generic_in_report_set(&m_app_hid_u2f, p_recv_buf, recv_size);
    Please confirm this fixed the issue.
  • Hi Kenneth,
    Indeed, it has illustrated to me how to fix my issue.  Thank you very much!
    I was able to use the blinky test with your changes and I could send arbitrarily large messages at full speed.  I had to do quite a bit of experimenting to make this work with my use case:
    The challenge I have is that I am processing large messages coming from USB and sending them off through BT and responding (receiving BT then responding over USB).
    So I have to be able to manage buffers between USB and BT.
    I have some observations that I'd like to share and would like it if you could comment on them:
    1) If I process USB too fast (calling app_usbd_event_queue_process() too fast), then I run into the OUT endpoint issue.  I believe the root cause is that I need to have enough time to process the data before the next OUT event comes through.
    2) It seems that if I process USB too slow (i.e. not calling app_usbd_event_queue_process() often enough) that the device eventually hangs.  My guess is that the event queue fills up and things just can't go on.
    The trick was finding a balance between the two which can allow the BT processing that I need to do at the same time.
    Can you confirm that my understanding of app_usbd_event_queue_process() is correct?
    Again, thanks for your help.
    Larry
  • 1. Calling `app_usbd_event_queue_process()` too often should not pose a problem. As soon as data is processed, it should be passed to the USB stack with `app_usbd_hid_generic_in_report_set()`. With no events left to process, USB stack just waits. But if you need a lot of time to process BLE data, calling `app_usbd_event_queue_process()` when there is no need may lead to slower processing.
    2. On the other hand, calling `app_usbd_event_queue_process()` too rarely is a problem - some events are not processed in time (which in this case lead to STALL of OUT reports).
    Kenneth
  • Hello Larry,
    Can you please share with me how this helped you fixed the issue? I am facing a similar issue and following the above discussions did not help me find the problem.
    Thanks
  • Yes.  The modified blinky project that was uploaded in this ticked illustrates the problem.  Kenneth was able to provide changes that made the issue go away.  That proved that a solution does exist.
    For my application I had to make sure that I was always able to process an OUT report as soon as I get the event (it meant I needed more buffers).  At the same time, I had to call app_usbd_event_queue_process() often enough to keep up with USB events.
    I hope that helps you.
    Larry
