hi..........
i want to put my peripheral device in sleep mode ? how to do that?
i tried this one , its shows error
err_code= sd_power_system_off();
hi..........
what to declare ?
It tells you what to declare!
You need to declare the thing which it told you was un-declared!
i tried ... leave that .. how to turn the device into sleep mode , using system off right . if i were wrong tell me and explain me about system on and off .......what function to used to turn the device into sleep and how to declare and tell me syntax .
OK - so long as you have fixed the error and understood the issue.
As noted, it is a very basic 'C' programming issue - if you're still not clear on such basics, you are going to struggle with advanced stuff like BLE.
Have you studied the documentation?
You haven't said what chip you're using, or what SoftDevice you're using.
For S132 v6.1.0, the documentation is here:
You will also need to study the chip documentation.
Have you looked at SDK examples?
Details of the nRF52832 power modes here:
leave that
Apparently not: https://devzone.nordicsemi.com/f/nordic-q-a/40579/nus_data_handler-error
