Hi.
I' m using nRF52832, SDK v15.0.0, S132.
I'm want tutorial how make bootloader DFU in IAR.
How I make bootloader DFU for nrf52832 in IAR?
Hi.
Why do no such file ?
The path that nrfutil is provided, i.e. C:\\1\\nrf52832_xxaa.hex looks weird. It should be C:\1\nrf52832_xxaa.hex.
Try placing nrfutil.exe in the C:\1\
Then open cmd and type cd "C:\1\" and run the command without any reference to C:\1\ in the path to nrf52832_xxaa.hex
i am not debug in IAR. I get errors Wed Dec 19, 2018 17:40:22: ELF/DWARF Error: Unsupported .debug_info format version: 4 and Wed Dec 19, 2018 17:40:22: Failed to load debugee.
What do I do wrong?
THis appears to be answered in this case
https://devzone.nordicsemi.com/f/nordic-q-a/17585/debugging-dfu-in-iar---sdk12
Could you try to remove the -g3 option from the micro-ecc Makefile? As suggested. It should then compiles/load in IAR without problems. You should then have debug information from the dfu software itself. Only the micro-ecc part is without debug information.
How do I can update softdevice and application and bootloader with help DFU?
I want to update by dfu SD+BL+APP to the SDK15.
