Hi.
I' m using nRF52832, SDK v15.0.0, S132.
I'm want tutorial how make bootloader DFU in IAR.
How I make bootloader DFU for nrf52832 in IAR?
Hi.
I get error in function static void ble_stack_init(void).
I changed NRF_SDH_BLE_VS_UUID_COUNT with 1 in 2, but now in function:
ret_code_t nrf_sdh_ble_enable(uint32_t * const p_app_ram_start)
// Start of RAM, obtained from linker symbol.
uint32_t const app_ram_start_link = *p_app_ram_start;
ret_code_t ret_code = sd_ble_enable(p_app_ram_start);
if (*p_app_ram_start > app_ram_start_link)
NRF_LOG_WARNING("Insufficient RAM allocated for the SoftDevice.");
NRF_LOG_WARNING("Change the RAM start location from 0x%x to 0x%x.",
app_ram_start_link, *p_app_ram_start);
NRF_LOG_WARNING("Maximum RAM size for application is 0x%x.",
ram_end_address_get() - (*p_app_ram_start));
NRF_LOG_DEBUG("RAM starts at 0x%x", app_ram_start_link);
if (*p_app_ram_start != app_ram_start_link)
NRF_LOG_DEBUG("RAM start location can be adjusted to 0x%x.", *p_app_ram_start);
NRF_LOG_DEBUG("RAM size for application can be adjusted to 0x%x.",
if (ret_code == NRF_SUCCESS)
m_stack_is_enabled = true;
NRF_LOG_ERROR("sd_ble_enable() returned %s.", nrf_strerror_get(ret_code));
return ret_code;
the the execution the execution enters in the block
Thank you for your support.
I modify RAM start and RAM STOP in IAR.
after started project.
How do start work DFU? I use function ble_dfu_buttonless_bootloader_start_finalize(); but she not started DFU.
Error on line nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU); in function
uint32_t ble_dfu_buttonless_bootloader_start_finalize(void)
uint32_t err_code;
NRF_LOG_DEBUG("In ble_dfu_buttonless_bootloader_start_finalize\r\n");
err_code = sd_power_gpregret_clr(0, 0xffffffff);
VERIFY_SUCCESS(err_code);
err_code = sd_power_gpregret_set(0, BOOTLOADER_DFU_START);
// Indicate that the Secure DFU bootloader will be entered
m_dfu.evt_handler(BLE_DFU_EVT_BOOTLOADER_ENTER);
// Signal that DFU mode is to be enter to the power management module
return NRF_SUCCESS;
I don't know that do. Help me.
Alex, when you report that functions return errors, then you need to provide the error codes so that we can find out what caused the error. Also do you mean a compilation error or a run-time error?
After calling the ble_dfu_buttonless_bootloader_start_finalize() function the device should jump to the bootloader and the device should start advertising as DfuTarg. You can then connect to the device using nRF Connect for Desktop or Mobile(ios/Android) and then start a DFU by pressing the DFU icon, the blue lock and then select the image you want to upload
ble_dfu_buttonless_bootloader_start_finalize -> nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_DFU) -> nrf_pwr_mgmt_shutdown(nrf_pwr_mgmt_shutdown_t shutdown_type) -> shutdown_process(void).
static void shutdown_process(void)
if ((m_pwr_mgmt_evt == NRF_PWR_MGMT_EVT_PREPARE_RESET)
|| (m_pwr_mgmt_evt == NRF_PWR_MGMT_EVT_PREPARE_DFU))
NVIC_SystemReset();
And occurs System Reset.
YEs, that is the intended behaviour. The chip should perform a SystemReset so that it enter the bootloader, which is always started before the application when it is present on the chip.
