BLE manual connect and Disconnect
Dear Nordic Team,
Thanks for supporting.
I am working in ble_app_uart_c example in this example is automatically connect with its peripheral. But i need to connect and disconnect manually like  nRF_UART android app. please support anyone.
My HW = DK52
SDK = SDK15.2.0
  • possible to change scan filter while running time ? because while scanning i will set UUID scaning , when establish connection i will set UUID and ADDR both scanning. The above examples are one time initialization process, i want to random scan initialization. Is this possible ?
  • Yes, you can adjust the scan parameters and filters runtime. But you have to stop scanning by calling nrf_ble_scan_stop() before you reconfigure.
  • yes, already tested same like your comment. Here with enclosed my code, i dont know what i am doing wrong . please guide me.
     * Copyright (c) 2016 - 2018, Nordic Semiconductor ASA
     * All rights reserved.
    #include <stdio.h>
    #include <stdint.h>
    #include <stdbool.h>
    #include "nordic_common.h"
    #include "app_error.h"
    #include "app_uart.h"
    #include "ble_db_discovery.h"
    #include "app_timer.h"
    #include "app_util.h"
    #include "bsp_btn_ble.h"
    #include "ble.h"
    #include "ble_gap.h"
    #include "ble_hci.h"
    #include "nrf_sdh.h"
    #include "nrf_sdh_ble.h"
    #include "nrf_sdh_soc.h"
    #include "ble_nus_c.h"
    #include "nrf_ble_gatt.h"
    #include "nrf_pwr_mgmt.h"
    #include "nrf_ble_scan.h"
    #include "ble_conn_state.h"
    #include "nrf_log.h"
    #include "nrf_log_ctrl.h"
    #define APP_BLE_CONN_CFG_TAG    1                                       /**< Tag that refers to the BLE stack configuration set with @ref sd_ble_cfg_set. The default tag is @ref BLE_CONN_CFG_TAG_DEFAULT. */
    #define APP_BLE_OBSERVER_PRIO   3                                       /**< BLE observer priority of the application. There is no need to modify this value. */
    #define UART_TX_BUF_SIZE        256                                     /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE        256                                     /**< UART RX buffer size. */
    #define NUS_SERVICE_UUID_TYPE   BLE_UUID_TYPE_VENDOR_BEGIN              /**< UUID type for the Nordic UART Service (vendor specific). */
    #define ECHOBACK_BLE_UART_DATA  1                                       /**< Echo the UART data that is received over the Nordic UART Service (NUS) back to the sender. */
    BLE_NUS_C_DEF(m_ble_nus_c);                                             /**< BLE Nordic UART Service (NUS) client instance. */
    NRF_BLE_GATT_DEF(m_gatt);                                               /**< GATT module instance. */
    BLE_DB_DISCOVERY_DEF(m_db_disc);                                        /**< Database discovery module instance. */
    NRF_BLE_SCAN_DEF(m_scan);                                               /**< Scanning Module instance. */
    static uint16_t m_ble_nus_max_data_len = BLE_GATT_ATT_MTU_DEFAULT - OPCODE_LENGTH - HANDLE_LENGTH; /**< Maximum length of data (in bytes) that can be transmitted to the peer by the Nordic UART service module. */
    uint8_t GI8u_Device_ID=0;
    uint8_t GI8u_Device_List[30][6];
    uint8_t GI8u_Device_List_Cnt=0;
    uint8_t GI8u_Device_Conn[12];
    static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;
    static void Clear_Device_List(void);
    static void scan_init_List(void);
    /**@brief NUS UUID. */
    static ble_uuid_t const m_nus_uuid =
        .uuid = BLE_UUID_NUS_SERVICE,
        .type = NUS_SERVICE_UUID_TYPE
    /**@brief Function for handling asserts in the SoftDevice.
     * @details This function is called in case of an assert in the SoftDevice.
     * @warning This handler is only an example and is not meant for the final product. You need to analyze
     *          how your product is supposed to react in case of assert.
     * @param[in] line_num     Line number of the failing assert call.
     * @param[in] p_file_name  File name of the failing assert call.
        app_error_handler(0xDEADBEEF, line_num, p_file_name);
    /**@brief Function for starting scanning. */
    static void scan_start(void)
        ret_code_t ret;
        ret = nrf_ble_scan_start(&m_scan);
        APP_ERROR_CHECK(ret);
        ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    /**@brief Function for handling Scanning Module events.
    static void scan_evt_handler(scan_evt_t const * p_scan_evt)
        ret_code_t err_code;
        switch(p_scan_evt->scan_evt_id)
             case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
                  err_code = p_scan_evt->params.connecting_err.err_code;
             } break;
             case NRF_BLE_SCAN_EVT_CONNECTED:
                  ble_gap_evt_connected_t const * p_connected = p_scan_evt->params.connected.p_connected;
                 // Scan is automatically stopped by the connection.
                 NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
                          p_connected->peer_addr.addr[0],
                          p_connected->peer_addr.addr[1],
                          p_connected->peer_addr.addr[2],
                          p_connected->peer_addr.addr[3],
                          p_connected->peer_addr.addr[4],
                          p_connected->peer_addr.addr[5]
             } break;
             case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
                NRF_LOG_INFO("Scan timed out.");
    					  GI8u_Device_ID=0;
    						Clear_Device_List();
    				    scan_init_List();
                scan_start();
             } break;
    /**@brief Function for initializing the scanning and setting the filters.
        nrf_ble_scan_init_t init_scan;
        memset(&init_scan, 0, sizeof(init_scan));
        init_scan.connect_if_match = false;
        init_scan.conn_cfg_tag     = APP_BLE_CONN_CFG_TAG;
        err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
       //err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER, &GI8u_Device_List[GI8u_Device_ID-1][0]);
    	  err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
    static void scan_init_Connection(void)
        init_scan.connect_if_match = true;
        err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER,GI8u_Device_Conn);  //err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_ADDR_FILTER, &GI8u_Device_List[GI8u_Device_ID-1][0]);
        err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_ADDR_FILTER, false);
    /**@brief Function for handling database discovery events.
     * @details This function is a callback function to handle events from the database discovery module.
     *          Depending on the UUIDs that are discovered, this function forwards the events
     *          to their respective services.
     * @param[in] p_event  Pointer to the database discovery event.
    static void db_disc_handler(ble_db_discovery_evt_t * p_evt)
        ble_nus_c_on_db_disc_evt(&m_ble_nus_c, p_evt);
    /**@brief Function for handling characters received by the Nordic UART Service (NUS).
     * @details This function takes a list of characters of length data_len and prints the characters out on UART.
     *          If @ref ECHOBACK_BLE_UART_DATA is set, the data is sent back to sender.
    static void ble_nus_chars_received_uart_print(uint8_t * p_data, uint16_t data_len)
        ret_code_t ret_val;
        NRF_LOG_DEBUG("Receiving data.");
        NRF_LOG_HEXDUMP_DEBUG(p_data, data_len);
        for (uint32_t i = 0; i < data_len; i++)
            do
                ret_val = app_uart_put(p_data[i]);
                if ((ret_val != NRF_SUCCESS) && (ret_val != NRF_ERROR_BUSY))
                    NRF_LOG_ERROR("app_uart_put failed for index 0x%04x.", i);
                    APP_ERROR_CHECK(ret_val);
            } while (ret_val == NRF_ERROR_BUSY);
        if (p_data[data_len-1] == '\r')
            while (app_uart_put('\n') == NRF_ERROR_BUSY);
        if (ECHOBACK_BLE_UART_DATA)
            // Send data back to the peripheral.
            do
                ret_val = ble_nus_c_string_send(&m_ble_nus_c, p_data, data_len);
                    NRF_LOG_ERROR("Failed sending NUS message. Error 0x%x. ", ret_val);
     * @details This function receives a single character from the app_uart module and appends it to
     *          a string. The string is sent over BLE when the last character received is a
     *          'new line' '\n' (hex 0x0A) or if the string reaches the maximum data length.
        static uint16_t index = 0;
    //    uint32_t ret_val;
        switch (p_event->evt_type)
            /**@snippet [Handling data from UART] */
            case APP_UART_DATA_READY:
                index++;
                if ((data_array[index - 1] == '\n') || (index >= (m_ble_nus_max_data_len)))
    							if(ble_conn_state_central_conn_count()>0){
    							else if(ble_conn_state_central_conn_count()==0){
    											if(memcmp(&data_array[0],"DEVICE1",7)==0){GI8u_Device_ID=1;}
    											if(memcmp(&data_array[1],"DEVICE2",7)==0){GI8u_Device_ID=2;}
    											if(memcmp(&data_array[2],"DEVICE3",7)==0){GI8u_Device_ID=3;}
    											if(memcmp(&data_array[3],"DEVICE4",7)==0){GI8u_Device_ID=4;}
    											if(memcmp(&data_array[4],"DEVICE5",7)==0){GI8u_Device_ID=5;}
    											if(memcmp(&data_array[5],"DEVICE6",7)==0){GI8u_Device_ID=6;}
    											if(memcmp(&data_array[6],"DEVICE7",7)==0){GI8u_Device_ID=7;}
    											if(memcmp(&data_array[7],"DEVICE8",7)==0){GI8u_Device_ID=8;}
    											if(GI8u_Device_ID >GI8u_Device_List_Cnt){
    												GI8u_Device_List_Cnt=0;printf("Invalid Entry\r\n");
    											if(GI8u_Device_ID>0){
    												nrf_ble_scan_stop();
    													uint8_t LI8u_Loop=0;uint8_t LI8u_Loop1=0;
    													for(LI8u_Loop=0;LI8u_Loop<6;LI8u_Loop++){
    															  GI8u_Device_Conn[LI8u_Loop1]=GI8u_Device_List[GI8u_Device_ID-1][LI8u_Loop];
    														    GI8u_Device_Conn[LI8u_Loop1+1]=',';LI8u_Loop1+=2;
    												//		printf("Target Device ID :%s\r\n",GI8u_Device_Conn);
    												scan_init_Connection();
    												scan_start();
    											if(memcmp(&data_array[0],"DISCONNECT",10)==0){
    														err_code = sd_ble_gap_disconnect(m_ble_nus_c.conn_handle,BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
    														if(err_code != NRF_ERROR_INVALID_STATE)
    														 GI8u_Device_ID=0;
    //                do
    //                    ret_val = ble_nus_c_string_send(&m_ble_nus_c, data_array, index);
    //                    if ( (ret_val != NRF_ERROR_INVALID_STATE) && (ret_val != NRF_ERROR_RESOURCES) )
    //                        APP_ERROR_CHECK(ret_val);
    //                } while (ret_val == NRF_ERROR_RESOURCES);
                    index = 0;
                NRF_LOG_ERROR("Communication error occurred while handling UART.");
            case APP_UART_FIFO_ERROR:
                NRF_LOG_ERROR("Error occurred in FIFO module used by UART.");
    /**@brief Callback handling Nordic UART Service (NUS) client events.
     * @details This function is called to notify the application of NUS client events.
     * @param[in]   p_ble_nus_c   NUS client handle. This identifies the NUS client.
     * @param[in]   p_ble_nus_evt Pointer to the NUS client event.
    /**@snippet [Handling events from the ble_nus_c module] */
    static void ble_nus_c_evt_handler(ble_nus_c_t * p_ble_nus_c, ble_nus_c_evt_t const * p_ble_nus_evt)
        switch (p_ble_nus_evt->evt_type)
            case BLE_NUS_C_EVT_DISCOVERY_COMPLETE:
                NRF_LOG_INFO("Discovery complete.");
                err_code = ble_nus_c_handles_assign(p_ble_nus_c, p_ble_nus_evt->conn_handle, &p_ble_nus_evt->handles);
                err_code = ble_nus_c_tx_notif_enable(p_ble_nus_c);
                NRF_LOG_INFO("Connected to device with Nordic UART Service.");
            case BLE_NUS_C_EVT_NUS_TX_EVT:
                ble_nus_chars_received_uart_print(p_ble_nus_evt->p_data, p_ble_nus_evt->data_len);
            case BLE_NUS_C_EVT_DISCONNECTED:
                NRF_LOG_INFO("Disconnected.");
    				    GI8u_Device_ID=0;
    				    scan_init_List();
                scan_start();
     * @brief Function for handling shutdown events.
     * @param[in]   event       Shutdown type.
    static bool shutdown_handler(nrf_pwr_mgmt_evt_t event)
        switch (event)
            case NRF_PWR_MGMT_EVT_PREPARE_WAKEUP:
                // Prepare wakeup buttons.
        return true;
    NRF_PWR_MGMT_HANDLER_REGISTER(shutdown_handler, APP_SHUTDOWN_HANDLER_PRIORITY);
    static bool Check_List(const ble_gap_evt_adv_report_t *p_adv_report){
    	for(LI8u_Loop=0;LI8u_Loop<GI8u_Device_List_Cnt;LI8u_Loop++){
    		if(memcmp(&GI8u_Device_List[LI8u_Loop][0], &p_adv_report->peer_addr.addr[0],6)==0){
    			return false;
    	return true;
    static void Clear_Device_List(void){
    		memset(&GI8u_Device_List[LI8u_Loop][0],0,20);
    static void Print_Device_List(void){
    	for(LI8u_Loop=GI8u_Device_List_Cnt-1;LI8u_Loop<GI8u_Device_List_Cnt;LI8u_Loop++){
    	     printf("Device:%d=== %02x%02x%02x%02x%02x%02x\r\n" , LI8u_Loop+1,
    														GI8u_Device_List[LI8u_Loop][1],
    														GI8u_Device_List[LI8u_Loop][2],
    														GI8u_Device_List[LI8u_Loop][3],
    														GI8u_Device_List[LI8u_Loop][4],
    														GI8u_Device_List[LI8u_Loop][5]
        ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
    			case BLE_GAP_EVT_ADV_REPORT:
    				  ble_gap_evt_adv_report_t const * p_adv_report = &p_gap_evt->params.adv_report;
    			    uint16_t data_len;
    					data_len = p_adv_report->data.len;
    			if (ble_advdata_name_find(p_adv_report->data.p_data,data_len,"Nordic_UART"))
                if(GI8u_Device_List_Cnt>0){
    							  if(Check_List( p_adv_report)){
    									  memcpy(&GI8u_Device_List[GI8u_Device_List_Cnt][0], &p_adv_report->peer_addr.addr[0],6);
    									  GI8u_Device_List_Cnt++;Print_Device_List();
                else if(GI8u_Device_List_Cnt==0){
            case BLE_GAP_EVT_CONNECTED:
                err_code = ble_nus_c_handles_assign(&m_ble_nus_c, p_ble_evt->evt.gap_evt.conn_handle, NULL);
                // start discovery of services. The NUS Client waits for a discovery result
                err_code = ble_db_discovery_start(&m_db_disc, p_ble_evt->evt.gap_evt.conn_handle);
                NRF_LOG_INFO("Disconnected. conn_handle: 0x%x, reason: 0x%x",
                             p_gap_evt->conn_handle,
                             p_gap_evt->params.disconnected.reason);
            case BLE_GAP_EVT_TIMEOUT:
                if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
                    NRF_LOG_INFO("Connection Request timed out.");
                // Pairing not supported.
                err_code = sd_ble_gap_sec_params_reply(p_ble_evt->evt.gap_evt.conn_handle, BLE_GAP_SEC_STATUS_PAIRING_NOT_SUPP, NULL, NULL);
            case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
                // Accepting parameters requested by peer.
                err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
                                                        &p_gap_evt->params.conn_param_update_request.conn_params);
                ble_gap_phys_t const phys =
                    .rx_phys = BLE_GAP_PHY_AUTO,
                    .tx_phys = BLE_GAP_PHY_AUTO,
            } break;
            case BLE_GATTC_EVT_TIMEOUT:
            case BLE_GATTS_EVT_TIMEOUT:
        uint32_t ram_start = 0;
        // Enable BLE stack.
    /**@brief Function for handling events from the GATT library. */
    void gatt_evt_handler(nrf_ble_gatt_t * p_gatt, nrf_ble_gatt_evt_t const * p_evt)
        if (p_evt->evt_id == NRF_BLE_GATT_EVT_ATT_MTU_UPDATED)
            NRF_LOG_INFO("ATT MTU exchange completed.");
            m_ble_nus_max_data_len = p_evt->params.att_mtu_effective - OPCODE_LENGTH - HANDLE_LENGTH;
            NRF_LOG_INFO("Ble NUS max data length set to 0x%X(%d)", m_ble_nus_max_data_len, m_ble_nus_max_data_len);
    /**@brief Function for initializing the GATT library. */
    void gatt_init(void)
        err_code = nrf_ble_gatt_init(&m_gatt, gatt_evt_handler);
        err_code = nrf_ble_gatt_att_mtu_central_set(&m_gatt, NRF_SDH_BLE_GATT_MAX_MTU_SIZE);
     * @param[in] event  Event generated by button press.
        switch (event)
            case BSP_EVENT_SLEEP:
                nrf_pwr_mgmt_shutdown(NRF_PWR_MGMT_SHUTDOWN_GOTO_SYSOFF);
            case BSP_EVENT_DISCONNECT:
    /**@brief Function for initializing the UART. */
    static void uart_init(void)
            .rx_pin_no    = RX_PIN_NUMBER,
            .tx_pin_no    = TX_PIN_NUMBER,
            .use_parity   = false,
            .baud_rate    = UART_BAUDRATE_BAUDRATE_Baud115200
                           UART_RX_BUF_SIZE,
                           UART_TX_BUF_SIZE,
                           uart_event_handle,
                           APP_IRQ_PRIORITY_LOWEST,
                           err_code);
    /**@brief Function for initializing the Nordic UART Service (NUS) client. */
    static void nus_c_init(void)
        ble_nus_c_init_t init;
        init.evt_handler = ble_nus_c_evt_handler;
        err_code = ble_nus_c_init(&m_ble_nus_c, &init);
    /**@brief Function for initializing buttons and leds. */
    static void buttons_leds_init(void)
        bsp_event_t startup_event;
        err_code = bsp_init(BSP_INIT_LEDS, bsp_event_handler);
    /**@brief Function for initializing the timer. */
    static void timer_init(void)
    /**@brief Function for initializing the nrf log module. */
    static void log_init(void)
    /** @brief Function for initializing the database discovery module. */
    static void db_discovery_init(void)
        ret_code_t err_code = ble_db_discovery_init(db_disc_handler);
     * @details Handles any pending log operations, then sleeps until the next event occurs.
            nrf_pwr_mgmt_run();
        // Initialize.
        log_init();
        timer_init();
        uart_init();
        buttons_leds_init();
        db_discovery_init();
        power_management_init();
        ble_stack_init();
        gatt_init();
        nus_c_init();
        //scan_init();
        scan_init_List();
        // Start execution.
        printf("BLE UART central example started.\r\n");
        NRF_LOG_INFO("BLE UART central example started.");
        scan_start();
        // Enter main loop.
        for (;;)
            idle_state_handle();
  • I do not immediately see the problem. But going back to your post from two days ago you wrote that there is a system reset. As I mentioned, that is typically due to an error check so seeing which error check was hit and what the error code was will typically show you the issue in a few minutes. Can you check that? (You can refer to this blog post for an intro into error handling in the SDK if that is new to you).
