Android phone loses bonding information when trying to read characteristic
I have an issue with bonding between a PCA10040 running the sample Glucose app and an Acer tablet running Android 7 and nRF Toolbox. I have not seen the problem on a second (Asus) tablet or a Samsung phone (Android 8). I can set up a bond and interact with the peripheral, but when I try to connect a second time, the peripheral disconnects immediately and then the tablet loses its bonding after about 19s.
Here is a typical sequence (although other variants also occur):
1   Ensure the peripheral is removed from the Paired Devices list on the tablet.
2   Remove pairing from the peripheral by holding down Button 2 during power on.
3   Run the nRF Toolbox Glucose monitor app and connect to the peripheral. The peripheral prints a passkey which I enter. Toast says the device is now bonded and I see it appears in the Paired Devices list on the tablet.
4   I use nRF Toolbox to disconnect from the peripheral, then attempt to connect again. The peripheral appears in the list of "Bonded devices".
5   The peripheral reports "Glucose example started, Fast advertising, Connected, Connection secured: role: Peripheral, conn_handle: 0, procedure: Encryption,  Link secured. Role: 1. conn_handle: 0, Procedure: 0, Fast advertising, Disconnected".  The disconnect is immediate.
6   The app does not immediately notice that the peripheral has disconnected. After a while the "Disconnect" button changes to "Connect"
7   When I click on "Connect" the peripheral now appears in the "Available devices" section in the "Select device:" dialog, rather than the "Paired Devices" section. Furthermore, if I go to Settings>Bluetooth, it also appears in the "Available devices" section. In other words, the tablet has forgotten the pairing. The peripheral presumably thinks it is still paired.
8   If I try to connect in nRF Toolbox, the app makes a sound, Toast says "bonding with the device", the peripheral prints "Connected", then after a delay, Toast says "bonding failed" and the peripheral prints: "BLE_GAP_EVT_AUTH_STATUS: status=0x1 bond=0x0 lv4: 0 kdist_own:0x0 kdist_peer:0x0, Fast advertising, Disconnected".
At this stage the only way to recover is to remove the pairing from the peripheral.
When I look at the nRF logs, in the failure case errors start when nRF Toolbox tries to read the battery characteristic. Typically I see error (0x85). In some log files (but not all) I see "[Broadcast] Action received: android.bluettoth.device.action.BOND_STATE_CHANGED, bond state changed to: BOND_NONE (10)"
I see the problems when I use nRF Toolkit downloaded from Playstore and built from the Github Master branch.
Sometimes the app makes a sound, Toast says "Bonding with the device" but the dialog asking for the passkey does not appear, and the peripheral does not print a passkey.
I can predict when the loss of pairing is about to happen. I go to the Settings Bluetooth screen and see the peripheral in the list of bonded devices. After a few sections I see Toast "Error on reading characteristic 133" error, and at the same moment the peripheral moves from the "Bonded devices" list to the "Available devices" list. In the case, nRF Logger shows the app is trying to read teh battery characteristic, then about 19s later the BOND_STATE_CHANGE message is printed, then the Error (0x85). Note in this case that while the tablet thinks it is connected, the peripheral has disconnected almost immediately after it connected.
  • I have PCA10059 dongles but it looks like the sniffer does not work with these. Can this be done?
    PCA10059 is currently not supported by the nRF Sniffer.
    Or could I run the Glucose app on the dongle?
    That is possible. To simplify things, it might be easier to use static passkey with the dongle.
    Can you comment on the fix reported in one of the links above? I don't know how I can do that.
    Link 1: The workaround was to delay the connection parameter update request. If the connection parameters is not within the min/max values, it will send a request after FIRST_CONN_PARAMS_UPDATE_DELAY, which is set to 5 sec in the ble_app_gls example. You could try to set it to 15 sec instead.
    Link 2: Same thing here as in link 1.
    AFAIK, neither nRF Logger nor the glucose app reports on either conn param negotiation or encryption events. Can these be turned on and examined?
    Do you have "VERBOSE" logging on the app? On the nRF52 you could set PM_LOG_LEVEL to 4, and NRF_LOG_DEFAULT_LEVEL to 4 in sdk_config.h
    You could also test with older versions of the SDK, to see if you have the samme issue here. E.g. test with SDK 12.3.
  • (1) I obtained a second nRF52 to act as a sniffer. However it does not decrypt encrypted packets -  see devzone.nordicsemi.com/.../nrf-sniffer-decryption-is-not-working-after-entering-passkey
    (2) I extended FIRST_CONN_PARAMS_UPDATE_DELAY from 5s to 15s but it did not fix the problem. Note that is NOT the fix applied by Seth Foster (see link above) who said "start_on_notify_cccd_handle to a handle that is always set to notify after connection" - what does that mean?
    (3)    I then tried the SDK12.3, which also gave problems (not identical), then started digging into the code in both versions that established a secure connection. Full details follow but the problem seems to be when both the Central and Peripheral try to initiate encryption. Looks like the Asus tablet handles that badly and ends up deleting bonding data. One hack is to stop the peripheral initiating encryption, but from comments in the source it looks like that might be needed for some Central devices. It looks like another fix is to reduce PM_HANDLER_SEC_DELAY_MS from 400ms to 100ms (but what is safe?).
    Does Nordic have documentation on which device should initiate encryption, and when?
    Full results for both SDKs follow in the next post, to avoid clutter.
  • Experiments with both SDKs and different security delays follow.
    With SDK12.3  (Summary: works with a 100ms security delay but not with 400ms or 900ms. Bug fix found.)
    Code in main.c sets up a delayed call to pm_conn_secure() to secure the communications. This is triggered after
    BLE_GAP_EVT_CONNECTED events (connection established) and PM_EVT_BONDED_PEER_CONNECTED events ("Connected to a previously bonded device.")
    The delay is set by SECURITY_REQUEST_DELAY, initially at 400ms.
    On the first connection (not bonded) this is the sequence:
        BLE_GAP_EVT_CONNECTED event (connection established)
        A delayed call to sec_req_timeout_handler() and pm_conn_secure()
        This triggers the passkey activity.
        PM_EVT_CONN_SEC_SUCCEEDED event ("Link secured")
        Works OK until the Central disconnects.
    On the second connection and a 100ms delay this is the sequence:
        PM_EVT_BONDED_PEER_CONNECTED event ("Connected to a previously bonded device.")
        One delayed call to sec_req_timeout_handler() and pm_conn_secure()
        (Works OK: stays connected until the Central disconnects)
        (Same with Asus tablet)
    On the second connection and a 400ms delay this is the sequence:
        Disconnect, reason 61. The Acer loses bonding info after about 20s.
        (On the Asus tablet at 400ms I get _two_ PM_EVT_CONN_SEC_SUCCEEDED events)
    On the second connection and a 900ms delay this is the sequence:
        PM_EVT_CONN_SEC_SUCCEEDED event ("Link secured") - this must be because the Central requests it.
        Only then do I make the delayed call to pm_conn_secure()
        Sometimes an immediate disconnect, reason 61. The Acer loses bonding info after about 20s.
        Other times the Acer loses bonding information after about 20s and the the peripheral disconnects, reason 19
        (On the Asus tablet I get PM_EVT_CONN_SEC_SUCCEEDED, then the delayed call to pm_conn_secure(), then a second PM_EVT_CONN_SEC_SUCCEEDED)
    Perhaps: both Central and Peripheral attempt to establish encrypted communications (note the _two_ PM_EVT_CONN_SEC_SUCCEEDED
    events seen with the Asus). Perhaps there is trouble in this case.
    Bug fix: I set the delay to 900ms then added code to stop the delay timer on the PM_EVT_CONN_SEC_SUCCEEDED event.
    This means the peripheral relies on the central to invoke encryption.
    Tested with phone and both tablets.
    With SDK 15.2 (Summary: works with a 100ms or 900ms security delay but not with 400ms. Bug fix found.)
    The delayed call to pm_conn_secure() is moved to pm_handler_secure_on_connection() in components/ble/peer_manager/peer_manager_handler.c
    It is defined by PM_HANDLER_SEC_DELAY_MS in sdk_config.h initially as 400ms
        A delayed call to delayed_conn_secure() and pm_conn_secure()
        (Same on the Asus tablet)
        Disconnected, reason 61. The Acer loses bonding info after about 20s.
        (The Asus tablet has the same sequence except it receives _two_ PM_EVT_CONN_SEC_SUCCEEDED events, and works correctly).
    Behaviour is similar to SDK12.3 (except it works with long and short security delays but not the default.)
    in peer_manager_handler.c. This means the peripheral relies on the central to invoke encryption.
  • Hi Sigurd - do you have any comment on the results I report above? "the problem seems to be when both the Central and Peripheral try to initiate encryption. "
    Or an answer to my question "Does Nordic have documentation on which device should initiate encryption, and when?"
    I’m happy to see that changing the delay-timer fixed the issue.
    When the security timer expires, and the link is not secure, we will as the slave send a "Security Request Packet", this is used by the slave to request that the master initiates security with the requested security properties. From the description, it seems like the Acer tablet is also trying to initiate security and pairing around the same time, and the Acer tablet is not able to handle this.
    I'm not aware of any explicit documentation on this, except the bluetooth specification. But it's typically initiated after paring/bonding, and it's the master that sends the LL_ENC_REQ.
