Unable to convert to Long Range after looking at umpteen examples :-(
Using SDK 15.2, PCA10056 Dev Kit. Segger Embedded Studio. s140_nrf52_6.1.0_softdevice.hex
Our Code (non Long Range) works perfectly! We are using it in a test for a customer. The code is based on the UART example.
However, we want more range, and want to test Long Range.
Note: I am NOT experienced in this field, but managed to get the existing code working after 8 weeks of work.
We do not have this amount of time to spend now...
For weeks I have looked at at least 5 different examples, but nothing I have tried works with my code.
Part of the problem is that there seems to be many approaches to configuring for long range, and most examples are not complete.
The last example I tried to follow, is this one:
Ref 1: devzone.nordicsemi.com/.../sdk15-long-advertising-and-long-range-connect
It is supposed to show the difference between the standard UART example and the conversion to Long Range.
If I follow that example, the Peripheral returns Error = 7 (Invalid Parameter) in call to:
- ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
- sd_ble_gap_adv_set_configure()
What confuses, is that many examples e.g. sets
adv_params.properties.type = BLE_GAP_ADV_TYPE_EXTENDED_CONNECTABLE_NONSCANNABLE_UNDIRECTED;
but there is no sign of such code in Ref 1 above...
Please, please help converting this example to use Long Range!
Please do not just refer to general descriptions, as I have tried to follow them for weeks with no success....
Code for Advertising and Scanning from Peripheral and Central follow below:
----------------- ble_app_uart START ----------------------------------
#define APP_ADV_INTERVAL 300
#define APP_ADV_DURATION 0
BLE_ADVERTISING_DEF(m_advertising);
uint32_t err_code;
switch (ble_adv_evt)
case BLE_ADV_EVT_FAST:
case BLE_ADV_EVT_IDLE:
uint32_t err_code;
ble_advertising_init_t init;
init.advdata.name_type = BLE_ADVDATA_FULL_NAME;
//init.advdata.include_appearance = false;
init.advdata.include_appearance = true; // Changed to True from ble_app_hrs example
// ONLY General Discovery Mode
init.advdata.flags = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
init.srdata.uuids_complete.p_uuids = m_adv_uuids;
init.config.ble_adv_fast_enabled = true;
init.config.ble_adv_fast_timeout = APP_ADV_DURATION;
static void advertising_start() {
ret_code_t err_code;
err_code = ble_advertising_start(&m_advertising, BLE_ADV_MODE_FAST);
----------------- ble_app_uart END ----------------------------------
----------------- ble_app_uart_c START ----------------------------------
#define APP_BLE_CONN_CFG_TAG 1
#define SCAN_SCAN_DURATION_PAIR 3000
static void scan_evt_handler(scan_evt_t cons t * p_scan_evt)
//p_scan_evt->params.p_whitelist_adv_report->peer_addr
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_WHITELIST_REQUEST:
NRF_LOG_INFO("NRF_BLE_SCAN_EVT_WHITELIST_REQUEST");
NRF_LOG_FLUSH();
on_whitelist_req();
m_whitelist_disabled = false;
} break;
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
NRF_LOG_INFO("scan_evt_handler()>>NRF_BLE_SCAN_EVT_CONNECTING_ERROR: %d ", err_code);
NRF_LOG_FLUSH();
} break;
case NRF_BLE_SCAN_EVT_CONNECTED:
NRF_LOG_INFO("NRF_BLE_SCAN_EVT_CONNECTED");
NRF_LOG_FLUSH();
ble_gap_evt_connected_t const * p_connected =
p_scan_evt->params.connected.p_connected;
// Scan is automatically stopped by the connection.
NRF_LOG_INFO("Connecting to target %02x%02x%02x%02x%02x%02x",
p_connected->peer_addr.addr[0],
p_connected->peer_addr.addr[1],
p_connected->peer_addr.addr[2],
p_connected->peer_addr.addr[3],
p_connected->peer_addr.addr[4],
p_connected->peer_addr.addr[5]
} break;
case NRF_BLE_SCAN_EVT_SCAN_TIMEOUT:
NRF_LOG_INFO("NRF_BLE_SCAN_EVT_SCAN_TIMEOUT");
NRF_LOG_FLUSH();
//scan_start(); /// GOS Should Not Scan here again !
} break;
case NRF_BLE_SCAN_EVT_FILTER_MATCH:
NRF_LOG_INFO("NRF_BLE_SCAN_EVT_FILTER_MATCH");
NRF_LOG_FLUSH();
case NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT:
NRF_LOG_INFO("NRF_BLE_SCAN_EVT_WHITELIST_ADV_REPORT");
NRF_LOG_FLUSH();
case NRF_BLE_SCAN_EVT_NOT_FOUND:
static void scan_init()
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
m_scan_param.timeout = SCAN_SCAN_DURATION_PAIR;
init_scan.p_scan_param = &m_scan_param;
init_scan.connect_if_match = true;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_UUID_FILTER, &m_nus_uuid);
err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_UUID_FILTER, false);
static void scan_start(void)
if (nrf_fstorage_is_busy(NULL)) // Added from ble_app_hrs_c
m_memory_access_in_progress = true;
return;
NRF_LOG_INFO("Start Scanning");
NRF_LOG_FLUSH();
ret_code_t ret;
ret = nrf_ble_scan_start(&m_scan);
APP_ERROR_CHECK(ret);
----------------- ble_app_uart_c END ----------------------------------
  •   Hi,
          How to do  these library  nRF5_SDK_15.2.0_mod.zip  make compatible with nrf5_SDK_17.2.0.
    You can see modifications I made for these 2 example in the 'diff' file below. It should not be much different in SDK 17.0.2
    diff --git a/examples/ble_central/ble_app_uart_c/main.c b/examples/ble_central/ble_app_uart_c/main.c
    index 5c6ffd5..c53297b 100644
    --- a/examples/ble_central/ble_app_uart_c/main.c
    +++ b/examples/ble_central/ble_app_uart_c/main.c
    @@ -116,6 +116,10 @@ static void scan_start(void)
         ret = bsp_indication_set(BSP_INDICATE_SCANNING);
    +    //Optional: Change output power
    +    ret = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT, 0, 8);
    +    APP_ERROR_CHECK(ret);
    @@ -164,13 +168,25 @@ static void scan_evt_handler(scan_evt_t const * p_scan_evt)
     static void scan_init(void)
    -    ret_code_t          err_code;
    -    nrf_ble_scan_init_t init_scan;
    +    ret_code_t            err_code;
    +    nrf_ble_scan_init_t   init_scan;
    +    ble_gap_scan_params_t scan_params;
    +    memset(&scan_params, 0, sizeof(ble_gap_scan_params_t));
    +    scan_params.active        = 1;
    +    scan_params.interval      = NRF_BLE_SCAN_SCAN_INTERVAL;
    +    scan_params.window        = NRF_BLE_SCAN_SCAN_WINDOW;
    +    scan_params.timeout       = NRF_BLE_SCAN_SCAN_DURATION;
    +    scan_params.filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL;
    +    scan_params.scan_phys     = BLE_GAP_PHY_CODED;
    +    scan_params.extended      = true;
    +    init_scan.p_scan_param     = &scan_params;
    diff --git a/examples/ble_central/ble_app_uart_c/pca10056/s140/config/sdk_config.h b/examples/ble_central/ble_app_uart_c/pca10056/s140/config/sdk_config.h
    index bb9c621..8ff8018 100644
    --- a/examples/ble_central/ble_app_uart_c/pca10056/s140/config/sdk_config.h
    +++ b/examples/ble_central/ble_app_uart_c/pca10056/s140/config/sdk_config.h
    @@ -127,7 +127,7 @@
     // <o> NRF_BLE_SCAN_BUFFER - Data length for an advertising set.
     #ifndef NRF_BLE_SCAN_BUFFER
    -#define NRF_BLE_SCAN_BUFFER 31
    +#define NRF_BLE_SCAN_BUFFER 255
     // <o> NRF_BLE_SCAN_NAME_MAX_LEN - Maximum size for the name to search in the advertisement report.
    @@ -184,7 +184,7 @@
     // <255=> BLE_GAP_PHY_NOT_SET
     #ifndef NRF_BLE_SCAN_SCAN_PHY
    -#define NRF_BLE_SCAN_SCAN_PHY 1
    +#define NRF_BLE_SCAN_SCAN_PHY 4
     // <e> NRF_BLE_SCAN_FILTER_ENABLE - Enabling filters for the Scanning Module.
    @@ -12394,7 +12394,7 @@
     // <i> Requested BLE GAP data length to be negotiated.
     #ifndef NRF_SDH_BLE_GAP_DATA_LENGTH
    -#define NRF_SDH_BLE_GAP_DATA_LENGTH 251
    +#define NRF_SDH_BLE_GAP_DATA_LENGTH 27
     // <o> NRF_SDH_BLE_PERIPHERAL_LINK_COUNT - Maximum number of peripheral links.
    @@ -12423,7 +12423,7 @@
     // <o> NRF_SDH_BLE_GATT_MAX_MTU_SIZE - Static maximum MTU size.
     #ifndef NRF_SDH_BLE_GATT_MAX_MTU_SIZE
    -#define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 247
    +#define NRF_SDH_BLE_GATT_MAX_MTU_SIZE 23
     // <o> NRF_SDH_BLE_GATTS_ATTR_TAB_SIZE - Attribute Table size in bytes. The size must be a multiple of 4.
    diff --git a/examples/ble_peripheral/ble_app_uart/main.c b/examples/ble_peripheral/ble_app_uart/main.c
    index 4d40d21..a42a8c7 100644
    --- a/examples/ble_peripheral/ble_app_uart/main.c
    +++ b/examples/ble_peripheral/ble_app_uart/main.c
    @@ -616,12 +616,15 @@ static void advertising_init(void)
         init.advdata.flags              = BLE_GAP_ADV_FLAGS_LE_ONLY_LIMITED_DISC_MODE;
    -    init.srdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    -    init.srdata.uuids_complete.p_uuids  = m_adv_uuids;
    -    init.config.ble_adv_fast_enabled  = true;
    -    init.config.ble_adv_fast_interval = APP_ADV_INTERVAL;
    -    init.config.ble_adv_fast_timeout  = APP_ADV_DURATION;
    +    init.advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    +    init.advdata.uuids_complete.p_uuids  = m_adv_uuids;
    +    init.config.ble_adv_fast_enabled      = true;
    +    init.config.ble_adv_fast_interval     = APP_ADV_INTERVAL;
    +    init.config.ble_adv_fast_timeout      = APP_ADV_DURATION;
    +    init.config.ble_adv_primary_phy       = BLE_GAP_PHY_CODED;
    +    init.config.ble_adv_secondary_phy     = BLE_GAP_PHY_CODED;
    +    init.config.ble_adv_extended_enabled  = true;
    @@ -687,6 +690,10 @@ static void advertising_start(void)
    +    err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_ADV, m_advertising.adv_handle, 8);
    +    APP_ERROR_CHECK(err_code);
