couldn't find mesh sdk 2.1.1 download link and need some help in the modification of the simple onoff model to send string in the mesh network
hello nordic ,
i want to download the mesh SDK 2.1.1 to use the light switch example to transform the model simple onoff from sending uint8_t to string ,
i have started modifying it but had so many mistakes done and couldn't come back to the first mesh sdk without any modification and i wanted to download it again but didn't find it
so can any body tell me how can i download it , and second can i have some help or some indications on how to modify it
i have a very important project that is going to include about thousands SoC
thank you
  • That's really obscure!
    And, as noted, the download links in the infocentre documentation need to be made far more visible.
  • is there a simple message example for v2.2.0 or can you support me on transforming the simple onoff model from sending 1 or 0 to sending string
    in the b2.1.1 i could send string with simple message unreliable fonction from client to server but when i want to send it with reliable funtion server doesn't answer always i get  No reply from  server x ( x=0,1,2,3)
  • Aswell it's not working , couldn't provision the servers
    0> <t: 1179>, main.c, 583, <t: 0>, main.c, 561, ----- BLE Mesh Light Switch Provisioner Demo -----
    0> <t: 0>, mesh_softdevice_init.c, 117, Initializing SoftDevice...
    0> <t: 0>, mesh_softdevice_init.c, 75, Enabling BLE...
    0> <t: 16>, mesh_softdevice_init.c, 109, sd_ble_enable: app_ram_base should be adjusted to 0x20002DA0
    0> <t: 555>, main.c, 499, Initializing and adding models
    0> <t: 585>, main.c, 452, Restored: App data
    0> <t: 587>, main.c, 551, Restored: Handles
    0> <t: 590>, provisioner_helper.c, 307, m_netkey_handle:0 m_appkey_handle:0 m_self_devkey_handle:1
    0> <t: 597>, main.c, 591, <start>
    0> <t: 676>, main.c, 404, Mesh evt: FLASH_STABLE
    0> <t: 678>, main.c, 578, Starting application ...
    0> <t: 680>, main.c, 580, Provisoned Nodes: 0, Configured Nodes: 0 Next Address: 0x0100
    0> <t: 684>, main.c, 581, Dev key : 6367FE1223F087DC0570A1C554F86DC6
    0> <t: 687>, main.c, 582, Net key : 0AFB51A4ED17362B158498D3FE0B8C0D
    0> <t: 690>, main.c, 583, App key : F61B9FB95B2037032CF71D1CDF0CAC7B
    0> <t: 693>, main.c, 584, Press Button 1 to start provisioning and configuration process.
    0> <t: 254042>, main.c, 459, Button 1 pressed
    0> <t: 254044>, main.c, 364, Waiting for Client node to be provisioned ...
    0> <t: 258819>, provisioner_helper.c, 288, Scanning For Unprovisioned Devices
    0> <t: 291727>, provisioner_helper.c, 143, UUID seen: 005955AA00000000BC32E7B859AC6FFE
    0> <t: 303182>, provisioner_helper.c, 143, UUID seen: 0059CCAA000000006846AB371D9B6F19
    0> <t: 303185>, provisioner_helper.c, 95, UUID filter matched
    0> <t: 303577>, provisioner_helper.c, 263, Provisioning link established
    0> <t: 316948>, provisioner_helper.c, 258, Static authentication data provided
    0> <t: 328810>, provisioner_helper.c, 196, Provisioning completed received
    0> <t: 328813>, provisioner_helper.c, 201, Adding device address, and device keys
    0> <t: 328819>, provisioner_helper.c, 218, Addr: 0x0100 addr_handle: 0 netkey_handle: 0 devkey_handle: 2
    0> <t: 329030>, main.c, 404, Mesh evt: FLASH_STABLE
    0> <t: 329033>, main.c, 404, Mesh evt: FLASH_STABLE
    0> <t: 332780>, provisioner_helper.c, 159, Local provisioning link closed: prov_state: 2 remaining retries: 2
    0> <t: 332785>, main.c, 285, Provisioning successful
    0> <t: 332787>, provisioner_helper.c, 185, Provisioning complete. Node addr: 0x0100 elements: 3
    0> <t: 332791>, provisioner_helper.c, 95, UUID filter matched
    0> <t: 332793>, node_setup.c, 661, Configuring Node: 0x0100
    0> <t: 332796>, node_setup.c, 551, Config client setup: devkey_handle:2 addr_handle:0
    0> <t: 332800>, node_setup.c, 343, Getting composition data
    0> <t: 332809>, access.c, 408, TX: [aop: 0x8008]
    0> <t: 332812>, access.c, 409, TX: Msg: 00
    0> <t: 332868>, main.c, 114, Flash write complete
    0> <t: 332871>, main.c, 404, Mesh evt: FLASH_STABLE
    0> <t: 332954>, main.c, 419, Unhandled Mesh Event: 1
    0> <t: 352039>, access.c, 241, RX: [aop: 0x0002]
    0> <t: 352042>, main.c, 335, Config client event
    0> <t: 352044>, node_setup.c, 353, Adding appkey
    0> <t: 352062>, access.c, 408, TX: [aop: 0x0000]
    0> <t: 352064>, access.c, 409, TX: Msg: 000000F61B9FB95B2037032CF71D1CDF0CAC7B
    0> <t: 352069>, main.c, 419, Unhandled Mesh Event: 0
    0> <t: 354149>, main.c, 419, Unhandled Mesh Event: 1
    0> <t: 355009>, access.c, 241, RX: [aop: 0x8003]
    0> <t: 355012>, main.c, 335, Config client event
    0> <t: 355014>, node_setup.c, 258, opcode status field: 0
    0> <t: 355017>, node_setup.c, 364, App key bind: Health server
    0> <t: 355026>, access.c, 408, TX: [aop: 0x803D]
    0> <t: 355028>, access.c, 409, TX: Msg: 000100000200
    0> <t: 355032>, main.c, 419, Unhandled Mesh Event: 0
    0> <t: 355078>, main.c, 419, Unhandled Mesh Event: 1
    0> <t: 355782>, access.c, 241, RX: [aop: 0x803E]
    0> <t: 355786>, main.c, 335, Config client event
    0> <t: 355788>, node_setup.c, 258, opcode status field: 0
    0> <t: 355790>, node_setup.c, 432, Setting publication address for the health server to 0x0001
    0> <t: 355806>, access.c, 408, TX: [aop: 0x0003]
    0> <t: 355809>, access.c, 409, TX: Msg: 0001010000001E81010200
    0> <t: 355812>, main.c, 419, Unhandled Mesh Event: 0
    0> <t: 357314>, main.c, 419, Unhandled Mesh Event: 1
    0> <t: 358980>, access.c, 241, RX: [aop: 0x8019]
    0> <t: 358984>, main.c, 335, Config client event
    0> <t: 358986>, node_setup.c, 258, opcode status field: 0
    0> <t: 358988>, node_setup.c, 398, App key bind: 0x1001 client on element 0x0101
    0> <t: 358999>, access.c, 408, TX: [aop: 0x803D]
    0> <t: 359001>, access.c, 409, TX: Msg: 010100000110
    0> <t: 359004>, main.c, 419, Unhandled Mesh Event: 0
    0> <t: 360604>, main.c, 419, Unhandled Mesh Event: 1
    0> <t: 361059>, access.c, 241, RX: [aop: 0x803E]
    0> <t: 361063>, main.c, 335, Config client event
    0> <t: 361065>, node_setup.c, 258, opcode status field: 2
    0> <t: 361067>, main.c, 278, Configuration of device 0 failed. Press Button 1 to retry.
    0> <t: 361071>, main.c, 419, Unhandled Mesh Event: 0
    0> <t: 684827>, access.c, 241, RX: [aop: 0x0004]
    0> <t: 684830>, main.c, 314, Node 0x0100 alive with 0 active fault(s), RSSI: -44
    0> <t: 684833>, main.c, 419, Unhandled Mesh Event: 0
    0> <t: 1012444>, access.c, 241, RX: [aop: 0x0004]
    0> <t: 1012447>, main.c, 314, Node 0x0100 alive with 0 active fault(s), RSSI: -32
    0> <t: 1012450>, main.c, 419, Unhandled Mesh Event: 0
    0> <t: 1340078>, access.c, 241, RX: [aop: 0x0004]
