hello,ESP32 ble scanner is not scanning my custom made beacon (nrf52832),I have programmed ble_app_beacon apllication in tag and ESP32 is scanning all ibeacon except our custom board tag.please help.thanks.
I have to say I agree with Awneil, that this is an ESP32 issue. I would guess you are doing some sort of filtering or whitelist not compatible with the custom beacon.
More unlikely, There is also a possibility there is something wrong with your HW that makes it incompatible with the ESP32 but still works with nRF connect. But this is unlikely.
esp32 is ... a chip microcontroller
Yes - but what is this "ESP32 ble scanner" that you are talking about?
A microcontroller on its own does nothing - it needs both supporting hardware and software to form a functioning product.
More specifically, it's most likely an issue with whatever software is running on the ESP32.
Indeed - which would be a software thing.
As noted above, there might be a signal strength threshold ...
May also be affected by the hardware of the mystery "ble scanner" that kiranj seems so loathe to describe.
Again, none of those things has anything to do with Nordic.
Indeed.
So an obvious next step should be for kiranj to try another scanner (or scanners) - there are plenty of apps available to do that.
If other scanners "see" the custom beacon, the conclusion should be obvious...
thanks for your suggestions.I'm also thinking that ESP32 is not compatible with these tags.
I'm also (sic) thinking that ESP32 is not compatible with these tags
Nobody else is saying that.
Clearly your unit - which you have still not identified - is compatible, because it manages to see one of your tags!
So you need to investigate your ESP32 code to see where & why it is filtering-out the other tag.
But that, again, has nothing to do with Nordic.
You still haven't answered the question about signal levels.
