Periodic messages from server to client in Light_switch example
Hi guys,
I am trying to modify Light switch example. My goal is to create a mesh network to transfer data from server to client periodically. So far, what I have done is to create a timer in server and set it in repeated mode. When I send message on from client to server, it starts the timer and start to call the function: app_onoff_status_publish(&m_onoff_server_0);
However, when I log this function access_model_publish(); which is the function to actually send the status data, it returns 7, which is invalid params?
Here is my code in main.c in sever side:
APP_TIMER_DEF(timer_id);
static void timer_handler(void *p_context)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "handler!\r\n");
static void timers_create()
    ret_code_t err_code;
	// timeout_id :
	err_code = app_timer_create(&timer_id, APP_TIMER_MODE_REPEATED, timer_handler);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "app_timer_create error: %d\r\n", err_code);
// END ---------------------------------------
static void timer_start(uint16_t time)
	err_code = app_timer_start(timer_id, APP_TIMER_TICKS(time), NULL);
     __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "app_timer_start error: %d\r\n", err_code);
static void timer_stop()
	app_timer_stop(timer_id);
/* Callback for updating the hardware state */
static void app_onoff_server_set_cb(const app_onoff_server_t * p_server, bool onoff)
    /* Resolve the server instance here if required, this example uses only 1 instance. */
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "Setting GPIO value: %d\n", onoff)
    hal_led_pin_set(ONOFF_SERVER_0_LED, onoff);
    if(onoff)
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "start timer here!\r\n");
      timer_start(1000);
    __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "stop timer here!\r\n");
      timer_stop();
And here is what I have in file generic_onoff_server.c, simply just log the function:
static uint32_t status_send(generic_onoff_server_t * p_server,
                            const access_message_rx_t * p_message,
                            const generic_onoff_status_params_t * p_params)
    uint32_t error_code;
    generic_onoff_status_msg_pkt_t msg_pkt;
    if (p_params->present_on_off > GENERIC_ONOFF_MAX ||
        p_params->target_on_off  > GENERIC_ONOFF_MAX ||
        p_params->remaining_time_ms > TRANSITION_TIME_STEP_10M_MAX)
        return NRF_ERROR_INVALID_PARAM;
    msg_pkt.present_on_off = p_params->present_on_off;
    if (p_params->remaining_time_ms > 0)
        msg_pkt.target_on_off = p_params->target_on_off;
        msg_pkt.remaining_time = model_transition_time_encode(p_params->remaining_time_ms);
    access_message_tx_t reply =
        .opcode = ACCESS_OPCODE_SIG(GENERIC_ONOFF_OPCODE_STATUS),
        .p_buffer = (const uint8_t *) &msg_pkt,
        .length = p_params->remaining_time_ms > 0 ? GENERIC_ONOFF_STATUS_MAXLEN : GENERIC_ONOFF_STATUS_MINLEN,
        .force_segmented = p_server->settings.force_segmented,
        .transmic_size = p_server->settings.transmic_size
    if (p_message == NULL)
        error_code = access_model_publish(p_server->model_handle, &reply);
        __LOG(LOG_SRC_APP, LOG_LEVEL_INFO, "access_model_publish error_code: %d\n", error_code);
        return error_code;
        return error_code;
And here is the result:
And nothing have been received from the client side.
How can I fix this?
Thank you very much guys.
  • Hi Hust,
    i have this problem also, i can send message from light_switch_client to server ok, then server send reply to client using status_send(), and this call "access_model_publish(p_server->model_handle, &reply);" return SUCCESS but server side does not receives any thing.
    I setup pub/sub as below:
    Server publish to 0xC000
    Client subscribe to 0xC000
    I try to add callback function in client code to capture rx_event 'nrf_mesh_evt_handler_add(..) but never receive any message from server. That's strange!
    My goal is server will send reply to client when he receive from client.
    Can you give me any suggest!
    Thanks in advance!
