ble_app_buttonless_dfu reset on pin interrupt
Hello Nordic team
I am working on nRF52832 Dk, SDK v15.2, example "ble_app_buttonless_dfu".
Following code snippets is the GPIO configuration for pin interrupt:
ret_code_t err_code;
nrf_drv_gpiote_in_config_t in_config = GPIOTE_CONFIG_IN_SENSE_LOTOHI(true);
in_config.sense = NRF_GPIOTE_POLARITY_LOTOHI;
err_code = nrf_drv_gpiote_in_init(ACCEL_INT_PIN, &in_config, in_pin_handler);
nrf_drv_gpiote_in_event_enable(ACCEL_INT_PIN, true);
ble_app_buttonless_dfu working correctly (OTA update). I have added support for accelerometer when any pin interrupt received on gpio pin as soon as board get reseted and print following message on serial console:
<warning> app: System reset
<info> app: Setting vector table to bootloader: 0x00078000
<info> app: Setting vector table to main app: 0x00026000
<info> app: Buttonless DFU Application started.
<info> app: INT detected
<error> app: Fatal error
Any suggestion why board reset after received GPIO interrupt?
Any help will be appreciated.
Regards
Raj
  • Timer initialization: APP_TIMER_DEF(data_logging_id);
    Timer creation:
    err_code = app_timer_create(&data_logging_id, APP_TIMER_MODE_REPEATED, data_logging_timeout_handler);
    Timer start: app_timer_start(data_logging_id, DATA_LOGGING_INTERVAL , NULL);
    - Actually I am using same timer multiple time with different timeout value. So, before loading different timeout value I am stopping the timer and then load new vale and start but. Some timer timer start correctly and working well but some timer it return error when starting.
  • Please add a breakpoint and try to step to the code and check why the function throw NRF_ERROR_INVALID_STATE
  • Hi , @Hung Bui
    I am also faced same issue. Please give the solution for this issue.
    SDK15.2.0  and nRF52810 custom board.
    <info> app: Setting vector table to bootloader: 0x00028000
    <info> app: Setting vector table to main app: 0x00019000
    When you see an assert, please try to debug it. You can have a look at this guide.
    Please create a new case with more information how you test it with step by step.
