nrf51 add ota dfu service on hrs_scanner or ble_nus example
hi all,
I have added the dfu service in one of example of sdk_11 ble_scanner_hrs I followed all help available on this forum and made sucessfuly compiled code but it stopped advertising?
any help is appreciate I have attached my main file
/* Copyright (c) 2012 Nordic Semiconductor. All Rights Reserved.
 * The information contained herein is property of Nordic Semiconductor ASA.
 * Terms and conditions of usage are described in detail in NORDIC
 * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
 * Licensees are granted free, non-transferable use of the information. NO
 * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
 * the file.
 * @brief Heart Rate Service Sample Application main file.
 * This file contains the source code for a sample application using the Heart Rate service
 * (and also Battery and Device Information services). This application uses the
 * @ref srvlib_conn_params module.
#include <stdint.h>
#include <string.h>
#include "nordic_common.h"
#include "nrf.h"
#include "app_error.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_srv_common.h"
#include "ble_advdata.h"
#include "ble_advertising.h"
#include "ble_bas.h"
#include "ble_hrs.h"
#include "ble_dis.h"
#include "ble_conn_params.h"
#include "bsp.h"
#include "sensorsim.h"
#include "bsp_btn_ble.h"
#include "softdevice_handler.h"
#include "app_timer.h"
#include "device_manager.h"
#include "pstorage.h"
#include "app_trace.h"
#include "scanner_beacon.h"
#include "D:\SDK_Nordic\nRF5_SDK_11.0.0_89a8197\components\libraries\uart\app_uart.h"
#include "D:\SDK_Nordic\nRF5_SDK_11.0.0_89a8197\components\ble\ble_services\ble_dfu\ble_dfu.h"
#include "D:\SDK_Nordic\nRF5_SDK_11.0.0_89a8197\components\libraries\bootloader_dfu\dfu_app_handler.h"
#include "ble_nus.h"
#include "D:\SDK_Nordic\nRF5_SDK_11.0.0_89a8197\components\libraries\bootloader_dfu\bootloader.h"
#include "D:\SDK_Nordic\nRF5_SDK_11.0.0_89a8197\components\libraries\bootloader_dfu\bootloader_util.h"
#define IS_SRVC_CHANGED_CHARACT_PRESENT         1                                       /**< Include or not the service_changed characteristic. if not enabled, the server's database cannot be changed for the lifetime of the device*/
#define CENTRAL_LINK_COUNT                      0                                       /**< Number of central links used by the application. When changing this number remember to adjust the RAM settings*/
#define PERIPHERAL_LINK_COUNT                   1                                       /**< Number of peripheral links used by the application. When changing this number remember to adjust the RAM settings*/
#define SEARCHED_MAJOR                          0x1200
#define SEARCHED_MINOR                          0x3400
#define APP_COMPANY_IDENTIFIER                  0x0059                                  /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
/**@brief Function for handling a BeaconScanner event.
 * @details This function will be called each time the scanner has found an advertiser with beacon data.
 *          In this simple implementation, it checks the Major and Minor and company ID fields from the beacon data,
 *          and if they match, @ref BSP_INDICATE_ALERT_3 is indicated.
 * @param[in]   p_evt   scanner event data.
static void beacon_evt_handler(ble_scan_beacon_evt_t * p_evt)
    uint32_t err_code;
    if((p_evt->rcv_adv_packet.adv_data.major    == SEARCHED_MAJOR)
     &&(p_evt->rcv_adv_packet.adv_data.minor    == SEARCHED_MINOR)
     &&(p_evt->rcv_adv_packet.adv_data.manuf_id == APP_COMPANY_IDENTIFIER)
			  printf("\nMAJOR=%d\n",p_evt->rcv_adv_packet.adv_data.major);
			  printf("\nMINOR=%d\n",p_evt->rcv_adv_packet.adv_data.minor);
			  printf("\nNordicid=%d\n",p_evt->rcv_adv_packet.adv_data.manuf_id);
			  printf("\nrssi=%d\n",p_evt->rcv_adv_packet.adv_data.rssi);
			  printf("\nuuid=%d\n",p_evt->rcv_adv_packet.adv_data.uuid);
        err_code = bsp_indication_set(BSP_INDICATE_ALERT_3);
/**@brief Function for handling a BeaconScanner error.
static void beacon_scanner_error_handler(uint32_t nrf_error)
    APP_ERROR_HANDLER(nrf_error);
static ble_beacon_scanner_init_t m_beacon_scanner_init;
/*end addition for beacon*/
#define MAX_TEST_DATA_BYTES     (15U)                /**< max number of test bytes to be used for tx and rx. */
#define UART_TX_BUF_SIZE 256                         /**< UART TX buffer size. */
#define UART_RX_BUF_SIZE 1                           /**< UART RX buffer size. */
void uart_error_handle(app_uart_evt_t * p_event)
    if (p_event->evt_type == APP_UART_COMMUNICATION_ERROR)
    else if (p_event->evt_type == APP_UART_FIFO_ERROR)
#define DEVICE_NAME                          "Nordic_HRM_sca"                               /**< Name of device. Will be included in the advertising data. */
#define MANUFACTURER_NAME                    "NordicSemiconductor"                      /**< Manufacturer. Will be passed to Device Information Service. */
#define APP_ADV_INTERVAL                     480                                         /**< The advertising interval (in units of 0.625 ms. This value corresponds to 300 ms). */
#define APP_ADV_TIMEOUT_IN_SECONDS           180                                        /**< The advertising timeout in units of seconds. */
#define APP_TIMER_PRESCALER                  0                                          /**< Value of the RTC1 PRESCALER register. */
#define APP_TIMER_OP_QUEUE_SIZE              4                                          /**< Size of timer operation queues. */
#define BATTERY_LEVEL_MEAS_INTERVAL          APP_TIMER_TICKS(2000, APP_TIMER_PRESCALER) /**< Battery level measurement interval (ticks). */
#define MIN_BATTERY_LEVEL                    81                                         /**< Minimum simulated battery level. */
#define MAX_BATTERY_LEVEL                    100                                        /**< Maximum simulated battery level. */
#define BATTERY_LEVEL_INCREMENT              1                                          /**< Increment between each simulated battery level measurement. */
#define HEART_RATE_MEAS_INTERVAL             APP_TIMER_TICKS(1000, APP_TIMER_PRESCALER) /**< Heart rate measurement interval (ticks). */
#define MIN_HEART_RATE                       140                                        /**< Minimum heart rate as returned by the simulated measurement function. */
#define MAX_HEART_RATE                       300                                        /**< Maximum heart rate as returned by the simulated measurement function. */
#define HEART_RATE_INCREMENT                 10                                         /**< Value by which the heart rate is incremented/decremented for each call to the simulated measurement function. */
#define RR_INTERVAL_INTERVAL                 APP_TIMER_TICKS(300, APP_TIMER_PRESCALER)  /**< RR interval interval (ticks). */
#define MIN_RR_INTERVAL                      100                                        /**< Minimum RR interval as returned by the simulated measurement function. */
#define MAX_RR_INTERVAL                      500                                        /**< Maximum RR interval as returned by the simulated measurement function. */
#define RR_INTERVAL_INCREMENT                1                                          /**< Value by which the RR interval is incremented/decremented for each call to the simulated measurement function. */
#define SENSOR_CONTACT_DETECTED_INTERVAL     APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Sensor Contact Detected toggle interval (ticks). */
#define MIN_CONN_INTERVAL                    MSEC_TO_UNITS(500, UNIT_1_25_MS)           /**< Minimum acceptable connection interval (0.5 seconds). */
#define MAX_CONN_INTERVAL                    MSEC_TO_UNITS(1000, UNIT_1_25_MS)          /**< Maximum acceptable connection interval (1 second). */
#define SLAVE_LATENCY                        0                                          /**< Slave latency. */
#define CONN_SUP_TIMEOUT                     MSEC_TO_UNITS(4000, UNIT_10_MS)            /**< Connection supervisory timeout (4 seconds). */
#define FIRST_CONN_PARAMS_UPDATE_DELAY       APP_TIMER_TICKS(5000, APP_TIMER_PRESCALER) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
#define NEXT_CONN_PARAMS_UPDATE_DELAY        APP_TIMER_TICKS(30000, APP_TIMER_PRESCALER)/**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
#define MAX_CONN_PARAMS_UPDATE_COUNT         3                                          /**< Number of attempts before giving up the connection parameter negotiation. */
#define SEC_PARAM_BOND                       1                                          /**< Perform bonding. */
#define SEC_PARAM_MITM                       0                                          /**< Man In The Middle protection not required. */
#define SEC_PARAM_LESC                       0                                          /**< LE Secure Connections not enabled. */
#define SEC_PARAM_KEYPRESS                   0                                          /**< Keypress notifications not enabled. */
#define SEC_PARAM_IO_CAPABILITIES            BLE_GAP_IO_CAPS_NONE                       /**< No I/O capabilities. */
#define SEC_PARAM_OOB                        0                                          /**< Out Of Band data not available. */
#define SEC_PARAM_MIN_KEY_SIZE               7                                          /**< Minimum encryption key size. */
#define SEC_PARAM_MAX_KEY_SIZE               16                                         /**< Maximum encryption key size. */
#define DEAD_BEEF                            0xDEADBEEF                                 /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
static uint16_t                              m_conn_handle = BLE_CONN_HANDLE_INVALID;   /**< Handle of the current connection. */
static ble_bas_t                             m_bas;                                     /**< Structure used to identify the battery service. */
static ble_hrs_t                             m_hrs;      /**< Structure used to identify the heart rate service. */
static ble_dfu_t                             m_dfus;
static bool                                  m_rr_interval_enabled = true;              /**< Flag for enabling and disabling the registration of new RR interval measurements (the purpose of disabling this is just to test sending HRM without RR interval data. */
static sensorsim_cfg_t                       m_battery_sim_cfg;                         /**< Battery Level sensor simulator configuration. */
static sensorsim_state_t                     m_battery_sim_state;                       /**< Battery Level sensor simulator state. */
static sensorsim_cfg_t                       m_heart_rate_sim_cfg;                      /**< Heart Rate sensor simulator configuration. */
static sensorsim_state_t                     m_heart_rate_sim_state;                    /**< Heart Rate sensor simulator state. */
static sensorsim_cfg_t                       m_rr_interval_sim_cfg;                     /**< RR Interval sensor simulator configuration. */
static sensorsim_state_t                     m_rr_interval_sim_state;                   /**< RR Interval sensor simulator state. */
APP_TIMER_DEF(m_battery_timer_id);                                                      /**< Battery timer. */
APP_TIMER_DEF(m_heart_rate_timer_id);                                                   /**< Heart rate measurement timer. */
APP_TIMER_DEF(m_rr_interval_timer_id);                                                  /**< RR interval timer. */
APP_TIMER_DEF(m_sensor_contact_timer_id);                                               /**< Sensor contact detected timer. */
static dm_application_instance_t             m_app_handle;                              /**< Application identifier allocated by device manager */
static ble_nus_t                        m_nus;                                      /**< Structure to identify the Nordic UART Service. */
//static uint16_t                         m_conn_handle = BLE_CONN_HANDLE_INVALID;    /**< Handle of the current connection. */
//static ble_uuid_t                       m_adv_uuids[] = {{BLE_UUID_NUS_SERVICE, NUS_SERVICE_UUID_TYPE}};  /**< Universally unique service identifier. */
static ble_uuid_t m_adv_uuids[] =                                                       /**< Universally unique service identifiers. */
    {BLE_UUID_HEART_RATE_SERVICE,         BLE_UUID_TYPE_BLE},
    {BLE_UUID_BATTERY_SERVICE,            BLE_UUID_TYPE_BLE},
    {BLE_UUID_DEVICE_INFORMATION_SERVICE, BLE_UUID_TYPE_BLE}
 *          a string. The string will be be sent over BLE when the last character received was a
 *          'new line' i.e '\n' (hex 0x0D) or if the string has reached a length of
 *          @ref NUS_MAX_DATA_LENGTH.
/**@snippet [Handling the data received over UART] */
    static uint8_t index = 0;
    uint32_t       err_code;
    switch (p_event->evt_type)
        case APP_UART_DATA_READY:
            index++;
            if ((data_array[index - 1] == '\n') || (index >= (BLE_NUS_MAX_DATA_LEN)))
                err_code = ble_nus_string_send(&m_nus, data_array, index);
                index = 0;
        case APP_UART_FIFO_ERROR:
void uart_inti()
	  uint32_t err_code;
    const app_uart_comm_params_t comm_params =
          RX_PIN_NUMBER,
          TX_PIN_NUMBER,
          RTS_PIN_NUMBER,
          CTS_PIN_NUMBER,
          APP_UART_FLOW_CONTROL_ENABLED,
          false,
          UART_BAUDRATE_BAUDRATE_Baud115200
                         UART_RX_BUF_SIZE,
                         UART_TX_BUF_SIZE,
                         uart_event_handle, // uart_error_handle,
                         APP_IRQ_PRIORITY_LOW,
                         err_code);
    printf("\n\rStart: \n\r");
/**@brief Callback function for asserts in the SoftDevice.
 * @param[in]   line_num   Line number of the failing ASSERT call.
 * @param[in]   file_name  File name of the failing ASSERT call.
/**@brief Function for handling the data from the Nordic UART Service.
 * @details This function will process the data received from the Nordic UART BLE Service and send
 *          it to the UART module.
 * @param[in] p_nus    Nordic UART Service structure.
 * @param[in] p_data   Data to be send to UART module.
 * @param[in] length   Length of the data.
/**@snippet [Handling the data received over BLE] */
static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
    for (uint32_t i = 0; i < length; i++)
        while(app_uart_put(p_data[i]) != NRF_SUCCESS);
    while(app_uart_put('\n') != NRF_SUCCESS);
/**@brief Function for performing battery measurement and updating the Battery Level characteristic
 *        in Battery Service.
static void battery_level_update(void)
    uint32_t err_code;
    uint8_t  battery_level;
    battery_level = (uint8_t)sensorsim_measure(&m_battery_sim_state, &m_battery_sim_cfg);
    err_code = ble_bas_battery_level_update(&m_bas, battery_level);
    if ((err_code != NRF_SUCCESS) &&
        (err_code != NRF_ERROR_INVALID_STATE) &&
        (err_code != BLE_ERROR_NO_TX_PACKETS) &&
        (err_code != BLE_ERROR_GATTS_SYS_ATTR_MISSING)
        APP_ERROR_HANDLER(err_code);
/**@brief Function for handling the Battery measurement timer timeout.
 * @details This function will be called each time the battery level measurement timer expires.
 * @param[in]   p_context   Pointer used for passing some arbitrary information (context) from the
 *                          app_start_timer() call to the timeout handler.
static void battery_level_meas_timeout_handler(void * p_context)
    UNUSED_PARAMETER(p_context);
    battery_level_update();
/**@brief Function for handling the Heart rate measurement timer timeout.
 * @details This function will be called each time the heart rate measurement timer expires.
 *          It will exclude RR Interval data from every third measurement.
static void heart_rate_meas_timeout_handler(void * p_context)
    static uint32_t cnt = 0;
    uint32_t        err_code;
    uint16_t        heart_rate;
    heart_rate = (uint16_t)sensorsim_measure(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    cnt++;
    err_code = ble_hrs_heart_rate_measurement_send(&m_hrs, heart_rate);
    // Disable RR Interval recording every third heart rate measurement.
    // NOTE: An application will normally not do this. It is done here just for testing generation
    //       of messages without RR Interval measurements.
    m_rr_interval_enabled = ((cnt % 3) != 0);
/**@brief Function for handling the RR interval timer timeout.
 * @details This function will be called each time the RR interval timer expires.
static void rr_interval_timeout_handler(void * p_context)
    if (m_rr_interval_enabled)
        uint16_t rr_interval;
        rr_interval = (uint16_t)sensorsim_measure(&m_rr_interval_sim_state,
                                                      &m_rr_interval_sim_cfg);
        ble_hrs_rr_interval_add(&m_hrs, rr_interval);
/**@brief Function for handling the Sensor Contact Detected timer timeout.
 * @details This function will be called each time the Sensor Contact Detected timer expires.
static void sensor_contact_detected_timeout_handler(void * p_context)
    static bool sensor_contact_detected = false;
    sensor_contact_detected = !sensor_contact_detected;
    ble_hrs_sensor_contact_detected_update(&m_hrs, sensor_contact_detected);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
static void timers_init(void)
    uint32_t err_code;
    // Initialize timer module.
    APP_TIMER_INIT(APP_TIMER_PRESCALER, APP_TIMER_OP_QUEUE_SIZE, false);
    // Create timers.
    err_code = app_timer_create(&m_battery_timer_id,
                                APP_TIMER_MODE_REPEATED,
                                battery_level_meas_timeout_handler);
    err_code = app_timer_create(&m_heart_rate_timer_id,
                                heart_rate_meas_timeout_handler);
    err_code = app_timer_create(&m_rr_interval_timer_id,
                                rr_interval_timeout_handler);
    err_code = app_timer_create(&m_sensor_contact_timer_id,
                                sensor_contact_detected_timeout_handler);
 * @details This function sets up all the necessary GAP (Generic Access Profile) parameters of the
 *          device including the device name, appearance, and the preferred connection parameters.
    uint32_t                err_code;
                                          (const uint8_t *)DEVICE_NAME,
                                          strlen(DEVICE_NAME));
    err_code = sd_ble_gap_appearance_set(BLE_APPEARANCE_HEART_RATE_SENSOR_HEART_RATE_BELT);
 * @details Initialize the Heart Rate, Battery and Device Information services.
/**@brief Function for preparing for system reset.
 * @details This function implements @ref dfu_app_reset_prepare_t. It will be called by
 *          @ref dfu_app_handler.c before entering the bootloader/DFU.
 *          This allows the current running application to shut down gracefully.
static void reset_prepare(void)
    uint32_t err_code;
    if (m_conn_handle != BLE_CONN_HANDLE_INVALID)
        // Disconnect from peer.
        err_code = sd_ble_gap_disconnect(m_conn_handle, BLE_HCI_REMOTE_USER_TERMINATED_CONNECTION);
        // If not connected, the device will be advertising. Hence stop the advertising.
       // advertising_stop();
    err_code = ble_conn_params_stop();
   // nrf_delay_ms(500);
    uint32_t       err_code;
    ble_hrs_init_t hrs_init;
    ble_bas_init_t bas_init;
    ble_dis_init_t dis_init;
    uint8_t        body_sensor_location;
    // Initialize Heart Rate Service.
    body_sensor_location = BLE_HRS_BODY_SENSOR_LOCATION_FINGER;
    memset(&hrs_init, 0, sizeof(hrs_init));
    hrs_init.evt_handler                 = NULL;
    hrs_init.is_sensor_contact_supported = true;
    hrs_init.p_body_sensor_location      = &body_sensor_location;
    // Here the sec level for the Heart Rate Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_hrm_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_hrm_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&hrs_init.hrs_bsl_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&hrs_init.hrs_bsl_attr_md.write_perm);
    err_code = ble_hrs_init(&m_hrs, &hrs_init);
    // Initialize Battery Service.
    memset(&bas_init, 0, sizeof(bas_init));
    // Here the sec level for the Battery Service can be changed/increased.
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.cccd_write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_char_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&bas_init.battery_level_char_attr_md.write_perm);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&bas_init.battery_level_report_read_perm);
    bas_init.evt_handler          = NULL;
    bas_init.support_notification = true;
    bas_init.p_report_ref         = NULL;
    bas_init.initial_batt_level   = 100;
    err_code = ble_bas_init(&m_bas, &bas_init);
    // Initialize Device Information Service.
    memset(&dis_init, 0, sizeof(dis_init));
    ble_srv_ascii_to_utf8(&dis_init.manufact_name_str, (char *)MANUFACTURER_NAME);
    BLE_GAP_CONN_SEC_MODE_SET_OPEN(&dis_init.dis_attr_md.read_perm);
    BLE_GAP_CONN_SEC_MODE_SET_NO_ACCESS(&dis_init.dis_attr_md.write_perm);
    err_code = ble_dis_init(&dis_init);
		 ble_dfu_init_t   dfus_init;
    // Initialize the Device Firmware Update Service.
    memset(&dfus_init, 0, sizeof(dfus_init));
    dfus_init.evt_handler   = dfu_app_on_dfu_evt;
    dfus_init.error_handler = NULL;
  //  dfus_init.revision      = DFU_REVISION;
    err_code = ble_dfu_init(&m_dfus, &dfus_init);
    dfu_app_reset_prepare_set(reset_prepare);
    dfu_app_dm_appl_instance_set(m_app_handle);
    ble_nus_init_t nus_init;
/**@brief Function for initializing the sensor simulators.
static void sensor_simulator_init(void)
    m_battery_sim_cfg.min          = MIN_BATTERY_LEVEL;
    m_battery_sim_cfg.max          = MAX_BATTERY_LEVEL;
    m_battery_sim_cfg.incr         = BATTERY_LEVEL_INCREMENT;
    m_battery_sim_cfg.start_at_max = true;
    sensorsim_init(&m_battery_sim_state, &m_battery_sim_cfg);
    m_heart_rate_sim_cfg.min          = MIN_HEART_RATE;
    m_heart_rate_sim_cfg.max          = MAX_HEART_RATE;
    m_heart_rate_sim_cfg.incr         = HEART_RATE_INCREMENT;
    m_heart_rate_sim_cfg.start_at_max = false;
    sensorsim_init(&m_heart_rate_sim_state, &m_heart_rate_sim_cfg);
    m_rr_interval_sim_cfg.min          = MIN_RR_INTERVAL;
    m_rr_interval_sim_cfg.max          = MAX_RR_INTERVAL;
    m_rr_interval_sim_cfg.incr         = RR_INTERVAL_INCREMENT;
    m_rr_interval_sim_cfg.start_at_max = false;
    sensorsim_init(&m_rr_interval_sim_state, &m_rr_interval_sim_cfg);
/**@brief Function for starting application timers.
static void application_timers_start(void)
    uint32_t err_code;
    // Start application timers.
    err_code = app_timer_start(m_battery_timer_id, BATTERY_LEVEL_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(m_heart_rate_timer_id, HEART_RATE_MEAS_INTERVAL, NULL);
    err_code = app_timer_start(m_rr_interval_timer_id, RR_INTERVAL_INTERVAL, NULL);
    err_code = app_timer_start(m_sensor_contact_timer_id, SENSOR_CONTACT_DETECTED_INTERVAL, NULL);
/**@brief Function for handling the Connection Parameters Module.
 * @details This function will be called for all events in the Connection Parameters Module which
 *          are passed to the application.
 *          @note All this function does is to disconnect. This could have been done by simply
 *                setting the disconnect_on_fail config parameter, but instead we use the event
 *                handler mechanism to demonstrate its use.
 * @param[in]   p_evt   Event received from the Connection Parameters Module.
    uint32_t err_code;
    if(p_evt->evt_type == BLE_CONN_PARAMS_EVT_FAILED)
/**@brief Function for handling a Connection Parameters error.
    cp_init.start_on_notify_cccd_handle    = m_hrs.hrm_handles.cccd_handle;
    err_code = bsp_indication_set(BSP_INDICATE_ALERT_OFF);
    // Prepare wakeup buttons.
    uint32_t err_code;
    switch (ble_adv_evt)
        case BLE_ADV_EVT_FAST:
        case BLE_ADV_EVT_IDLE:
            sleep_mode_enter();
/**@brief Function for handling the Application's BLE Stack events.
static void on_ble_evt(ble_evt_t * p_ble_evt)
    uint32_t err_code;
        case BLE_GAP_EVT_CONNECTED:
            // No implementation needed.
/**@brief Function for dispatching a BLE stack event to all modules with a BLE stack event handler.
 * @details This function is called from the BLE Stack event interrupt handler after a BLE stack
 *          event has been received.
static void ble_evt_dispatch(ble_evt_t * p_ble_evt)
    app_beacon_scanner_on_ble_evt(p_ble_evt);
    dm_ble_evt_handler(p_ble_evt);
    ble_hrs_on_ble_evt(&m_hrs, p_ble_evt);
    ble_bas_on_ble_evt(&m_bas, p_ble_evt);
    ble_conn_params_on_ble_evt(p_ble_evt);
    bsp_btn_ble_on_ble_evt(p_ble_evt);
    ble_advertising_on_ble_evt(p_ble_evt);
	 // ble_dfu_on_ble_evt(&m_dfus, p_ble_evt);
/**@brief Function for dispatching a system event to interested modules.
 * @details This function is called from the System event interrupt handler after a system
 * @param[in]   sys_evt   System stack event.
static void sys_evt_dispatch(uint32_t sys_evt)
    pstorage_sys_event_handler(sys_evt);
    app_beacon_scanner_on_sys_evt(sys_evt);
    ble_advertising_on_sys_evt(sys_evt);
/**@brief Function for initializing the beacon scanner module.
static void scanner_init()
    m_beacon_scanner_init.evt_handler   = beacon_evt_handler;
    m_beacon_scanner_init.error_handler = beacon_scanner_error_handler;
    app_beacon_scanner_init(&m_beacon_scanner_init);
/**@brief Function for starting the beacon scanner module.
static void scanner_start()
    app_beacon_scanner_start();
/*static void nus_data_handler(ble_nus_t * p_nus, uint8_t * p_data, uint16_t length)
static void ble_stack_init(bool init_softdevice)
    uint32_t err_code;
   sd_mbr_command_t com = {SD_MBR_COMMAND_INIT_SD, };
    nrf_clock_lf_cfg_t clock_lf_cfg = NRF_CLOCK_LFCLKSRC;
    if (init_softdevice)
        err_code = sd_mbr_command(&com);
    err_code = sd_softdevice_vector_table_base_set(BOOTLOADER_REGION_START);
    // Initialize the SoftDevice handler module.
    SOFTDEVICE_HANDLER_INIT(&clock_lf_cfg, NULL);
    ble_enable_params_t ble_enable_params;
    err_code = softdevice_enable_get_default_config(CENTRAL_LINK_COUNT,
                                                    PERIPHERAL_LINK_COUNT,
                                                    &ble_enable_params);
    //Check the ram settings against the used number of links
    CHECK_RAM_START_ADDR(CENTRAL_LINK_COUNT,PERIPHERAL_LINK_COUNT);
    // Enable BLE stack.
    err_code = softdevice_enable(&ble_enable_params);
    // Register with the SoftDevice handler module for BLE events.
    err_code = softdevice_ble_evt_handler_set(ble_evt_dispatch);
    err_code = softdevice_sys_evt_handler_set(sys_evt_dispatch);
 * @param[in]   event   Event generated by button press.
static void bsp_event_handler(bsp_event_t event)
    uint32_t err_code;
    switch (event)
        case BSP_EVENT_SLEEP:
            sleep_mode_enter();
        case BSP_EVENT_DISCONNECT:
/**@brief Function for handling the Device Manager events.
 * @param[in]   p_evt   Data associated to the device manager event.
static uint32_t device_manager_evt_handler(dm_handle_t const    * p_handle,
                                           dm_event_t const     * p_event,
                                           ret_code_t           event_result)
    APP_ERROR_CHECK(event_result);
    return NRF_SUCCESS;
/**@brief Function for the Device Manager initialization.
 * @param[in] erase_bonds  Indicates whether bonding information should be cleared from
 *                         persistent storage during initialization of the Device Manager.
static void device_manager_init(bool erase_bonds)
    dm_init_param_t        init_param = {.clear_persistent_data = erase_bonds};
    dm_application_param_t register_param;
    // Initialize persistent storage module.
    err_code = pstorage_init();
    err_code = dm_init(&init_param);
    memset(&register_param.sec_param, 0, sizeof(ble_gap_sec_params_t));
    register_param.sec_param.bond         = SEC_PARAM_BOND;
    register_param.sec_param.mitm         = SEC_PARAM_MITM;
    register_param.sec_param.lesc         = SEC_PARAM_LESC;
    register_param.sec_param.keypress     = SEC_PARAM_KEYPRESS;
    register_param.sec_param.io_caps      = SEC_PARAM_IO_CAPABILITIES;
    register_param.sec_param.oob          = SEC_PARAM_OOB;
    register_param.sec_param.min_key_size = SEC_PARAM_MIN_KEY_SIZE;
    register_param.sec_param.max_key_size = SEC_PARAM_MAX_KEY_SIZE;
    register_param.evt_handler            = device_manager_evt_handler;
    register_param.service_type           = DM_PROTOCOL_CNTXT_GATT_SRVR_ID;
    err_code = dm_register(&m_app_handle, &register_param);
    uint32_t      err_code;
    ble_advdata_t advdata;
    // Build advertising data struct to pass into @ref ble_advertising_init.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type               = BLE_ADVDATA_FULL_NAME;
    advdata.include_appearance      = true;
    advdata.flags                   = BLE_GAP_ADV_FLAGS_LE_ONLY_GENERAL_DISC_MODE;
    advdata.uuids_complete.uuid_cnt = sizeof(m_adv_uuids) / sizeof(m_adv_uuids[0]);
    advdata.uuids_complete.p_uuids  = m_adv_uuids;
    ble_adv_modes_config_t options = {0};
    options.ble_adv_fast_enabled  = BLE_ADV_FAST_ENABLED;
    options.ble_adv_fast_interval = APP_ADV_INTERVAL;
    options.ble_adv_fast_timeout  = APP_ADV_TIMEOUT_IN_SECONDS;
    err_code = ble_advertising_init(&advdata, NULL, &options, on_adv_evt, NULL);
    bsp_event_t startup_event;
    uint32_t err_code = bsp_init(BSP_INIT_LED | BSP_INIT_BUTTONS,
                                 APP_TIMER_TICKS(100, APP_TIMER_PRESCALER),
                                 bsp_event_handler);
/**@brief Function for the Power manager.
static void power_manage(void)
    uint32_t err_code = sd_app_evt_wait();
/**@brief Function for application main entry.
    uint32_t err_code;
    bool erase_bonds;
    bool     dfu_start = false;
    bool     app_reset = (NRF_POWER->GPREGRET == BOOTLOADER_DFU_START);
    // Initialize.
    timers_init();
	  uart_inti();
    ble_stack_init(!app_reset);
    device_manager_init(erase_bonds);
    gap_params_init();
    advertising_init();
    services_init();
    //sensor_simulator_init();
   // conn_params_init();
    scanner_init();
    // Start execution.
    scanner_start();
  //  application_timers_start();
    err_code = ble_advertising_start(BLE_ADV_MODE_FAST);
    // Enter main loop.
    for (;;)
        power_manage();
I have attached the bootloder_util.c ,ble_dfu.c,dfu_app_handler.c and made changes according it.
I also changed ram setting in keil.
Thanks in advance
  • Ok. I used the pca10028\s130_with_dfu\arm5_no_packs, as it was the one I found that was closest to compiling without error, but I had to add the path to ble_db_discovery.h, so I just want to check with you that I used the correct project?
    After that it compiled, but nus_c_init returns 0x04, because it didn't have space for the NUS service. So am I using the correct project?
    After commenting out nus_c_init() the application runs, and I can see the advertisements, but still I can't see your beacon_evt_handler() in your project. The one that you described in a previous reply:
        uint32_t err_code;
    	// const ble_gap_evt_t * p_gap_evt = &p_evt->evt.gap_evt;
    	// const ble_gap_evt_adv_report_t * p_adv_report = &p_gap_evt->params.adv_report;
         &&(p_evt->rcv_adv_packet.adv_data.manuf_id == APP_COMPANY_IDENTIFIER))
    			  printf("\nMAJOR=0x %02x\n",(uint16_t)p_evt->rcv_adv_packet.adv_data.major);
    			  printf("\nMINOR=0x%02x\n",(uint16_t)p_evt->rcv_adv_packet.adv_data.minor);
    			  printf("\nNordicid=0x%02x\n",(uint8_t)p_evt->rcv_adv_packet.adv_data.manuf_id);
    			  printf("\nrssi=-0x%02x\n",(uint8_t)p_evt->rcv_adv_packet.adv_data.rssi);
    			  printf("Connecting to target %02x%02x%02x%02x%02x%02x\r\n",
    			                    (uint8_t) p_evt->rcv_adv_packet.addr.addr[5],
    			                    (uint8_t) p_evt->rcv_adv_packet.addr.addr[4],
    			                    (uint8_t) p_evt->rcv_adv_packet.addr.addr[3],
    			                    (uint8_t) p_evt->rcv_adv_packet.addr.addr[2],
    			                    (uint8_t) p_evt->rcv_adv_packet.addr.addr[1],
    			                    (uint8_t) p_evt->rcv_adv_packet.addr.addr[0]);
  • yes Edvin,
    That is different project which used hrs_scanner example.
    Here in above project I am scanning using the central nus_c service.
    hrs_scanner.rar
    this project has the beacon_evt_handler()  function its location
    nRF5_SDK_11.0.0\examples\ble_peripheral\experimental_ble_app_multiactivity_beacon\hrs_scanner
    How can I make space for service using service inti with memloc() function?
    Thanks for your effort
  • Ok. I see. Well. Thank you for sending the correct project Slight smile
    The scanner_beacon.c/h doesn't actually forward the address to the beacon_evt_handler() in main.c. If you see in the app_beacon_on_ble_evt, you can see that it creates the event that is forwarded to the main scanning interrupt handler. It only decodes the MINOR and MAJOR values, in addition to the uuid.
    I did a few modifications to your project. Now it forwards the RSSI and the address to the beacon_evt_handler() in main.c.
    Attached is the main.c file, the scanner_beacon.h and scanner_beacon.c that I changed.
    /* Copyright (c) 2014 Nordic Semiconductor. All Rights Reserved.
     * the file.
    #include <stdio.h>
    #include <string.h>
    #include "app_util.h"
    #define SCAN_INTERVAL_MS  100
    #define WINDOW_LEN_MS    (SCAN_INTERVAL_MS / 4)
    #define MAX_ADV_PACK_LEN (BLE_GAP_ADV_MAX_SIZE + BLE_GAP_ADDR_LEN + 2)
    #define ADV_TYPE_LEN      2
    #define BEACON_DATA_LEN   21
    static struct
        ble_scan_beacon_evt_handler_t evt_handler;
        ble_srv_error_handler_t       error_handler;                      /**< Function to be called in case of an error. */
        ble_gap_scan_params_t         scan_params;
    } m_beacon_scanner;
    static void decode_ad_type_flags(uint8_t *buffer, uint8_t len, adv_packet_t *adv_packet)
        int i = 1;
        adv_packet->gap_ad_flags = buffer[i];
    static void decode_ad_manuf_spec_data(uint8_t *buffer, uint8_t len, adv_packet_t *adv_packet)
        int i = 1;
        adv_packet->adv_data.manuf_id = uint16_decode(&buffer[i]);
        i += sizeof(uint16_t);
        adv_packet->adv_data.beacon_dev_type = buffer[i++];
        uint8_t data_len = buffer[i++];
        if (data_len == BEACON_DATA_LEN)
            memcpy(&adv_packet->adv_data.uuid, &buffer[i], sizeof(ble_uuid128_t));
            i += sizeof(ble_uuid128_t);
            adv_packet->adv_data.major = uint16_decode(&buffer[i]);
    			//  i += sizeof(ble_gap_addr_t);
           // adv_packet->adv_data.peer_addr = uint48_encode(&buffer[i],&buffer1[i]);
            adv_packet->adv_data.minor = uint16_decode(&buffer[i]);
            adv_packet->adv_data.rssi = uint16_decode(&buffer[i]);
            memset(&adv_packet->adv_data.uuid, 0, sizeof(ble_uuid128_t));
            adv_packet->adv_data.major = 0;
            adv_packet->adv_data.minor = 0;
            adv_packet->adv_data.rssi = 0;
    static uint32_t decode_advertising(uint8_t *buffer, uint8_t buffer_len, adv_packet_t *adv_packet)
        uint8_t i = 0;
        do
            uint8_t field_len = buffer[i++];
            if(buffer[i] == BLE_GAP_AD_TYPE_FLAGS)
                if (field_len != ADV_TYPE_LEN)
                    return NRF_ERROR_NOT_FOUND;
                decode_ad_type_flags(&buffer[i], field_len, adv_packet);
                i += field_len;
            else if (buffer[i] == BLE_GAP_AD_TYPE_MANUFACTURER_SPECIFIC_DATA)
                decode_ad_manuf_spec_data(&buffer[i], field_len, adv_packet);
                i += field_len;
        }while( i < buffer_len);
        return NRF_SUCCESS;
    void app_beacon_scanner_on_sys_evt(uint32_t event)
        // no implementation needed
    void app_beacon_scanner_on_ble_evt(ble_evt_t * p_ble_evt)
        if (p_ble_evt->header.evt_id == BLE_GAP_EVT_ADV_REPORT)
            ble_scan_beacon_evt_t evt;
            uint32_t err_code = decode_advertising(p_ble_evt->evt.gap_evt.params.adv_report.data, p_ble_evt->evt.gap_evt.params.adv_report.dlen, &evt.rcv_adv_packet);
            evt.rcv_adv_packet.addr.addr[0] = p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[0];
            evt.rcv_adv_packet.addr.addr[1] = p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[1];
            evt.rcv_adv_packet.addr.addr[2] = p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[2];
            evt.rcv_adv_packet.addr.addr[3] = p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[3];
            evt.rcv_adv_packet.addr.addr[4] = p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[4];
            evt.rcv_adv_packet.addr.addr[5] = p_ble_evt->evt.gap_evt.params.adv_report.peer_addr.addr[5];
            evt.rcv_adv_packet.adv_data.rssi = p_ble_evt->evt.gap_evt.params.adv_report.rssi;
            if (err_code == NRF_SUCCESS)
                if (m_beacon_scanner.evt_handler != NULL)
                        evt.evt_type = BLE_SCAN_BEACON_ADVERTISER_FOUND;
                        m_beacon_scanner.evt_handler(&evt);
    void app_beacon_scanner_init(ble_beacon_scanner_init_t * p_init)
        m_beacon_scanner.evt_handler = p_init->evt_handler;
        m_beacon_scanner.error_handler= p_init->error_handler;
        memset(&m_beacon_scanner.scan_params, 0, sizeof(m_beacon_scanner.scan_params));
        m_beacon_scanner.scan_params.active      = false;
        m_beacon_scanner.scan_params.selective   = false;
        m_beacon_scanner.scan_params.p_whitelist = NULL;
        m_beacon_scanner.scan_params.interval    = MSEC_TO_UNITS(SCAN_INTERVAL_MS, UNIT_0_625_MS);
        m_beacon_scanner.scan_params.window      = MSEC_TO_UNITS(WINDOW_LEN_MS, UNIT_0_625_MS);
        m_beacon_scanner.scan_params.timeout     = 0; // disable timeout
    void app_beacon_scanner_start(void)
        uint32_t err_code;
        err_code = sd_ble_gap_scan_start(&m_beacon_scanner.scan_params);
        if (err_code != NRF_SUCCESS)
            if (m_beacon_scanner.error_handler != NULL)
                m_beacon_scanner.error_handler(err_code);
    void app_beacon_scanner_stop(void)
        uint32_t err_code;
        err_code = sd_ble_gap_scan_stop();
     * the file.
    #include <stdint.h>
    #include <string.h>
    #include "nrf.h"
    #include "ble.h"
    #include "bsp.h"
    #include "app_uart.h"
    uint8_t buffer1[48];
    uint64_t addra;
    #define IS_SRVC_CHANGED_CHARACT_PRESENT         0                                       /**< Include or not the service_changed characteristic. if not enabled, the server's database cannot be changed for the lifetime of the device*/
        uint32_t err_code;
        //if((p_evt->rcv_adv_packet.adv_data.major    == SEARCHED_MAJOR)
        // &&(p_evt->rcv_adv_packet.adv_data.minor    == SEARCHED_MINOR)
        // &&(p_evt->rcv_adv_packet.adv_data.manuf_id == APP_COMPANY_IDENTIFIER))
        if (p_evt->rcv_adv_packet.adv_data.manuf_id == APP_COMPANY_IDENTIFIER)
    			  printf("\nMAJOR=0x %04x\n",(uint16_t)p_evt->rcv_adv_packet.adv_data.major);
    			  printf("\nMINOR=0x%04x\n",(uint16_t)p_evt->rcv_adv_packet.adv_data.minor);
    			  printf("\nNordicid=0x%02x\n",(uint16_t)p_evt->rcv_adv_packet.adv_data.manuf_id);
    			  printf("\nrssi=%d\n", (int8_t)p_evt->rcv_adv_packet.adv_data.rssi);
    			  //printf("\nuuid=%d\n",p_evt->rcv_adv_packet.adv_data.uuid);
                  printf("Connecting to target %02x:%02x:%02x:%02x:%02x:%02x\r\n",
                                    buffer1[0]=(uint8_t) p_evt->rcv_adv_packet.addr.addr[0],
                                    buffer1[1]=(uint8_t) p_evt->rcv_adv_packet.addr.addr[1],
                                    buffer1[2]=(uint8_t) p_evt->rcv_adv_packet.addr.addr[2],
                                    buffer1[3]=(uint8_t) p_evt->rcv_adv_packet.addr.addr[3],
                                    buffer1[4]=(uint8_t) p_evt->rcv_adv_packet.addr.addr[4],
                                    buffer1[5]=(uint8_t) p_evt->rcv_adv_packet.addr.addr[5]);
                  printf("Beacon uuid: 0x");
                  for (int i=0; i<16; i++)
                      printf("%02x:", p_evt->rcv_adv_packet.adv_data.uuid.uuid128[i]);
                  printf("\r\n");
    void uart_inti()
    	  uint32_t err_code;
              RX_PIN_NUMBER,
              TX_PIN_NUMBER,
              RTS_PIN_NUMBER,
              CTS_PIN_NUMBER,
              false,
                             UART_RX_BUF_SIZE,
                             UART_TX_BUF_SIZE,
                             uart_error_handle, // uart_error_handle,
                             err_code);
        uint32_t err_code;
        uint32_t        err_code;
        cnt++;
        uint32_t err_code;
        // Create timers.
        uint32_t                err_code;
        uint32_t       err_code;
        uint32_t err_code;
        uint32_t err_code;
        uint32_t err_code;
                sleep_mode_enter();
        uint32_t err_code;
        uint32_t err_code;
        uint32_t err_code;
        switch (event)
                sleep_mode_enter();
        return NRF_SUCCESS;
        uint32_t      err_code;
                                     bsp_event_handler);
        uint32_t err_code;
        bool erase_bonds;
        // Initialize.
        timers_init();
    	  uart_inti();
        ble_stack_init();
        gap_params_init();
        advertising_init();
        services_init();
        conn_params_init();
        scanner_init();
        // Start execution.
        scanner_start();
        // Enter main loop.
        for (;;)
            power_manage();
    scanner_beacon.h
    Edvin
  • Note that the address is LSB, so if you want to see it the same way as in nRF Connect, you must print it in the opposite order, starting from addr[5] and ending with addr[0].
  • thank you Edvin,
    Thanks for your effort.I will check with changes in my code and update you. sorry for trouble I give you.
