"synchronize" two devices
I have two nrf51822 devices, one running s110, the other s120. The s110 device reads ADC values every 20ms, and if they changed from the last reading it sends a notification with the values to the s120 device. My connection interval is 7.5ms, so this works fine. (packet is only 9 bytes). However, I also wish to know roughly how "old" the ADC readings are when received on the s120 device. I used the ble_app_multilink example in the SDK as a basis for the project, and tried the following:
I modified it so that when the s120 enables notifications on the s110 it also starts RTC1 with a 64 prescaler. When the s110 receives this it also starts its RTC1 with the same prescaler. The idea is that the real-time clocks on the two devices are now roughly in sync, disregarding the time it takes to send and process the packet. This difference will in any case only add a constant offset. Every time the s110 sends a message to the s120 it will timestamp the message, and the s120 will check how late it is. Since the packets are timestamped, then queued, i expected the difference to be maximum one connection interval, but the values seem to be completely random, anywhere from 2 ticks, to about 35 ticks. (~4ms to ~70ms). The s120 device makes use of the ble_radio_notification to know when exactly to start the RTC, so i'm guessing it should be fairly accurate.
So, I have two questions:
  1. Why do i see such large variation in the received packets?
  2. Is there a better way to know how "old" the received packet is?
    I am glad that I found your post.
    I have a pretty similar project, where the real-time clocks of two nRF5 devices should be roughly in sync and data should get timestamped.
    Can you please provide us some code of your modifications regarding the enabling of notifications, starting the RTC with a prescaler and using the ble_radio_notification:
    Thank you very much in advance.
