I keep getting stuck in the TIMER1_IRQHandler function.
When I debug the code, I get to line 20 (exiting interrupt function scope) and then the assembly code hits a nop instruction. This then brings the debugger back up to line 17.
Why won't the code enter my if statement?
/** @file
* @brief Example template project.
* @defgroup nrf_templates_example Example Template
* NOTE: To get build to work, I right clicked nRF_micro-ecc folder and excluded it from build
#include "main.h"
NRF_TIMER_Type* TIMER0 = (NRF_TIMER_Type*) TIMER0_BASE; // NRF_TIMER_Type has register structure
NRF_TIMER_Type* TIMER1 = (NRF_TIMER_Type*) TIMER1_BASE; // NRF_TIMER_Type has register structure
NRF_GPIOTE_Type* GPIOTE = (NRF_GPIOTE_Type*) GPIOTE_BASE; // NRF_GPIOTE_Type has register structure
int timer_flag = false;
void TIMER1_IRQHandler(void) {
timer_flag = true;
TIMER0 -> TASKS_STOP = 1;
TIMER0 -> EVENTS_COMPARE[0] = 0;
void timer_init(hx711_mode_t number_of_pulses) {
Setup timer for PWM
TIMER0 -> MODE &= 0; // Timer mode [DEFAULT]
TIMER0 -> CC[0] |= 0x10; // Set value in CC[0] to 10
TIMER0 -> PRESCALER |= 0x4; // Counts at 1 MHz [DEFAULT]
TIMER0 -> SHORTS |= 1; // On compare[0] event, CLEAR timer
Setup counter to stop PWM after number_of_pulses
TIMER1 -> MODE |= 0x2; // Timer set to low power counter mode
TIMER1 -> CC[0] |= number_of_pulses; // Counter set to mode
TIMER1 -> INTENSET |= (1 << 16); // initialise interrupt
TIMER1 -> SHORTS |= (1 << 8); // On compare[0] event, STOP timer
NVIC_SetPriority(TIMER1_IRQn, 0); // Priority 0 (lowest)
NVIC_ClearPendingIRQ(TIMER1_IRQn);
NVIC_EnableIRQ(TIMER1_IRQn); // Enables interrupt in NVIC interrupt controllers
Use PPI for PWM generation
Mode: task, Pin: PD_SCK, Polarity: Toggle, Initial pin value: LOW
GPIOTE-> CONFIG[0] = (0x3 << 0) |
(PD_SCK << 8) |
(0x3 << 16)|
(0 << 20);
NRF_PPI -> CH[0].EEP = (uint32_t) &TIMER0 -> EVENTS_COMPARE[0]; // Connect TIMER0 event to PPI channel 0
NRF_PPI -> CH[0].TEP = (uint32_t) &GPIOTE-> TASKS_OUT[0]; // Connect toggle task to PPI channel 0
NRF_PPI -> FORK[0].TEP = (uint32_t) &TIMER1-> TASKS_COUNT; // Connect toggle task to PPI channel 0
NRF_PPI -> CHEN = (0x1 << 0); // Enable PPI channel 0
* @brief Function for application main entry.
timer_init(CHANNEL_A_128); // Setup Timer
TIMER0 -> TASKS_START = 1;
while(true) {
if (timer_flag) {
nrf_delay_ms(500);
TIMER1 -> TASKS_CLEAR = 1;
timer_flag = false;
