nrf52-mesh-light-switch-client-server-proxy-master add uart module
HI
I use SDK nrf52-mesh-light-switch-client-server-proxy-master with nrf52840 PDK。
I need uart module,so I add include path,c file to the project.
add header file , uart_init function and uart event handle dunction to main.c .
set SDKconfig.h as uart example of SDK15.0.0 .
At beginning,it works fine. But when I send many data or send data Very frequently, it will stop running and show this error:
app_error_weak.c,  105, Mesh error 1 at 0x00000000 (:0)
after debug, i fuond that uart_event_handle function came a event of APP_UART_COMMUNICATION_ERROR.
  • What is the value of data field of the app_uart event? From app_uart.h :
    /**@brief Struct containing events from the UART module.
     * @details The app_uart_evt_t is used to notify the application of asynchronous events when data
     * are received on the UART peripheral or in case an error occured during data reception.
    typedef struct
        app_uart_evt_type_t evt_type; /**< Type of event. */
        union
            uint32_t error_communication; /**< Field used if evt_type is: APP_UART_COMMUNICATION_ERROR. This field contains the value in the ERRORSRC register for the UART peripheral. The UART_ERRORSRC_x defines from nrf5x_bitfields.h can be used to parse the error code. See also the \nRFXX Series Reference Manual for specification. */
            uint32_t error_code;          /**< Field used if evt_type is: NRF_ERROR_x. Additional status/error code if the error event type is APP_UART_FIFO_ERROR. This error code refer to errors defined in nrf_error.h. */
            uint8_t  value;               /**< Field used if evt_type is: NRF_ERROR_x. Additional status/error code if the error event type is APP_UART_FIFO_ERROR. This error code refer to errors defined in nrf_error.h. */
        } data;
    } app_uart_evt_t;
    Non-blocking means that you continue executing code when you wait for a state change instead of blocking execution:
    change_state();
    while(!state_changed); // Blocking function
    do_stuff();
    do_other_stuff(); // Blocked function
    -------------------------- VS ----------------------------
    change_state();
    do_other_stuff(); // Not blocked
    void some_event_handler(bool state_changed)
        if(state_changed)
            do_stuff();
  • Hi Enzo.
    Am strugle with the same issue.
    Looking at the one, you are quite succes.
    Could you attache project file (am guess in SES)?
    Thanks forward,
    Kamo.
