app_timer hangs
Hello.
I have encountered a case where app_timer gets stuck indefinitely while processing its timer queue. I have attached a simplified version of the code that runs on the nRF52840 DK. (I actually have the nRF52840 PDK, but I doubt that it makes a difference here).
The attached main.c should replace the main.c of the PCA10056 BSP example in SDK 15.2. The code toggles leds 1-3 every time buttons 1-3 are pressed. In addition there is another app_timer that toggles led 4 every second.
Essentially my app_timer code adds long press detection to the basic button handling done by app_button. I looked at the BSP library for an example of long press detection, and implemented the code similarly as the BSP does. So a button press starts an app_timer and a release stops it. If the timer expires before a release, a long press is signaled. This works otherwise, but rapidly clicking two buttons makes the code hang. It usually doesn't take more than a dozen clicks to make it hang on the DK.
Here is the button handling part of the code: (The full, compilable code is the attached main.c)
// Timer callback when long press timeout occurs.
// Forward long press events to the button handler.
static void button_long_press_handler(void * p_context)
    uint8_t * p_button = (uint8_t *)p_context;
    // Check if we have a button combo
    uint8_t is_pushed = 0;
    bool button_1 = false;
    bool button_2 = false;
    bool button_3 = false;
    if(app_button_is_pushed(0)){is_pushed++; button_1 = true;}    // app_button_is_pushed needs the index into the buttons[] array, hence (0,1,2).
    if(app_button_is_pushed(1)){is_pushed++; button_2 = true;}
    if(app_button_is_pushed(2)){is_pushed++; button_3 = true;}
    uint8_t event_id = BUTTON_LONG_PUSH;
    if(is_pushed > 1)
        if(button_1 && button_2)
            event_id = BUTTON_COMBO_1_2;
        else if(button_1 && button_3)
            event_id = BUTTON_COMBO_1_3;
        else if(button_2 && button_3)
            event_id = BUTTON_COMBO_2_3;
    button_common_handler(*p_button, event_id);
// Button definitions
// The config values are taken from custom_board.h
static const app_button_cfg_t buttons[BUTTONS_NUMBER] =
        .pin_no = BUTTON_1,
        .active_state = BUTTONS_ACTIVE_STATE,
        .pull_cfg = BUTTON_PULL,
        .button_handler = button_common_handler
        .pin_no = BUTTON_2,
        .pin_no = BUTTON_3,
#if (BUTTONS_NUMBER > 3)
        .pin_no = BUTTON_4,
void buttons_init(void)
    ret_code_t err_code;
    err_code = app_button_init(buttons, BUTTONS_NUMBER, APP_TIMER_TICKS(20));
    err_code = app_button_enable();
    err_code = app_timer_create(&button_long_press_timer, APP_TIMER_MODE_SINGLE_SHOT, button_long_press_handler);
// Common handler for button events. Detects short and long presses.
static void button_common_handler(uint8_t pin_no, uint8_t button_action)
    static bool suppress_next_release_event = false;
    if(button_action == APP_BUTTON_PUSH)
        // Start long press timer on PUSH event
        ret_code_t err_code = app_timer_start(button_long_press_timer, APP_TIMER_TICKS(LONG_PRESS_TIMEOUT_MS), (void*)&current_long_push_pin_no);
        if (err_code == NRF_SUCCESS)
            current_long_push_pin_no = pin_no;
    if(button_action == APP_BUTTON_RELEASE)
        // Stop long press timer
		(void)app_timer_stop(button_long_press_timer);
        // If this was the release event after a long press, ignore it.
        if(suppress_next_release_event){return;}
        if(pin_no == BUTTON_1){nrf_gpio_pin_toggle(LED_1);}
        if(pin_no == BUTTON_2){nrf_gpio_pin_toggle(LED_2);}
        if(pin_no == BUTTON_3){nrf_gpio_pin_toggle(LED_3);}
    if(button_action == BUTTON_LONG_PUSH)
        // Suppress next release event
        suppress_next_release_event = true;
    if(button_action == BUTTON_COMBO_1_2)
    if(button_action == BUTTON_COMBO_1_3)
    if(button_action == BUTTON_COMBO_2_3)
One interesting aspect is that the code hangs in two different while() loops inside app_timer, depending on whether another app_timer (that implements a one second tick) is running. If the tick timer is running, execution hangs in timer_list_remove(), similarly as in this old thread. If I commend out the tick timer (one_sec_timer_start() in the attached code), the code hangs in timer_timeouts_check() in the following loop:
        // Expire all timers within ticks_elapsed and collect ticks_expired.
        while (p_timer != NULL)
            // Do nothing if timer did not expire.
            if (ticks_elapsed < p_timer->ticks_to_expire)
            // Decrement ticks_elapsed and collect expired ticks.
            ticks_elapsed -= p_timer->ticks_to_expire;
            ticks_expired += p_timer->ticks_to_expire;
            // Move to next timer.
            p_previous_timer = p_timer;
            p_timer = p_timer->next;
            // Execute Task.
            if (p_previous_timer->is_running)
                p_previous_timer->is_running = false;
                timeout_handler_exec(p_previous_timer);
When it hangs, both p_timer and p_previous_timer point to the same timer. And their next pointers also point to the same, so the loop never exits.
I suspect that the root cause is a race condition, since I am triggering starts and stops of the same timer rapidly. Yet this code uses the same principle as the BSP, and I can't get the unmodified BSP example to hang. So I must be doing something wrong. I would appreciate any advice on how to make this work.
 * Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
 * All rights reserved.
/** @file
 * @defgroup bsp_example_main main.c
 * @ingroup bsp_example
 * @brief BSP Example Application main file.
#include <stdbool.h>
#include <stdint.h>
#include "boards.h"
#include "app_timer.h"
#include "app_button.h"
#include "nrf_gpio.h"
#include "nordic_common.h"
#include "nrf_error.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define LONG_PRESS_TIMEOUT_MS   3000
#define BUTTON_LONG_PUSH        2
#define BUTTON_COMBO_1_2        3
#define BUTTON_COMBO_1_3        4
#define BUTTON_COMBO_2_3        5
#define ONE_SEC_TIMER_TIMEOUT     (APP_TIMER_TICKS(1000))
static volatile uint32_t one_sec_ticks;
static void button_common_handler(uint8_t pin_no, uint8_t button_action);
uint8_t current_long_push_pin_no;
// The button timer is used to detect long presses
APP_TIMER_DEF(button_long_press_timer);
APP_TIMER_DEF(one_sec_timer_id);
/**@brief Function for initializing low frequency clock.
void clock_initialization()
    NRF_CLOCK->LFCLKSRC            = (CLOCK_LFCLKSRC_SRC_Xtal << CLOCK_LFCLKSRC_SRC_Pos);
    NRF_CLOCK->TASKS_LFCLKSTART    = 1;
    while (NRF_CLOCK->EVENTS_LFCLKSTARTED == 0)
        // Do nothing.
// This handler is called every second
void handle_one_sec_timer_tick(void *p_context)
    one_sec_ticks++;
    nrf_gpio_pin_toggle(LED_4);
/**@brief Function for the Timer initialization.
 * @details Initializes the timer module. This creates and starts application timers.
void one_sec_timer_init(void)
    // Initialize app_timer module.
    // Create timers.
    err_code = app_timer_create(&one_sec_timer_id, APP_TIMER_MODE_REPEATED, &handle_one_sec_timer_tick);
/**@brief Function for starting timers.
void one_sec_timer_start(void)
    err_code = app_timer_start(one_sec_timer_id, ONE_SEC_TIMER_TIMEOUT, NULL);
    if(is_pushed > 1)
        .pin_no = BUTTON_1,
        .pin_no = BUTTON_2,
        .pin_no = BUTTON_3,
        .pin_no = BUTTON_4,
 * @brief Function for application main entry.
    clock_initialization();
    nrf_gpio_cfg_output(LED_1);
    nrf_gpio_cfg_output(LED_2);
    nrf_gpio_cfg_output(LED_3);
    nrf_gpio_cfg_output(LED_4);
    one_sec_timer_init();
    //one_sec_timer_start();
    NRF_LOG_INFO("BSP example started.");
    buttons_init();
    while (true)
        NRF_LOG_FLUSH();
        __SEV();
        __WFE();
        __WFE();
        // no implementation needed
  • Using the APP_TIMER_WITH_PROFILER feature I can confirm that the queue isn't filling up. It has to be something else.
    I've also tried to play with the IRQ priorities of GPIOTE and app_timer, but have not found anything that would explain this.
  • I found out I can make the application hang by pressing one button at the same time as releasing another one. But if I try doing it the other way around it doesn't hang, so the order is important. Maybe it has something to do with starting and stopping a timer at the same time.
  • Yes, that has been my suspicion as well. But my code should essentially be a simplification of the BSP code, which also does the same kind of starting and stopping. And it doesn't seem to hang in the same way.
  • Hello again, and sorry for late reply. I found a fix for your problem. You need to make sure that a timer is not inserted in timer_list_insert() when it is already in the queue. To do that, you can check it like this
    if (p_current == p_timer)
    	return;
    The timer_list_insert() will then look like this
    static void timer_list_insert(timer_node_t * p_timer)
        if (mp_timer_id_head == NULL)
            mp_timer_id_head = p_timer;
            if (p_timer->ticks_to_expire <= mp_timer_id_head->ticks_to_expire)
                mp_timer_id_head->ticks_to_expire -= p_timer->ticks_to_expire;
                p_timer->next   = mp_timer_id_head;
                timer_node_t * p_previous;
                timer_node_t * p_current;
                uint32_t       ticks_to_expire;
                ticks_to_expire   = p_timer->ticks_to_expire;
                p_previous        = mp_timer_id_head;
                p_current         = mp_timer_id_head;
                while ((p_current != NULL) && (ticks_to_expire > p_current->ticks_to_expire))
                    ticks_to_expire   -= p_current->ticks_to_expire;
                    p_previous         = p_current;
                    p_current          = p_current->next;
                if (p_current != NULL)
                    p_current->ticks_to_expire -= ticks_to_expire;
    				return;
                p_timer->ticks_to_expire = ticks_to_expire;
                p_timer->next            = p_current;
                p_previous->next         = p_timer;
    This is probably not an ideal solution, but it seems to work.
  • Thank you. That change seems to fix the immediate case, but I'm not sure if it fixes the general case.
    I have tried to dig deeper into the timer queue handling, and would like to confirm with you if my understanding is correct:
    The app_timer queue is a linked list of timer_node_t -structs. When new timers are added to the queue new nodes are NOT allocated (dynamically or from a fixed size pool). Instead, every timer created by APP_TIMER_DEF is itself a timer_node_t node. Is my understanding correct so far?
    If this is true, then one must never, ever add the same timer into the queue twice. Doing so would modify the existing queue by modifying the next pointer of the first timer instance that is already in the queue. This would result in either skipping the timers in the queue between the first and second instances, or lead to a circular queue that causes the hang we're seeing in my case. Again is this correct or am I way off here?
    The fix you propose would prevent adding the same timer twice consecutively into the queue. This might be enough to prevent the hang, but if I have understood the operation correctly one could still add the same timer twice if there are other timers in between. And that case would lead to the timers in between to be lost from the queue.
