Only some of the connected thingy are output
https://github.com/NordicPlayground/nrf52-ble-multi-link-multi-role
I use this code.
The connection to thingy was successful. max connection is 10.
The discovery of environmental services has been successful.
but only the environmental values of some devices are output.
for example connect  10 device but print only 7 device
How can I print the environment values of all devices?
  • uint32_t ble_thingy_tms_c_quat_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    VERIFY_PARAM_NOT_NULL(p_ble_thingy_tms_c);
    if (p_ble_thingy_tms_c->conn_handle == BLE_CONN_HANDLE_INVALID)
    // NRF_LOG_INFO("quat notif_enable");
    return cccd_configure(p_ble_thingy_tms_c->conn_handle,
    p_ble_thingy_tms_c->peer_thingy_tms_db.quat_cccd_handle,
    true);
    uint32_t ble_thingy_tms_c_tap_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    // NRF_LOG_INFO("tap notif_enable");
    p_ble_thingy_tms_c->peer_thingy_tms_db.tap_cccd_handle,
    true);
    uint32_t ble_thingy_tms_c_pedo_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    // NRF_LOG_INFO("pedo notif_enable");
    p_ble_thingy_tms_c->peer_thingy_tms_db.pedo_cccd_handle,
    true);
    uint32_t ble_thingy_tms_c_raw_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    // NRF_LOG_INFO("raw notif_enable");
    p_ble_thingy_tms_c->peer_thingy_tms_db.raw_cccd_handle,
    true);
    uint32_t ble_thingy_tms_c_euler_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    p_ble_thingy_tms_c->peer_thingy_tms_db.euler_cccd_handle,
    true);
    uint32_t ble_thingy_tms_c_orientation_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    // NRF_LOG_INFO("orientation notif_enable");
    p_ble_thingy_tms_c->peer_thingy_tms_db.orientation_cccd_handle,
    true);
    uint32_t ble_thingy_tms_c_gravity_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    NRF_LOG_INFO("gravity notif_enable");
    p_ble_thingy_tms_c->peer_thingy_tms_db.gravity_cccd_handle,
    true);
    uint32_t ble_thingy_tms_c_heading_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    NRF_LOG_INFO("heading notif_enable");
    p_ble_thingy_tms_c->peer_thingy_tms_db.heading_cccd_handle,
    true);
    uint32_t ble_thingy_tms_c_config_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    p_ble_thingy_tms_c->peer_thingy_tms_db.config_cccd_handle,
    true);
    uint32_t ble_thingy_tms_c_rot_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    p_ble_thingy_tms_c->peer_thingy_tms_db.rot_cccd_handle,
    true);
    this is my code  in ble.c
    there is code in main.c
    static void thingy_tms_c_evt_handler(ble_thingy_tms_c_t * p_thingy_tms_c, ble_thingy_tms_c_evt_t * p_thingy_tms_c_evt)
    ret_code_t err_code;
    switch (p_thingy_tms_c_evt->evt_type)
    case BLE_THINGY_TMS_C_EVT_DISCOVERY_COMPLETE:
    // uint32_t ble_thingy_tms_c_raw_notif_enable(ble_thingy_tms_c_t * p_ble_thingy_tms_c)
    err_code = ble_thingy_tms_c_heading_notif_enable(p_thingy_tms_c);
    err_code = ble_thingy_tms_c_raw_notif_enable(p_thingy_tms_c);
    err_code = ble_thingy_tms_c_quat_notif_enable(p_thingy_tms_c);
    err_code = ble_thingy_tms_c_orientation_notif_enable(p_thingy_tms_c);
    err_code = ble_thingy_tms_c_tap_notif_enable(p_thingy_tms_c);
    err_code = ble_thingy_tms_c_pedo_notif_enable(p_thingy_tms_c);
    err_code = ble_thingy_tms_c_euler_notif_enable(p_thingy_tms_c);
    err_code = ble_thingy_tms_c_gravity_notif_enable(p_thingy_tms_c);
    err_code = ble_thingy_tms_c_config_notif_enable(p_thingy_tms_c);
    err_code = ble_thingy_tms_c_rot_notif_enable(p_thingy_tms_c);
    ble_gap_conn_params_t conn_params;
    conn_params.max_conn_interval = MAX_CONNECTION_INTERVAL;
    conn_params.min_conn_interval = MIN_CONNECTION_INTERVAL;
    conn_params.slave_latency = SLAVE_LATENCY;
    conn_params.conn_sup_timeout = SUPERVISION_TIMEOUT;
    sd_ble_gap_conn_param_update(p_thingy_tms_c_evt->conn_handle, &conn_params);
    } break;
    // case BLE_THINGY_TES_C_EVT_TEMPERATURE_NOTIFICATION:
    //app_aggregator_temp_update(p_thingy_tes_c_evt->conn_handle, p_thingy_tes_c_evt->params.temperature.integer);
    // break;
    // case BLE_THINGY_TES_C_EVT_HUMIDITY_NOTIFICATION:
    //app_aggregator_humid_update(p_thingy_tes_c_evt->conn_handle, p_thingy_tes_c_evt->params.humidity.humidity);
    default :/*
    app_aggregator_humid_update(p_thingy_tes_c_evt->conn_handle, p_thingy_tes_c_evt->params.humidity.humidity);*/
    it is correct?
  • Hi
    Sorry for the late reply. I have been out travelling and haven't had time to follow up.
    At first glance your code looks OK, but when enabling that many characteristics at the same time you might have to increase the buffer size inside the service module.
    inside the ble_thingy_tsm_c.c file there should be two defines looking like this:
    #define TX_BUFFER_MASK 0x07 /**< TX Buffer mask, must be a mask of continuous zeroes, followed by continuous sequence of ones: 000...111. */
    #define TX_BUFFER_SIZE (TX_BUFFER_MASK + 1) /**< Size of send buffer, which is 1 higher than the mask. */
    Try to change them to this, and it should work better:
    #define TX_BUFFER_MASK 0x0F /**< TX Buffer mask, must be a mask of continuous zeroes, followed by continuous sequence of ones: 000...111. */
    Best regards
    Torbjørn
  • i don't found  ble_thingy_tsm_c.c
    how to find  ble_thingy_tsm_c.c ?
  • Hi
    This file was included in the ble_thingy_tms_c.zip file, that I sent you in my reply 16 days ago.
    Please let me know if you still can't find it, and I will send it again.
    Best regards
    Torbjørn
  • #define TX_BUFFER_MASK 0x0F
    I found this code and changed
    but this is not solution
