nRF5_SDK_15.2 UART DFU problems
Hi.
We are on early phases of getting UART DFU support for our product. However I seem to run into communication issue with the bootloader even with the examples provided in the SDK.
The device seems to enter DFU mode OK (I can see the LEDs 1 and 4 to light up and sometimes even 1 and 2), however the nrfutil reports either "Serial port could not be opened on {0}" or "No ping response after opening COM port".
My test procedure with the examples (nRF5_SDK_15.2.0_9412b96/examples/dfu/secure_dfu_test_images/uart/nrf52832):
1. nrfjprog --eraseall -f nrf52
2. nrfjprog --reset --program mbr.hex --family NRF52 --sectorerase
3. nrfjprog --reset --program bootloader_secure_uart_debug_without_bonds_mbr.hex --family NRF52 --sectoranduicrerase
After rebooting the device I can see the leds 1 and 4 light up.
After that:
4. nrfutil dfu serial -pkg blinky_mbr.zip -p /dev/ttyACM0 (-b 115200 -fc 1 tested also with these, no difference)
My setup:
Ubuntu 16.04 LTS
SEGGER J-Link Commander V6.40
nrf52832 (pca10040):
Firmware: J-Link OB-SAM3U128-V2-NordicSemi  compiled Jul 12 2018 11:44:4Hardware version: V1.00
S/N: 682270901
VTref=3.300V
nrfutil version
nrfutil version 4.0.0
python --version
Python 2.7.12
nrfjprog --version
nrfjprog version: 9.8.1
JLinkARM.dll version: 6.40
GNU_INSTALL_ROOT ?= /usr/local/gcc-arm-none-eabi-5_2-2015q4/bin/
GNU_VERSION ?= 5.2.1
GNU_PREFIX ?= arm-none-eabi
As a separate question regarding the bootloader and regular app without any support for bootloader:
Should I be able to have bootloader in the mix and the application should run normal? I mean I've tried with the combined image and the application doesn't start. I don't mind at this phase that I cannot enter the DFU mode from button, etc, but I would like to have the DFU bootloader in the mix and run the app.
My process for the image was:
1. build bootloader
2. Build app
3. goto bootloader _build
4. nrfutil settings generate --family NRF52 --application /path/to/app/_build/nrf52832_xxaa.hex --application-version 0 --bootloader-version 1 --bl-settings-version 1 setting.hex
5. mergehex -m nrf52832_xxaa_mbr.hex setting.hex -o bootloader_and_setting.hex
6. mergehex -m /path/to/app/nrf52832_xxaa.hex bootloader_and_setting.hex -o app_bootloader_and_setting.hex
7. mergehex -m nRF5_SDK_15.2.0_9412b96/components/softdevice/s132/hex/s132_nrf52_6.1.0_softdevice.hex app_bootloader_and_setting.hex -o sd_app_bootloader_and_setting.hex
8. nrfutil pkg generate --hw-version 52 --application-version 1 --application sd_app_bootloader_and_setting.hex --sd-req 0xAF --key-file private.key app_dfu_package.zip
9. nrfjprog --reset --program sd_app_bootloader_and_setting.hex --family NRF52 --sectoranduicrerase
Does this make any sense? My linker memory table looks like:
MEMORY
FLASH (rx) : ORIGIN = 0x26000, LENGTH = 0x5a000
RAM (rwx) : ORIGIN = 0x20002218, LENGTH = 0xdde8
Rest of it is pretty much right off the hrs example if I recall correctly (we update from SDK 12.xx recently so I had to update the linker file also).
