Multi role in SDK 15 - Scanning for devices only working when peripheral is not connected
I'm trying to get the scanning procedure to work while my device is connected to a phone. At the moment, even though I start the scanning procedure, I don't get any BLE_GAP_EVT_ADV_REPORT events.
As soon as the peripheral link is terminated (i.e. phone disconnects), I start getting the adv report events. This happens without me telling the scanning procedure to start again, as far as I'm concerned the scanning was started already.
What could be going wrong? Is scanning while connected not supported? I haven't read any limitations about this in the documentation.
Any help with this is appreciated :)
  • The connection parameters of my central links are set to 500 ms min, 2000 ms max, but the scanning doesn't even work when no central links are active (i.e. peripheral active, no central links active).
    The suggestion to look at the connection intervals was because scan events are dropped in their entirety if they collide with connection events. (That would explain why you did not get any advertising reports.) But if scan events are dropped multiple times and the connections have high enough supervision timeout (and, in peripheral role, slave latency) then after a few missed scan event a scan event would be scheduled anyway (and the connection event be dropped instead.) However, with the parameters that you listed I do not see how this could be the issue. Also, in that case you should expect at least _some_ scan events to get thorugh.
    Have you gotten the scan and establishment of a second connection to work if you use the same configuration for both links? The issues that you experience may be totally unrelated to the use of different configurations.
    Terje
  • I just tried what you suggested, i.e. scanning with a single configuration supporting one peripheral and on e central link, and it didn't work either. So at least that means that the configuration isn't the problem
  • I found the problem! It's this code:
    static void on_adv_report(ble_evt_t const * p_ble_evt) {
    	ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
    	ret_code_t            err_code;
    	if (is_already_connected(&p_gap_evt->params.adv_report.peer_addr)) {
    		debug_line("Returning because already connected");
    		return;
    I don't know why I had that there. I possibly copied it from one of the examples. My question now is: Why would an advertising report come from a device that is already connected? That doesn't make sense at all.
    Yes, that would probably explain it. In the latest SoftDevice you need to actively resume scanning on an advertising report, so just returning from the handler would leave the SoftDevice in a state where scanning is "paused".
    As to why you could receive an advertising report from a device to which you are already in a connection, that would be normal if the other device can have multiple connections as a peripheral. It would then continue to advertise again after the connection with your central device was established.
    In order to not end up with multiple connections to the same peripheral it is wise to do that check, but with SoftDevice 6 and onward you must make sure to restart scanning before you return from the handler.
    Terje
