flashwrite persistence
Using sdk12.3 on pca10040.
I wanted to test persistence so I modified the example from the SDK as follows:  log what's already there.  don't erase.  enter new data.  log it again.
Using the provided example /peripheral/flashwrite to get the starting address
pg_size = NRF_FICR->CODEPAGESIZE;
pg_num = NRF_FICR->CODESIZE - 1; // Use last page in flash
addr = (uint32_t *)(pg_size * pg_num);
I then say:
flash_word_write(addr, (uint32_t)patwr);
NRF_LOG_INFO("'%c' was written to flash at %08x\r\n", patwr, (unsigned long) addr);
patrd = (uint8_t)*addr;
NRF_LOG_INFO("'%c' %08x was read from flash at %08x\r\n\r\n", patrd, *addr, (unsigned long) addr);
Regardless of the value of patwr (a character from the console) written to 0007F000 the read value is 00000000.
(So the fact that it does not persist across a reset is not surprising.)
Causes could be that the address is wrong or that writing to flash is somehow being blocked.
Any suggestions pls.
    The fds module should work without the softdevice as well. Just make sure to include the correct fstorage files (that are used by the fds files).
    There are two fstorage.c files. One called fstorage.c, and one called fstorage_nosd.c (no softdevice). Use the last one.
    Your compiler error, "initializer element is not constant" is probably because you are trying to add
    ret_code_t ret = fds_register(fds_evt_handler);
    outside a function.
    These instructions can't be copy-pasted into a main.c file. You must have all function calls inside a function, e.g. your main() function, or another function that you create. Something like this:
    static void fds_evt_handler(fds_evt_t const * p_fds_evt)
        switch(p_fds_evt->id)
            case FDS_EVT_INIT:
                if(p_fds_evt->result != FDS_SUCCESS)
                    // initialization failed.
    void my_fds_init_function(void)
        if(ret != FDS_SUCCESS)
            //registering failed.
        ret = fds_init();
            // Handle error.
    BR,
    Edvin
  • Thx Edvin and apologies for forgetting the main()
    Now when I try to build this as above I find that  fds_record_t  is undefined.
    I think I have the right stuff in the attached Makefile.
    Again, I'm wondering if I can do this on SDK 12.3?
    Thx. Paul
    PROJECT_NAME     := flashwrite_pca10040
    TARGETS          := nrf52832_xxaa
    OUTPUT_DIRECTORY := _build
    SDK_ROOT := ../../../../../..
    PROJ_DIR := ../../..
    $(OUTPUT_DIRECTORY)/nrf52832_xxaa.out: \
      LINKER_SCRIPT  := flashwrite_gcc_nrf52.ld
    # Source files common to all targets
    SRC_FILES += \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_backend_serial.c \
      $(SDK_ROOT)/components/libraries/log/src/nrf_log_frontend.c \
      $(SDK_ROOT)/components/libraries/util/app_error.c \
      $(SDK_ROOT)/components/libraries/util/app_error_weak.c \
      $(SDK_ROOT)/components/libraries/util/app_util_platform.c \
      $(SDK_ROOT)/components/libraries/util/nrf_assert.c \
      $(SDK_ROOT)/components/libraries/util/sdk_errors.c \
      $(SDK_ROOT)/components/libraries/fds/fds.c \
      $(SDK_ROOT)/components/libraries/fstorage/fstorage_nosd.c \
      $(SDK_ROOT)/components/boards/boards.c \
      $(SDK_ROOT)/components/drivers_nrf/common/nrf_drv_common.c \
      $(SDK_ROOT)/components/drivers_nrf/uart/nrf_drv_uart.c \
      $(PROJ_DIR)/main.c \
      $(SDK_ROOT)/external/segger_rtt/RTT_Syscalls_GCC.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT.c \
      $(SDK_ROOT)/external/segger_rtt/SEGGER_RTT_printf.c \
      $(SDK_ROOT)/components/toolchain/gcc/gcc_startup_nrf52.S \
      $(SDK_ROOT)/components/toolchain/system_nrf52.c \
    # Include folders common to all targets
    INC_FOLDERS += \
      $(SDK_ROOT)/components \
      $(SDK_ROOT)/components/libraries/util \
      $(SDK_ROOT)/components/toolchain/gcc \
      $(SDK_ROOT)/components/drivers_nrf/uart \
      ../config \
      $(SDK_ROOT)/components/drivers_nrf/common \
      $(PROJ_DIR) \
      $(SDK_ROOT)/external/segger_rtt \
      $(SDK_ROOT)/components/libraries/bsp \
      $(SDK_ROOT)/components/libraries/fds \
      $(SDK_ROOT)/components/libraries/fstorage \
      $(SDK_ROOT)/components/libraries/experimental_section_vars \
      $(SDK_ROOT)/components/drivers_nrf/nrf_soc_nosd \
      $(SDK_ROOT)/components/toolchain \
      $(SDK_ROOT)/components/device \
      $(SDK_ROOT)/components/libraries/log \
      $(SDK_ROOT)/components/boards \
      $(SDK_ROOT)/components/drivers_nrf/delay \
      $(SDK_ROOT)/components/toolchain/cmsis/include \
      $(SDK_ROOT)/components/drivers_nrf/hal \
      $(SDK_ROOT)/components/libraries/log/src \
    # Libraries common to all targets
    LIB_FILES += \
    # C flags common to all targets
    CFLAGS += -DNRF52_PAN_12
    CFLAGS += -DNRF52_PAN_15
    CFLAGS += -DNRF52_PAN_58
    CFLAGS += -DNRF52_PAN_20
    CFLAGS += -DNRF52_PAN_54
    CFLAGS += -DNRF52
    CFLAGS += -DNRF52_PAN_51
    CFLAGS += -DNRF52_PAN_36
    CFLAGS += -DCONFIG_GPIO_AS_PINRESET
    CFLAGS += -DNRF52_PAN_64
    CFLAGS += -DNRF52_PAN_55
    CFLAGS += -DBOARD_PCA10040
    CFLAGS += -DNRF52_PAN_31
    CFLAGS += -DNRF52832
    CFLAGS += -DBSP_DEFINES_ONLY
    CFLAGS += -mcpu=cortex-m4
    CFLAGS += -mthumb -mabi=aapcs
    CFLAGS +=  -Wall -Werror -O3 -g3
    CFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # keep every function in separate section, this allows linker to discard unused ones
    CFLAGS += -ffunction-sections -fdata-sections -fno-strict-aliasing
    CFLAGS += -fno-builtin --short-enums
    # C++ flags common to all targets
    CXXFLAGS += \
    # Assembler flags common to all targets
    ASMFLAGS += -x assembler-with-cpp
    ASMFLAGS += -DNRF52_PAN_12
    ASMFLAGS += -DNRF52_PAN_15
    ASMFLAGS += -DNRF52_PAN_58
    ASMFLAGS += -DNRF52_PAN_20
    ASMFLAGS += -DNRF52_PAN_54
    ASMFLAGS += -DNRF52
    ASMFLAGS += -DNRF52_PAN_51
    ASMFLAGS += -DNRF52_PAN_36
    ASMFLAGS += -DCONFIG_GPIO_AS_PINRESET
    ASMFLAGS += -DNRF52_PAN_64
    ASMFLAGS += -DNRF52_PAN_55
    ASMFLAGS += -DBOARD_PCA10040
    ASMFLAGS += -DNRF52_PAN_31
    ASMFLAGS += -DNRF52832
    ASMFLAGS += -DBSP_DEFINES_ONLY
    # Linker flags
    LDFLAGS += -mthumb -mabi=aapcs -L $(TEMPLATE_PATH) -T$(LINKER_SCRIPT)
    LDFLAGS += -mcpu=cortex-m4
    LDFLAGS += -mfloat-abi=hard -mfpu=fpv4-sp-d16
    # let linker to dump unused sections
    LDFLAGS += -Wl,--gc-sections
    # use newlib in nano version
    LDFLAGS += --specs=nano.specs -lc -lnosys
    .PHONY: $(TARGETS) default all clean help flash
    # Default target - first one defined
    default: nrf52832_xxaa
    # Print all targets that can be built
    help:
    	@echo following targets are available:
    	@echo 	nrf52832_xxaa
    TEMPLATE_PATH := $(SDK_ROOT)/components/toolchain/gcc
    include $(TEMPLATE_PATH)/Makefile.common
    $(foreach target, $(TARGETS), $(call define_target, $(target)))
    # Flash the program
    flash: $(OUTPUT_DIRECTORY)/nrf52832_xxaa.hex
    	@echo Flashing: $<
    	nrfjprog --program $< -f nrf52 --sectorerase
    	nrfjprog --reset -f nrf52
    erase:
    	nrfjprog --eraseall -f nrf52
  • Hello Paul,
    Yes. This is possible in SDK12.3.0
    fds_record_t is defined in fds.h, so you must add the folder including this in your INC_FOLDERS in your makefile.
    I see that you have included it in your makefile, but there must be something wrong with it.
    Do you intend to use the softdevice in your final appliaction?
    Can you please paste the compiler output log?
    BR,
    Edvin
  • Thx Edvin,
    Initially without softdevice.  Will add that later.
    Compiling file: main.c
    ../../../main.c: In function 'main':
    ../../../main.c:100:13: error: 'struct <anonymous>' has no member named 'p_data'
      record.data.p_data       = &m_deadbeef;
    ../../../main.c:101:13: error: 'struct <anonymous>' has no member named 'length_words'
      record.data.length_words = 1;   /* one word is four bytes. */
    ../../../main.c:110:13: error: 'struct <anonymous>' has no member named 'p_data'
      record.data.p_data       = &m_hello;
    ../../../main.c:112:13: error: 'struct <anonymous>' has no member named 'length_words'
      record.data.length_words = (sizeof(m_hello) + 3) / 4;
    make: *** [_build/nrf52832_xxaa_main.c.o] Error 1
    I may have misinterpreted the above?
    Thx. Paul
  • Where do you declare "record"? and what does it look like?
