I tried to use the code from nRF5_SDK_15.0.0_a53641a, but the compiler keep complaining can't find head files ( seems not possible without changing sdk 15 files )
So, Is there an easy way?
How to properly post source code:
Hi, awneil,
here's the code:
void uarte_config(NRF_UARTE_Type * p_uarte,
nrfx_uarte_config_t const * p_config)
if (p_config->pseltxd != NRF_UARTE_PSEL_DISCONNECTED)
nrf_gpio_pin_set(p_config->pseltxd);
nrf_gpio_cfg_output(p_config->pseltxd);
if (p_config->pselrxd != NRF_UARTE_PSEL_DISCONNECTED)
nrf_gpio_cfg_input(p_config->pselrxd, NRF_GPIO_PIN_NOPULL);
nrf_uarte_baudrate_set(p_uarte, p_config->baudrate);
nrf_uarte_configure(p_uarte, p_config->parity, p_config->hwfc);
nrf_uarte_txrx_pins_set(p_uarte, p_config->pseltxd, p_config->pselrxd);
if (p_config->hwfc == NRF_UARTE_HWFC_ENABLED)
if (p_config->pselcts != NRF_UARTE_PSEL_DISCONNECTED)
nrf_gpio_cfg_input(p_config->pselcts, NRF_GPIO_PIN_NOPULL);
if (p_config->pselrts != NRF_UARTE_PSEL_DISCONNECTED)
nrf_gpio_pin_set(p_config->pselrts);
nrf_gpio_cfg_output(p_config->pselrts);
nrf_uarte_hwfc_pins_set(p_uarte, p_config->pselrts, p_config->pselcts);
nrf_uarte_int_enable(p_uarte, UARTE_INT_MASK);
NVIC_SetPriority(UARTE0_UART0_IRQn, p_config->interrupt_priority);
NVIC_ClearPendingIRQ(UARTE0_UART0_IRQn);
NVIC_EnableIRQ(UARTE0_UART0_IRQn);
nrf_uarte_enable(p_uarte);
void uarte_tx(NRF_UARTE_Type * p_reg, uint8_t * p_data, size_t len)
p_reg->TXD.PTR = (uint32_t)p_data;
p_reg->TXD.MAXCNT = len;
p_reg->TASKS_STARTTX = 0x1UL;
}By the way, here's the config I used:
#define NRF_UARTE_DEFAULT_CONFIG \
.pseltxd = TX_PIN_NUMBER, \
.pselrxd = NRF_UART_PSEL_DISCONNECTED, \
.pselcts = NRF_UART_PSEL_DISCONNECTED, \
.pselrts = NRF_UART_PSEL_DISCONNECTED, \
.p_context = NULL, \
.hwfc = (nrf_uart_hwfc_t)UART_DEFAULT_CONFIG_HWFC, \
.parity = (nrf_uart_parity_t)UART_DEFAULT_CONFIG_PARITY, \
.baudrate = NRF_UART_BAUDRATE_115200, \
.interrupt_priority = UART_DEFAULT_CONFIG_IRQ_PRIORITY, \
