Beacon Scanner Problem
I have beacon advertiser and scanner. Scanner is scanning the devices from around. But its not scanning the device that i used for advertising. On the other side, NRF Connet application able to scan my advertising device. I have attached my Scanner and Advertising beacon code. Please, can you check why i am not getting the my advertising device on scanner side. Can you guide me to add the filter so it can scan only device from NRF and NRF Beacon.
Thanks
Scanner.cpp
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "ble.h"
#include "nrf_delay.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define SCAN_INTERVAL                   0x00A0                              /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW                     0x0050                              /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION                   0x0000                              /**< Timout when scanning. 0x0000 disables timeout. */
#define APP_BLE_CONN_CFG_TAG            1                                   /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO           3                                   /**< Application's BLE observer priority. You shouldn't need to modify this value. */
static ble_gap_scan_params_t const m_scan_params =
    .extended = 0,
    .report_incomplete_evts = 0,
    .active   = 1,
    .filter_policy = BLE_GAP_SCAN_FP_ACCEPT_ALL,
    .scan_phys = BLE_GAP_PHY_1MBPS,
    .interval = SCAN_INTERVAL,
    .window   = SCAN_WINDOW,
    .timeout  = SCAN_DURATION
static uint8_t m_scan_buffer_data[BLE_GAP_SCAN_BUFFER_MIN]; /**< buffer where advertising reports will be stored by the SoftDevice. */
static ble_data_t m_scan_buffer =
    m_scan_buffer_data,
static void scan_start(void)
    (void) sd_ble_gap_scan_stop();
    sd_ble_gap_scan_start(&m_scan_params, &m_scan_buffer);
uint8_t * adv_address = 0; int8_t rssi = 0; uint8_t * adv_data = 0;
static void on_adv_report(ble_gap_evt_adv_report_t const * p_adv_report)
    adv_address = (uint8_t *)p_adv_report->peer_addr.addr;
    rssi = (int8_t)p_adv_report->rssi;
    adv_data = (uint8_t *)p_adv_report->data.p_data;
    //if(adv_address[0] == 0x73 && adv_address[1] == 0xE8)
    printf("MAC ID");
    for(int i=0;i<6;i++)
    printf(":%02X",adv_address[i]);
    printf("\tDATA: ");
    for(int j=0;j<16;j++)
    printf("%02X",adv_data[j]);
    printf("\tRSSI: %d DB\n", rssi);
    nrf_delay_ms(1000);
    ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
        case BLE_GAP_EVT_ADV_REPORT:
            on_adv_report(&p_gap_evt->params.adv_report);
        } break;
  uint32_t ram_start = 0;
  nrf_sdh_enable_request();
  nrf_sdh_ble_default_cfg_set(APP_BLE_CONN_CFG_TAG, &ram_start);
  nrf_sdh_ble_enable(&ram_start);
    NRF_LOG_INIT(NULL);
    nrf_pwr_mgmt_init();
    ble_stack_init();
    while(1)
      scan_start();
      NRF_LOG_FLUSH();
      nrf_pwr_mgmt_run();
Adv_beacon.cpp
#include <stdbool.h>
#include <stdint.h>
#include "nordic_common.h"
#include "nrf_soc.h"
#include "ble_advdata.h"
#define NON_CONNECTABLE_ADV_INTERVAL    MSEC_TO_UNITS(100, UNIT_0_625_MS)  /**< The advertising interval for non-connectable advertisement (100 ms). This value can vary between 100ms to 10.24s). */
#define APP_BEACON_INFO_LENGTH          0x17                               /**< Total length of information advertised by the Beacon. */
#define APP_ADV_DATA_LENGTH             0x15                               /**< Length of manufacturer specific data in the advertisement. */
#define APP_DEVICE_TYPE                 0x02                               /**< 0x02 refers to Beacon. */
#define APP_MEASURED_RSSI               0xC3                               /**< The Beacon's measured RSSI at 1 meter distance in dBm. */
#define APP_COMPANY_IDENTIFIER          0x0059                             /**< Company identifier for Nordic Semiconductor ASA. as per www.bluetooth.org. */
#define APP_MAJOR_VALUE                 0x01, 0x02                         /**< Major value used to identify Beacons. */
#define APP_MINOR_VALUE                 0x03, 0x04                         /**< Minor value used to identify Beacons. */
#define APP_BEACON_UUID                 0x01, 0x12, 0x23, 0x34, \
                                        0x45, 0x56, 0x67, 0x78, \
                                        0x89, 0x9a, 0xab, 0xbc, \
                                        0xcd, 0xde, 0xef, 0xf0            /**< Proprietary UUID for Beacon. */
static ble_gap_adv_params_t m_adv_params;                                  /**< Parameters to be passed to the stack when starting advertising. */
static uint8_t              m_adv_handle = BLE_GAP_ADV_SET_HANDLE_NOT_SET; /**< Advertising handle used to identify an advertising set. */
static uint8_t              m_enc_advdata[BLE_GAP_ADV_SET_DATA_SIZE_MAX];  /**< Buffer for storing an encoded advertising set. */
static ble_gap_adv_data_t m_adv_data =
    .adv_data =
        .p_data = m_enc_advdata,
        .len    = BLE_GAP_ADV_SET_DATA_SIZE_MAX
    .scan_rsp_data =
        .p_data = NULL,
        .len    = 0
static uint8_t m_beacon_info[APP_BEACON_INFO_LENGTH] =                    /**< Information advertised by the Beacon. */
    APP_DEVICE_TYPE,     // Manufacturer specific information. Specifies the device type in this
                         // implementation.
    //APP_ADV_DATA_LENGTH, // Manufacturer specific information. Specifies the length of the
                         // manufacturer specific data in this implementation.
    //APP_BEACON_UUID,     // 128 bit UUID value.
    //APP_MAJOR_VALUE,     // Major arbitrary value that can be used to distinguish between Beacons.
    //APP_MINOR_VALUE,     // Minor arbitrary value that can be used to distinguish between Beacons.
    //APP_MEASURED_RSSI    // Manufacturer specific information. The Beacon's measured TX power in
                         // this implementation.
    uint32_t      err_code;
    ble_advdata_t advdata;
    uint8_t       flags = BLE_GAP_ADV_FLAG_BR_EDR_NOT_SUPPORTED;
    ble_advdata_manuf_data_t manuf_specific_data;
    manuf_specific_data.company_identifier = APP_COMPANY_IDENTIFIER;
    manuf_specific_data.data.p_data = (uint8_t *) m_beacon_info;
    manuf_specific_data.data.size   = APP_BEACON_INFO_LENGTH;
    // Build and set advertising data.
    memset(&advdata, 0, sizeof(advdata));
    advdata.name_type             = BLE_ADVDATA_NO_NAME;
    advdata.flags                 = flags;
    advdata.p_manuf_specific_data = &manuf_specific_data;
    // Initialize advertising parameters (used when starting advertising).
    memset(&m_adv_params, 0, sizeof(m_adv_params));
    m_adv_params.properties.type = BLE_GAP_ADV_TYPE_NONCONNECTABLE_NONSCANNABLE_UNDIRECTED;
    m_adv_params.p_peer_addr     = NULL;    // Undirected advertisement.
    m_adv_params.filter_policy   = BLE_GAP_ADV_FP_ANY;
    m_adv_params.interval        = NON_CONNECTABLE_ADV_INTERVAL;
    m_adv_params.duration        = 0;       // Never time out.
    ble_advdata_encode(&advdata, m_adv_data.adv_data.p_data, &m_adv_data.adv_data.len);
    sd_ble_gap_adv_set_configure(&m_adv_handle, &m_adv_data, &m_adv_params);
   sd_ble_gap_adv_start(m_adv_handle, APP_BLE_CONN_CFG_TAG);
static void log_init(void)
    NRF_LOG_INIT(NULL);
    log_init();
    ble_stack_init();
    advertising_init();
    advertising_start();
    while(1)
        nrf_pwr_mgmt_run();
  • #include <stdint.h>
    #include <stdio.h>
    #include <string.h>
    #include "ble.h"
        .extended = 0,
        .active   = 1,
        m_scan_buffer_data,
        printf("MAC ID");
        printf("\tDATA: ");
        nrf_delay_ms(1000);
                scan_start(); // <-- NEW ADDITION
            } break;
        NRF_LOG_INIT(NULL);
        ble_stack_init();
        while(1)
          scan_start();
          NRF_LOG_FLUSH();
          nrf_pwr_mgmt_run();
    Thank you for information.
    I changed the code as you said but again I did not get any result on the log screen.
  • sorry for coming back so late, i tried these attached code in SDK17 without any modifications and it works as it is. I see no issues with scanner not able to find the beacon packets.
  • Thank you for your time. I really appreciate it. I just copy the above code to the BLE template code in SDK17 but unfortunately, I did not receive any data.
    Best,
