How to disable NRF52832 BLE power shutdown?
We are using NRF52832 with SDK15.0 to develop a wearable device that collects data every 10 seconds. It works fine except that NRF52832 shuts down automatically 1 hour after power is turned on. My question is: how to disable this automatic power down?
The code is quite simple, based on the sampel code project "ble_app_uart" from  Nordic, where main() is modified as follows:
void processing(void * p_context)
	DrawString(++m_Count);
	int count = 0;
	init_ble();
	init_timer(processing);
	start_timer(2000);
	for (;;) {
		idle_state_handle();
I traced into idle_state_handle(), that has this function nrf_pwr_mgmt_run() playing the role of shutdown.
void nrf_pwr_mgmt_run(void)
    PWR_MGMT_FPU_SLEEP_PREPARE();
    PWR_MGMT_SLEEP_LOCK_ACQUIRE();
    PWR_MGMT_CPU_USAGE_MONITOR_SECTION_ENTER();
    PWR_MGMT_DEBUG_PIN_SET();
    // Wait for an event.
#ifdef SOFTDEVICE_PRESENT
    if (nrf_sdh_is_enabled())
        ret_code_t ret_code = sd_app_evt_wait();
        ASSERT((ret_code == NRF_SUCCESS) || (ret_code == NRF_ERROR_SOFTDEVICE_NOT_ENABLED));
        UNUSED_VARIABLE(ret_code);
#endif // SOFTDEVICE_PRESENT
        __WFE();
        // Clear the internal event register.
        __SEV();
        __WFE();
    PWR_MGMT_DEBUG_PIN_CLEAR();
    PWR_MGMT_CPU_USAGE_MONITOR_SECTION_EXIT();
    PWR_MGMT_SLEEP_LOCK_RELEASE();
Interestingly, the shutdown will not occur if PWR_MGMT_FPU_SLEEP_PREPARE() is commented out. I assume that some kind counter is in this function, and clear of the counter will also prevent CPU fron shutdown. Unfortunately, this function can not be traced.
What to do to disable the shutdown thing? Many Thanks
Best regards, Dimtai
