problem to adding AES encription to secure DFU SDK15.0
Hi!
nRF52832, SDK15, SD6.0.0, S132
I try to use secure_bootloader from SDK15 examples. All works.
Now I need encrypt my firmware with AES. I already made it on a SDK13- works fine.
Now after encrypt .bin file in the dfu.zip package, I try to decrypt it in the bootloader project. For that I in a file
nrf_dfu_req_handler.c in a on_data_obj_write_request() function insert my decode function:
static void on_data_obj_write_request(nrf_dfu_request_t * p_req, nrf_dfu_response_t * p_res)
    NRF_LOG_DEBUG("Handle NRF_DFU_OP_OBJECT_WRITE (data)");
    if (!nrf_dfu_validation_init_cmd_present())
        /* Can't accept data because DFU isn't initialized by init command. */
        p_res->result = NRF_DFU_RES_CODE_OPERATION_NOT_PERMITTED;
        return;
    uint32_t const data_object_offset = s_dfu_settings.progress.firmware_image_offset -
                                        s_dfu_settings.progress.firmware_image_offset_last;
    if ((p_req->write.len + data_object_offset) > s_dfu_settings.progress.data_object_size)
        /* Can't accept data because too much data has been received. */
        NRF_LOG_ERROR("Write request too long");
        p_res->result = NRF_DFU_RES_CODE_INVALID_PARAMETER;
        return;
    uint32_t const write_addr = m_firmware_start_addr + s_dfu_settings.write_offset;
    ASSERT(p_req->callback.write);
                // az
                for (int i = 0; i < p_req->write.len; i+=16)
                    AES128_ECB_decrypt (p_req->write.p_data + i, key, p_req->write.p_data + i);
    ret_code_t ret =
        nrf_dfu_flash_store(write_addr, p_req->write.p_data, p_req->write.len, p_req->callback.write);
    if (ret != NRF_SUCCESS)
        /* When nrf_dfu_flash_store() fails because there is no space in the queue,
         * stop processing the request so that the peer can detect a CRC error
         * and retransmit this object. Remember to manually free the buffer !
        p_req->callback.write((void*)p_req->write.p_data);
        return;
    /* Update the CRC of the firmware image. */
    s_dfu_settings.write_offset                   += p_req->write.len;
    s_dfu_settings.progress.firmware_image_offset += p_req->write.len;
    s_dfu_settings.progress.firmware_image_crc     =
        crc32_compute(p_req->write.p_data, p_req->write.len, &s_dfu_settings.progress.firmware_image_crc);
    /* This is only used when the PRN is triggered and the 'write' message
     * is answered with a CRC message and these field are copied into the response.
    p_res->write.crc    = s_dfu_settings.progress.firmware_image_crc;
    p_res->write.offset = s_dfu_settings.progress.firmware_image_offset;
AES128_ECB_decrypt().....
One more- this function works fine with same syntax on the SDK13.
But in the SDK13 after that I write another CRC and it works.
Now on SDK15 when I try to update via smartphone, I see error on the smartphone - ERROC CRC.
Also I have RTT log of it:
 0> <debug> nrf_dfu_req_handler:
 0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (data)
 0> <debug> nrf_dfu_req_handler: Offset:2928, CRC:0xA907DD27
 0> <debug> nrf_dfu_req_handler: Request handling complete. Result: 0x1
 0> <debug> app: Shutting down transports (found: 1)
 0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (data)
 0> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x00039000, len=1 pages), queue usage: 0
 0> <debug> nrf_dfu_req_handler: Creating object with size: 4096. Offset: 0x00000000, CRC: 0x00000000
 0> <debug> nrf_dfu_ble: Buffer 0x20005EB8 acquired, len 244 (244)
 0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (data)
 0> <debug> nrf_dfu_flash: Flash erase success: addr=0x00039000, pending 0
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00039000, src=0x20005EB8, len=244 bytes), queue usage: 0
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x00039000, pending 0
 0> <debug> nrf_dfu_ble: Freeing buffer 0x20005EB8
 0> <debug> nrf_dfu_ble: Buffer 0x20005FAC acquired, len 244 (244)
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000390F4, src=0x20005EB8, len=244 bytes), queue usage: 0
 0> <debug> nrf_dfu_ble: Buffer 0x20006194 acquired, len 244 (244)
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x000390F4, pending 0
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000391E8, src=0x20005FAC, len=244 bytes), queue usage: 0
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x000391E8, pending 0
 0> <debug> nrf_dfu_ble: Freeing buffer 0x20005FAC
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000392DC, src=0x20006194, len=244 bytes), queue usage: 0
 0> <debug> nrf_dfu_ble: Buffer 0x20006288 acquired, len 244 (244)
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000393D0, src=0x20005EB8, len=244 bytes), queue usage: 1
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x000392DC, pending 1
 0> <debug> nrf_dfu_ble: Freeing buffer 0x20006194
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x000393D0, pending 0
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000394C4, src=0x20005FAC, len=244 bytes), queue usage: 0
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x000394C4, pending 0
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000395B8, src=0x20006288, len=244 bytes), queue usage: 0
 0> <debug> nrf_dfu_ble: Buffer 0x200060A0 acquired, len 244 (244)
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x000395B8, pending 0
 0> <debug> nrf_dfu_ble: Freeing buffer 0x20006288
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000396AC, src=0x20006194, len=244 bytes), queue usage: 0
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000397A0, src=0x20005EB8, len=244 bytes), queue usage: 1
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x000396AC, pending 1
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x000397A0, pending 0
 0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00039894, src=0x20005FAC, len=244 bytes), queue usage: 0
 0> <debug> nrf_dfu_flash: Flash write success: addr=0x00039894, pending 0
 0> x200060A0, len=244 bytes), queue usage: 0
 0> a)
 0> <debug> nrf_dfu_ble: Advertising...
 0> <info> nrf_bootloader_wdt: Internal feed
In wich place of bootloader should I clear or replace CRC ? I just want to reject this verification from bootloader.
  • You don't need to resume, just check the input of the CRC calculation function, to see if the input data are the same in both case or not  ?
    Most likely they are not the same.
    The CRC calculation function is very simple. The input is the previous CRC (make sure this one is the same in both cases) and the 244 byte data of new write command. If these 2 are matches the result CRC should be the same.
  • just added AES block or comment:
    without AES block:
    7485.wo_aes.log
    with AES:
    # SEGGER J-Link RTT Viewer V5.12f Terminal Log File
    # Compiled: 16:04:47 on May 17 2016
    # Logging started @ 21 Dec 2018 11:07:18
     0> <debug> nrf_dfu_ble: Connected
     0> <debug> nrf_dfu_ble: Received BLE_GAP_EVT_CONN_PARAM_UPDATE
     0> <debug> nrf_dfu_ble: max_conn_interval: 12
     0> <debug> nrf_dfu_ble: min_conn_interval: 12
     0> <debug> nrf_dfu_ble: slave_latency: 0
     0> <debug> nrf_dfu_ble: conn_sup_timeout: 600
     0> <debug> nrf_dfu_ble: Received BLE_GATTS_EVT_EXCHANGE_MTU_REQUEST (request: 517, reply: 247).
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (command)
     0> <debug> nrf_dfu_ble: Set receipt notif
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_RECEIPT_NOTIF_SET
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_CREATE (command)
     0> <debug> nrf_dfu_ble: Buffer 0x20005EB8 acquired, len 135 (244)
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_WRITE (command)
     0> <debug> nrf_dfu_validation:  az nrf_dfu_validation_init_cmd_append CRC = 0x5DA7B5DB
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_CRC_GET (command)
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_EXECUTE (command)
     0> <debug> nrf_dfu_validation: PB: Init packet data len: 58
     0> <info> nrf_dfu_validation: Signature required. Checking signature.
     0> <info> nrf_dfu_validation: Calculating init packet hash (init packet len: 58)
     0> <info> nrf_dfu_validation: Verify signature
     0> <info> nrf_dfu_validation: Image verified
     0> <debug> app: Enter nrf_dfu_cache_prepare()
     0> <debug> app: required_size: 0x127A0.
     0> <debug> app: single_bank: false.
     0> <debug> app: keep_app: false.
     0> <debug> app: keep_softdevice: true.
     0> <debug> app: SD_PRESENT: true.
     0> <debug> app: Bank contents:
     0> <debug> app: Bank 0 code: 0x01: Size: 0x127A0
     0> <debug> app: Bank 1 code: 0x00: Size: 0x0
     0> <debug> app: pass: 0.
     0> <debug> app: cache_address: 0x39000.
     0> <debug> app: cache_too_small: false.
     0> <debug> app: keep_firmware: false.
     0> <debug> app: delete_more: false.
     0> <debug> nrf_dfu_validation: Write address set to 0x00039000
     0> <debug> nrf_dfu_settings: Writing settings...
     0> <debug> nrf_dfu_settings: Erasing old settings at: 0x0007F000
     0> <debug> nrf_dfu_flash: nrf_fstorage_erase(addr=0x0x0007F000, len=1 pages), queue usage: 0
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x0007F000, src=0x20006EEC, len=440 bytes), queue usage: 1
     0> <debug> nrf_dfu_req_handler: Writing valid init command to flash.
     0> <debug> nrf_dfu_flash: Flash erase success: addr=0x0007F000, pending 1
     0> <debug> nrf_dfu_flash: Flash write success: addr=0x0007F000, pending 0
     0> <debug> nrf_dfu_req_handler: Handle NRF_DFU_OP_OBJECT_SELECT (data)
     0> <debug> nrf_dfu_req_handler: crc = 0x0, offset = 0x0, max_size = 0x1000
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x000000A5
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_p_req->write.len = 0x000000F4
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_&s_dfu_settings.progress.firmware_image_crc = 0x200070EC
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00039000, src=0x20005EB8, len=244 bytes), queue usage: 1
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0xA5BE0D95
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x00000000
     0> <debug> nrf_dfu_flash: Flash erase success: addr=0x00039000, pending 1
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000390F4, src=0x20005FAC, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0xE5314F14
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x00000065
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0x9ECA00EB
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x00000015
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000392DC, src=0x20005EB8, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0x9762C394
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x00000092
     0> <debug> nrf_dfu_flash: Flash write success: addr=0x000392DC, pending 0
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000393D0, src=0x20005FAC, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0x44ED2D93
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x00000004
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000394C4, src=0x200060A0, len=244 bytes), queue usage: 1
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0x4728C0BC
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x0000003A
     0> <debug> nrf_dfu_flash: Flash write success: addr=0x000393D0, pending 1
     0> <debug> nrf_dfu_ble: Freeing buffer 0x200060A0
     0> x20005EB8, len=244 bytes), queue usage: 0
     0>  0xA23B0BC0
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00039000, src=0x20006288, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x00000009
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000390F4, src=0x20006288, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0x65491F3A
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000391E8, src=0x20005EB8, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0xB42E4DC3
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000392DC, src=0x200060A0, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0x9C65D3A5
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x0000001B
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000393D0, src=0x20006288, len=244 bytes), queue usage: 1
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0xA314E743
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x00000095
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000394C4, src=0x20005EB8, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0x6F63CA50
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request crc32_compute_*p_req->write.p_data = 0x000000B5
     0> C
     0> ding 0
     0>  0x7CF62A1D
     0> 0x1
     0> a)
     0> C
     0> 0x1
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x00039000, src=0x20005FAC, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000391E8, src=0x20006194, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000393D0, src=0x20005FAC, len=244 bytes), queue usage: 1
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0xE77404FF
     0> <debug> nrf_dfu_flash: nrf_fstorage_write(addr=0x000394C4, src=0x20006194, len=244 bytes), queue usage: 0
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC = 0x9B7AD0E4
     0> <debug> nrf_dfu_req_handler:  az on_data_obj_write_request CRC =0x1
  • seems,
    antother due to adding some code. And address of
    some moved. It is my opinion.
  • Hi Mikhail,
    Could you printout value of firmware_image_crc ? not the address of it. It's normal to have different address when you modified the code.
