I am unable to program the nRF52 Dongle. What I see is that the "Write" option is not highlighted.
Though the Bootloader and Softdevice are already there on the dongle.
Thanks
Abhishek
Thanks
Abhishek
It looks like the update went fine.
Abhishek said:2018-12-13T18:45:19.600Z INFO DFU for Application completed successfully!
It always says "INFO Nordic DFU Trigger Interface was not found. Please physically reset device."
This just means that the device is no longer in DFU mode, and hence, it is not responding to the USB as a DFU device, which is what nRF Connect is looking for.
Now, I don't know what example you put on the dongle, but it may be that it is running, just that you can't see it. Note that the UART pins are not the same as the USB pins, so you will not get any log information. I suggest you try the blinky example for pca10059, then you should see that the LEDs blink.
So what application did you modify and upload to the Dongle?
BR,
Edvin
HI,
It is a customized application coming from blinky_app_c, it scans particular beacons and sends it across on SPI. I am aware of the that UART will not work, but I am not able to see any output on SPI.
I am using a pca10056 DK where I can see the output. The same code I change the preprocessor directives and memory setting for pca10059 ( dongle) it does not work? Below is the main file
* Copyright (c) 2014 - 2018, Nordic Semiconductor ASA
* All rights reserved.
* list of conditions and the following disclaimer.
* Semiconductor ASA integrated circuit in a product or a software update for
* such product, must reproduce the above copyright notice, this list of
* conditions and the following disclaimer in the documentation and/or other
* materials provided with the distribution.
* contributors may be used to endorse or promote products derived from this
* software without specific prior written permission.
* Nordic Semiconductor ASA integrated circuit.
* engineered, decompiled, modified and/or disassembled.
* @brief BLE LED Button Service central and client application main file.
* This file contains the source code for a sample client application using the LED Button service.
#include "sdk_config.h"
#include "nrf_drv_spis.h"
#include <stdint.h>
#include <stdio.h>
#include <string.h>
#include "nrf_sdh.h"
#include "nrf_sdh_ble.h"
#include "nrf_sdh_soc.h"
#include "nrf_pwr_mgmt.h"
#include "app_timer.h"
#include "boards.h"
#include "bsp.h"
#include "bsp_btn_ble.h"
#include "ble.h"
#include "ble_hci.h"
#include "ble_advertising.h"
#include "ble_conn_params.h"
#include "ble_db_discovery.h"
#include "ble_lbs_c.h"
#include "nrf_ble_gatt.h"
#include "nrf_ble_scan.h"
#include "nrf_log.h"
#include "nrf_log_ctrl.h"
#define CENTRAL_SCANNING_LED BSP_BOARD_LED_0 /**< Scanning LED will be on when the device is scanning. */
#define CENTRAL_CONNECTED_LED BSP_BOARD_LED_1 /**< Connected LED will be on when the device is connected. */
#define LEDBUTTON_LED BSP_BOARD_LED_2 /**< LED to indicate a change of state of the the Button characteristic on the peer. */
#define SCAN_INTERVAL 0x00A0 /**< Determines scan interval in units of 0.625 millisecond. */
#define SCAN_WINDOW 0x0050 /**< Determines scan window in units of 0.625 millisecond. */
#define SCAN_DURATION 0x0000 /**< Timout when scanning. 0x0000 disables timeout. */
#define MIN_CONNECTION_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS) /**< Determines minimum connection interval in milliseconds. */
#define MAX_CONNECTION_INTERVAL MSEC_TO_UNITS(30, UNIT_1_25_MS) /**< Determines maximum connection interval in milliseconds. */
#define SLAVE_LATENCY 0 /**< Determines slave latency in terms of connection events. */
#define SUPERVISION_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS) /**< Determines supervision time-out in units of 10 milliseconds. */
#define LEDBUTTON_BUTTON_PIN BSP_BUTTON_0 /**< Button that will write to the LED characteristic of the peer */
#define BUTTON_DETECTION_DELAY APP_TIMER_TICKS(50) /**< Delay from a GPIOTE event until a button is reported as pushed (in number of timer ticks). */
#define APP_BLE_CONN_CFG_TAG 1 /**< A tag identifying the SoftDevice BLE configuration. */
#define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
NRF_BLE_SCAN_DEF(m_scan); /**< Scanning module instance. */
BLE_LBS_C_DEF(m_ble_lbs_c); /**< Main structure used by the LBS client module. */
NRF_BLE_GATT_DEF(m_gatt); /**< GATT module instance. */
BLE_DB_DISCOVERY_DEF(m_db_disc); /**< DB discovery module instance. */
//static char const m_target_periph_name[] = "Nordic_Blinky"; /**< Name of the device we try to connect to. This name is searched in the scan report data*/
#define SCAN_LIST_REFRESH_INTERVAL 5000 // 5 sec
#define FOUND_DEVICE_REFRESH_TIME APP_TIMER_TICKS(SCAN_LIST_REFRESH_INTERVAL) /**< Time after which the device list is clean and refreshed. */
#define DEVICE_NAME_MAX_SIZE 20
//#define DEVICE_TO_FIND_MAX 20 //Max numbers of devices in the list
#define DEVICE_TO_FIND_MAX 30 //Max numbers of devices in the list
#define FILTER_ON_COMPANY_ID 1 // Only matching company_identifiers will be added to the list.
//#define COMPANY_ID_0 0x06 // E.g. 0x02 and 0x77 ->ABC inc, 06 00 is Microsoft.
//#define COMPANY_ID_1 0x00
#define COMPANY_ID_0 0x77 //0x0277 , 0x0006 for Microsoft
#define COMPANY_ID_1 0x02
#define SPIS_INSTANCE 1 /**< SPIS instance index. */
static const nrf_drv_spis_t spis = NRF_DRV_SPIS_INSTANCE(SPIS_INSTANCE);/**< SPIS instance. */
#define TEST_STRING "Nordic"
static uint8_t m_tx_buf[] = TEST_STRING; /**< TX buffer. */
static uint8_t m_rx_buf[sizeof(TEST_STRING) + 1]; /**< RX buffer. */
static const uint16_t m_length = sizeof(m_tx_buf); /**< Transfer length. */
static volatile bool spis_xfer_done; /**< Flag used to indicate that SPIS instance completed the transfer. */
typedef struct
bool is_not_empty; /**< Indicates that the structure is not empty. */
uint16_t size; /**< Size of manuf data. */
uint8_t addr[BLE_GAP_ADDR_LEN]; /**< Device address. */
char dev_name[DEVICE_NAME_MAX_SIZE]; /**< Device name. */
uint8_t manuf_buffer[BLE_GAP_ADV_SET_DATA_SIZE_MAX]; /**< Buffer for storing an manuf data. */
} scanned_device_t;
void device_list_print(scanned_device_t * p_device);
void send_on_spi(scanned_device_t * ad_device);
scanned_device_t m_device[DEVICE_TO_FIND_MAX]; /**< Stores device info from scan data. */
/**@brief Function for printing the devices.
*@details Function print list of devices.
* @param[in] device Pointer to the struct storing the scanned devices.
NRF_LOG_INFO("==== PRINTING DEVICE LIST ===");
for (uint8_t i = 0; i < DEVICE_TO_FIND_MAX; i++)
if (p_device[i].is_not_empty)
NRF_LOG_INFO("Device list number: %d:",i);
NRF_LOG_INFO("Device-addr %02x:%02x:%02x:%02x:%02x:%02x",
p_device[i].addr[5],
p_device[i].addr[4],
p_device[i].addr[3],
p_device[i].addr[2],
p_device[i].addr[1],
p_device[i].addr[0]
NRF_LOG_INFO("ManufData:");
NRF_LOG_HEXDUMP_INFO(m_device[i].manuf_buffer,m_device[i].size);
NRF_LOG_INFO("");
NRF_LOG_INFO("======================");
// Data Transmission on SPI bus
NRF_LOG_INFO("==== SENDING ADDRESS ON SPI===");
// memset(m_rx_buf, 0, m_length);
spis_xfer_done = false;
if (ad_device[i].is_not_empty)
//NRF_LOG_INFO("Device list number: %d:",i);
for (uint8_t js = 5; js > 0 ; js--)
// uint8_t const * tx_buffer= &p_device[i].addr[j];
nrf_drv_spis_buffers_set(&spis, &ad_device[i].addr[js] , m_length, m_rx_buf, m_length);
NRF_LOG_INFO("==== ADDRESS %d SENT ON SPI===", js);
// while (!spis_xfer_done);
__WFE();
if(!spis_xfer_done)
NRF_LOG_INFO("==== ADDRESS SENT ON SPI===");
/* NRF_LOG_INFO("Device-addr %02x:%02x:%02x:%02x:%02x:%02x",
p_device[i].addr[0]
NRF_LOG_INFO("ManufData on SPI:");
APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_device[i].manuf_buffer,m_device[i].size, m_rx_buf, m_length));
// NRF_LOG_HEXDUMP_INFO(m_device[i].manuf_buffer,m_device[i].size);
NRF_LOG_INFO("Tx on SPI done");
void scan_device_info_clear(void)
memset(m_device, 0, sizeof(m_device));
scanned_device_t * scan_device_info_get(void)
return m_device;
typedef struct
uint8_t * p_data; /**< Pointer to data. */
uint16_t data_len; /**< Length of data. */
} data_t;
static void device_to_list_add(ble_gap_evt_adv_report_t const * p_adv_report)
uint8_t idx = 0;
uint16_t dev_name_offset = 0;
uint16_t field_len;
data_t adv_data;
// Initialize advertisement report for parsing
adv_data.p_data = (uint8_t *)p_adv_report->data.p_data;
adv_data.data_len = p_adv_report->data.len;
for ( idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
// If address is duplicated, then return.
if (memcmp(p_adv_report->peer_addr.addr,
m_device[idx].addr,
sizeof(p_adv_report->peer_addr.addr)) == 0)
return;
// Device is not in the list.
for (idx = 0; idx < DEVICE_TO_FIND_MAX; idx++)
if (!m_device[idx].is_not_empty) // We find an empty entry
// Search for manuf_specific_data.
uint8_t * p_manuf = ble_advdata_parse(p_adv_report->data.p_data,
p_adv_report->data.len,
BLE_GAP_AD_TYPE_MANUFACTURER_SPECIFIC_DATA);
// If manuf_specific_data is not found, then return.
if(p_manuf == NULL)
return;
uint16_t data_offset = 0;
uint8_t manuf_len;
manuf_len = ble_advdata_search(p_adv_report->data.p_data,
&data_offset,
uint8_t company_id[2];
memset(company_id,0,2);
memcpy(company_id, p_manuf, 2);
if(FILTER_ON_COMPANY_ID == 0)
// We add all devices with manuf_specific_data to the list
m_device[idx].is_not_empty = true; //validating the list record
memset(m_device[idx].manuf_buffer,0,BLE_GAP_ADV_SET_DATA_SIZE_MAX);
memcpy(m_device[idx].manuf_buffer, p_manuf, manuf_len);
m_device[idx].size = manuf_len;
memset(m_device[idx].addr,
0,
sizeof(p_adv_report->peer_addr.addr));
memcpy(m_device[idx].addr,
return;
if( (FILTER_ON_COMPANY_ID == 1) &&
(company_id[0] == COMPANY_ID_0 ) &&
(company_id[1] == COMPANY_ID_1) )
// We add ONLY devices with correct company ID to the list
0,
NRF_LOG_INFO("MANUFACTURER_SPECIFIC_DATA FOUND with correct company_id");
return;
//NRF_LOG_HEXDUMP_INFO(m_device[idx].manuf_buffer,m_device[idx].size);
return;
/**@brief Function to handle asserts in the SoftDevice.
* how your product is supposed to react in case of Assert.
* @param[in] line_num Line number of the failing ASSERT call.
* @param[in] p_file_name File name of the failing ASSERT call.
app_error_handler(0xDEADBEEF, line_num, p_file_name);
/**@brief Function for the LEDs initialization.
* @details Initializes all LEDs used by the application.
static void leds_init(void)
/**@brief Function to start scanning.
static void scan_start(void)
ret_code_t err_code;
err_code = nrf_ble_scan_start(&m_scan);
bsp_board_led_off(CENTRAL_CONNECTED_LED);
bsp_board_led_on(CENTRAL_SCANNING_LED);
* @param[in] p_ble_evt Bluetooth stack event.
* @param[in] p_context Unused.
// For readability.
ble_gap_evt_t const * p_gap_evt = &p_ble_evt->evt.gap_evt;
// Upon connection, check which peripheral has connected (HR or RSC), initiate DB
// discovery, update LEDs status and resume scanning if necessary. */
case BLE_GAP_EVT_CONNECTED:
NRF_LOG_INFO("Connected.");
// err_code = ble_lbs_c_handles_assign(&m_ble_lbs_c, p_gap_evt->conn_handle, NULL);
// APP_ERROR_CHECK(err_code);
// err_code = ble_db_discovery_start(&m_db_disc, p_gap_evt->conn_handle);
// Update LEDs status, and check if we should be looking for more
// peripherals to connect to.
bsp_board_led_on(CENTRAL_CONNECTED_LED);
bsp_board_led_off(CENTRAL_SCANNING_LED);
} break;
// Upon disconnection, reset the connection handle of the peer which disconnected, update
// the LEDs status and start scanning again.
NRF_LOG_INFO("Disconnected.");
scan_start();
} break;
case BLE_GAP_EVT_TIMEOUT:
// We have not specified a timeout for scanning, so only connection attemps can timeout.
if (p_gap_evt->params.timeout.src == BLE_GAP_TIMEOUT_SRC_CONN)
NRF_LOG_DEBUG("Connection request timed out.");
} break;
case BLE_GAP_EVT_CONN_PARAM_UPDATE_REQUEST:
// Accept parameters requested by peer.
err_code = sd_ble_gap_conn_param_update(p_gap_evt->conn_handle,
&p_gap_evt->params.conn_param_update_request.conn_params);
} break;
ble_gap_phys_t const phys =
.rx_phys = BLE_GAP_PHY_AUTO,
.tx_phys = BLE_GAP_PHY_AUTO,
} break;
case BLE_GATTC_EVT_TIMEOUT:
} break;
case BLE_GATTS_EVT_TIMEOUT:
} break;
// No implementation needed.
* @details Initializes the SoftDevice and the BLE event interrupts.
uint32_t ram_start = 0;
// Enable BLE stack.
/**@brief Function for handling events from the button handler module.
* @param[in] pin_no The pin that the event applies to.
* @param[in] button_action The button action (press/release).
static void button_event_handler(uint8_t pin_no, uint8_t button_action)
switch (pin_no)
case LEDBUTTON_BUTTON_PIN:
//APP_ERROR_HANDLER(pin_no);
/**@brief Function for handling Scaning events.
* @param[in] p_scan_evt Scanning event.
static void scan_evt_handler(scan_evt_t const * p_scan_evt)
switch(p_scan_evt->scan_evt_id)
case NRF_BLE_SCAN_EVT_CONNECTING_ERROR:
err_code = p_scan_evt->params.connecting_err.err_code;
case NRF_BLE_SCAN_EVT_NOT_FOUND:
device_to_list_add(p_scan_evt->params.p_not_found);
/**@brief Function for initializing the button handler module.
static void buttons_init(void)
//The array must be static because a pointer to it will be saved in the button handler module.
static app_button_cfg_t buttons[] =
{LEDBUTTON_BUTTON_PIN, false, BUTTON_PULL, button_event_handler}
err_code = app_button_init(buttons, ARRAY_SIZE(buttons),
BUTTON_DETECTION_DELAY);
/**@brief Function for initializing the log.
static void log_init(void)
/**@brief Function for handling the list_timer event,
static void adv_list_timer_handle(void * p_context)
// Print devices
scanned_device_t * p_device_list = scan_device_info_get();
device_list_print(p_device_list);
// send_on_spi(p_device_list);
//scan_device_info_clear();
/**@brief Function for initializing the timer.
static void timer_init(void)
// Timer for refreshing scanned devices data.
APP_TIMER_DEF(adv_list_timer);
err_code = app_timer_create(&adv_list_timer, APP_TIMER_MODE_REPEATED, adv_list_timer_handle);
err_code = app_timer_start(adv_list_timer, FOUND_DEVICE_REFRESH_TIME, NULL);
/**@brief Function for initializing the Power manager. */
static void scan_init(void)
nrf_ble_scan_init_t init_scan;
memset(&init_scan, 0, sizeof(init_scan));
init_scan.connect_if_match = false;
init_scan.conn_cfg_tag = APP_BLE_CONN_CFG_TAG;
err_code = nrf_ble_scan_init(&m_scan, &init_scan, scan_evt_handler);
// // Setting filters for scanning.
// err_code = nrf_ble_scan_filters_enable(&m_scan, NRF_BLE_SCAN_NAME_FILTER, false);
// err_code = nrf_ble_scan_filter_set(&m_scan, SCAN_NAME_FILTER, m_target_periph_name);
/**@brief Function for initializing the GATT module.
static void gatt_init(void)
ret_code_t err_code = nrf_ble_gatt_init(&m_gatt, NULL);
* @details Handle any pending log operation(s), then sleep until the next event occurs.
NRF_LOG_FLUSH();
nrf_pwr_mgmt_run();
* @brief SPIS user event handler.
* @param event
void spis_event_handler(nrf_drv_spis_event_t event)
if (event.evt_type == NRF_DRV_SPIS_XFER_DONE)
spis_xfer_done = true;
NRF_LOG_INFO(" Transfer completed. Received: %s",(uint32_t)m_rx_buf);
// NRF_LOG_INFO(" Transfer completed. Received: %d",(int32_t)m_rx_buf);
// Initialize.
log_init();
timer_init();
leds_init();
buttons_init();
power_management_init();
ble_stack_init();
scan_init();
gatt_init();
// Start execution.
NRF_LOG_INFO("Beacon scanner example started.");
scan_start();
// Turn on the LED to signal scanning.
//SPI Transmission Init
NRF_LOG_INFO("SPIS Transmission parameters set");
nrf_drv_spis_config_t spis_config = NRF_DRV_SPIS_DEFAULT_CONFIG;
spis_config.csn_pin = APP_SPIS_CS_PIN;
spis_config.miso_pin = APP_SPIS_MISO_PIN;
spis_config.mosi_pin = APP_SPIS_MOSI_PIN;
spis_config.sck_pin = APP_SPIS_SCK_PIN;
APP_ERROR_CHECK(nrf_drv_spis_init(&spis, &spis_config, spis_event_handler));
// Enter main loop.
for (;;)
// APP_ERROR_CHECK(nrf_drv_spis_buffers_set(&spis, m_tx_buf, m_length, m_rx_buf, m_length));
for (uint8_t js = 6; js > 0 ;)
js--;
nrf_drv_spis_buffers_set(&spis, &p_device_list[0].addr[js] , m_length, m_rx_buf, m_length);
// js--;
nrf_drv_spis_buffers_set(&spis, m_device[0].manuf_buffer, m_device[0].size, m_rx_buf, m_length);
// __WFE();
idle_state_handle();
// idle_state_handle();
// __WFE();
}Have you tried this project (with the PCA10059 preprocessor define) on the DK? Then you can monitor the logging information, and do some debugging to see whether there are any other issues. Maybe it doesn't work because it doesn't have enough buttons?
BR,
Edvin
Hi Edvin,
Yes I tried with the preprocessor define as mentioned in the link you provided :
That also did not work. Then I tried the example in the SDK for the dongle itslef.
\nRF5_SDK_15.2.0_9412b96\examples\ble_peripheral\ble_app_blinky\pca10059
I built this example and tried to program with the .hex file it showed the same indications in nRF Connect.
Assuming that the device is programmed ( because this was as is example from Nordic SDK) the LED's should have blinked, but it did not happen.
Thanks
Abhishek
Hi Edvin,
Seems like I am able to program it now:
Here is what I followed:
1) Reprogrammed the softdevice ( i think earlier it was over lapping with the existing code)
2) calculated the memory usage of flash and changed the Flash start address in the placement macros.
But the problem here is that the same code shows no data on SPI comms while it is running on the dongle, but as i run on the PCA10056 it shows data on SPI comms.
I am not sure what is wrong here.
To explain a little more about my setup:
Master program runs on ESP32 devkitC, as the voltage levels on this board is 3.3V I use a level shifter to make it work with PCA10056 eval board and the dongle.
The same setup works well with the eval board but does not with the dongle.
Thanks
Abhishek
