Serial port on the nRF52840 Dongle
Hi I am trying to init the serial on the nRF52840 Dongle but there are some defines missing in the boards/pca10069.h
I run this on the nRF52840 DK and it works fine.
NRF_SERIAL_DRV_UART_CONFIG_DEF(m_uart0_drv_config,
    RX_PIN_NUMBER, TX_PIN_NUMBER,
    RTS_PIN_NUMBER, CTS_PIN_NUMBER,
    NRF_UART_HWFC_ENABLED, NRF_UART_PARITY_EXCLUDED,
    NRF_UART_BAUDRATE_115200,
    UART_DEFAULT_CONFIG_IRQ_PRIORITY);
file: boards/pca10056.h
#define RX_PIN_NUMBER  8
#define TX_PIN_NUMBER  6
#define CTS_PIN_NUMBER 7
#define RTS_PIN_NUMBER 5
#define HWFC           true
    I'm interested in doing something similar to the original question here with an nRF52840 Dongle where I'd like to stream data over the dongle's USB connection and read it from a computer via /dev/ttyACMx. I've tried to compile the usbd_cdc_acm example to use as a template but it seems to rely on TX_PIN_NUMBER and RX_PIN_NUMBER constants that aren't defined for pca10059.
    Is this kind of setup possible with pca10059? Is usbd_cdc_acm the right example to use (it doesn't have a pca10059 subfolder)?
  • This works for both my dev board and the dongle.
    #include <stdlib.h>
    #include "zboss_api.h"
    #include "sdk_config.h"
    #include "app_usbd.h"
    #include "app_usbd_cdc_acm.h"
    #include "app_usbd_serial_num.h"
    //#include "app_usbd_string_desc.h"
    #include "boards.h"
    #include "serial_handler.h"
     * @brief Enable power USB detection
     * Configure if example supports USB port connection
    #ifndef USBD_POWER_DETECTION
    #define USBD_POWER_DETECTION true
    static zb_uint8_t tx = 0;
    static void cdc_acm_user_ev_handler(app_usbd_class_inst_t const * p_inst, app_usbd_cdc_acm_user_event_t event);
    static void usbd_user_ev_handler(app_usbd_event_type_t event);
    #define CDC_ACM_COMM_INTERFACE  0
    #define CDC_ACM_COMM_EPIN       NRF_DRV_USBD_EPIN2
    #define CDC_ACM_DATA_INTERFACE  1
    #define CDC_ACM_DATA_EPIN       NRF_DRV_USBD_EPIN1
    #define CDC_ACM_DATA_EPOUT      NRF_DRV_USBD_EPOUT1
     * @brief CDC_ACM class instance
    APP_USBD_CDC_ACM_GLOBAL_DEF(serial_uart,
                                cdc_acm_user_ev_handler,
                                CDC_ACM_COMM_INTERFACE,
                                CDC_ACM_DATA_INTERFACE,
                                CDC_ACM_COMM_EPIN,
                                CDC_ACM_DATA_EPIN,
                                CDC_ACM_DATA_EPOUT,
                                //APP_USBD_CDC_COMM_PROTOCOL_AT_V250
                                APP_USBD_CDC_COMM_PROTOCOL_NONE
    void serial_reset()
        serial_command_hdr_t rts;
        rts.size    = 0xC0C0;
        rts.command = SERIAL_CMD_INVALID;
        app_usbd_cdc_acm_write(&serial_uart, &rts, sizeof(rts) );
    void serial_init()
        static const app_usbd_config_t usbd_config = {
            .ev_state_proc = usbd_user_ev_handler
        ret_code_t ret;
        app_usbd_serial_num_generate();
        ret = app_usbd_init(&usbd_config);
        APP_ERROR_CHECK(ret);
        app_usbd_class_inst_t const * class_cdc_acm = app_usbd_cdc_acm_class_inst_get(&serial_uart);
        ret = app_usbd_class_append(class_cdc_acm);
        EVT_LOG("USBD CDC ACM example started.\n", NULL);
        if (USBD_POWER_DETECTION)
            ret = app_usbd_power_events_enable();
            EVT_LOG("No USB power detection enabled\nStarting USB now\n", NULL);
            app_usbd_enable();
            app_usbd_start();
    struct _tx_item
        void* p;
        size_t s;
    #define TX_MAX 32
    static int _tx_pos  = 0;
    static int _tx_next = 0;
    static struct _tx_item tx_queue[ TX_MAX ];
    static void __send_it(void* hdr, size_t hdr_size, void* buf, size_t blen )
        zb_uint8_t* t = (zb_uint8_t*)malloc(hdr_size + blen );
        memcpy( t, hdr, hdr_size);
        if( blen > 0 && buf != NULL )
            memcpy( &t[hdr_size], buf, blen );
        if (tx_queue[_tx_next].p != NULL)
            // OOM.....
            PRINT("tx_queue is full !!... dropping packet! %d %d\n",  _tx_pos, _tx_next);
            free(t);
            return;
        tx_queue[_tx_next].p = t;
        tx_queue[_tx_next].s = hdr_size + blen;
        // No on going item send now!
        if( _tx_pos == _tx_next )
            if( app_usbd_cdc_acm_write(&serial_uart, t, hdr_size + blen ) == NRF_ERROR_INVALID_STATE )
                // No serial connected, just drop packet!
                tx_queue[_tx_next].p = NULL;
                tx_queue[_tx_next].s = 0;
                free(t);
                return;
        ++_tx_next;
        if( _tx_next >= TX_MAX )
            _tx_next = 0;
    static cb_command_handler      command_handler     = NULL;
    static cb_port_status_handler  port_status_handler = NULL;
    void serial_set_command_handler(cb_command_handler cb)
        command_handler = cb;
    void serial_set_port_status_handler(cb_port_status_handler cb)
        port_status_handler = cb;
        app_usbd_cdc_acm_t const * p_cdc_acm = app_usbd_cdc_acm_class_get(p_inst);
        static char tmp[1024];
        static uint16_t tmp_i     = 0;
        static uint16_t size      = 0;
        switch (event)
            case APP_USBD_CDC_ACM_USER_EVT_PORT_OPEN:
                tmp_i = 2;
                size  = 0;
                tx = 0;
                memset(tmp,0,sizeof(tmp));
                /*Setup first transfer*/
                ret_code_t ret = app_usbd_cdc_acm_read(&serial_uart,
                                                       tmp,
                                                       sizeof(size));
                UNUSED_VARIABLE(ret);
                bsp_board_led_on(BSP_BOARD_LED_0);
                if( port_status_handler != NULL )
                    port_status_handler( true );
            case APP_USBD_CDC_ACM_USER_EVT_PORT_CLOSE:
                bsp_board_led_off(BSP_BOARD_LED_0);
                    port_status_handler( false );
            case APP_USBD_CDC_ACM_USER_EVT_TX_DONE:
                free( tx_queue[_tx_pos].p );
                tx_queue[_tx_pos].p = NULL;
                tx_queue[_tx_pos].s = 0;
                // We should normaly only go once in this loop, but if there is an
                // error sending its most likly due to disconnected serial and we will
                // loop thrue and flush the queue.
                do
                    ++_tx_pos;
                    if( _tx_pos >= TX_MAX )
                        _tx_pos = 0;
                    if( _tx_pos != _tx_next )
                        if( app_usbd_cdc_acm_write(&serial_uart, tx_queue[_tx_pos].p, tx_queue[_tx_pos].s ) == NRF_ERROR_INVALID_STATE )
                            PRINT( "Drop from queue packet... %d %d\n", _tx_pos, _tx_next);
                            free(tx_queue[_tx_pos].p);
                }while( _tx_pos != _tx_next );
            case APP_USBD_CDC_ACM_USER_EVT_RX_DONE:
                ret_code_t ret;
                do
                    //size_t xsize = app_usbd_cdc_acm_rx_size(p_cdc_acm);
                    //EVT_LOG("Bytes waiting: %zd %hu:%hu\n", xsize, tmp_i, size );
                    if( size == 0 )
                        memcpy(&size, tmp, sizeof(size));
                        ret = app_usbd_cdc_acm_read_any(&serial_uart, &tmp[tmp_i], 1);
                        continue;
                    if (tmp_i < size)
                        ++tmp_i;
                    if (size == tmp_i)
                        if (command_handler != NULL)
                            command_handler(tmp);
                        tmp_i = 2;
                        size  = 0;
                        app_usbd_cdc_acm_read(&serial_uart, tmp, sizeof(size));
                    if (ret != NRF_SUCCESS)
                } while (ret == NRF_SUCCESS);
                PRINT("Unhandled usb event: %x\n",event);
        switch (event)
            case APP_USBD_EVT_DRV_SUSPEND:
                PRINT("USB_RESUME\n",NULL);
            case APP_USBD_EVT_DRV_RESUME:
            case APP_USBD_EVT_STARTED:
            case APP_USBD_EVT_STOPPED:
                app_usbd_disable();
                bsp_board_leds_off();
            case APP_USBD_EVT_POWER_DETECTED:
                PRINT("USB power detected\n",NULL);
                if (!nrf_drv_usbd_is_enabled())
                    app_usbd_enable();
            case APP_USBD_EVT_POWER_REMOVED:
                PRINT("USB power removed\n",NULL);
                app_usbd_stop();
            case APP_USBD_EVT_POWER_READY:
                PRINT("USB ready\n",NULL);
                app_usbd_start();
                PRINT("USB unhandled event:%x\n", event);
    void serial_process()
        app_usbd_event_queue_process();
  • Hey Jimmy,
    I'm trying to run this sample on a nr52840 dongle, and I can't seem to find a definition for the rts struct. Any chance you'd know?
  • The struct is not part of Nordic SDK its part of our source.
    typedef struct serial_command_hdr
        zb_uint16_t size;
        zb_uint8_t command; // serial_command_t
    } serial_command_hdr_t;
  • Running into something similar on the cb_command_handler/cb_port_status_handler. If this is part of a larger framework, let me know.
