SPI long data transfer
Hello Everyone,
I am newbie to nordic BLE environment. This maybe a silly question.
Currently I am using nrf51 DK with SDK11, S130.
Data to be sent through SPI:
I checked the example code in SDK11, and there is example code and m_tx_buf is variable for sending data, but not sure how should I send all the data mentioned in above image. Data is very long to be sent as data is of type long long and m_tx_buf is of type const uin8_t *.
This link embed entire initialisation values of LCD init command in one buffer, do I need to follow the same?
Thanks in advance.
  • I am using SDK11, Is "NRF_LOG_HEXDUMP_INFO" available in SDK11?
  • No, NRF_LOG_HEXDUMP_INFO is not available in SDK 11. Then you have to do it in a loop instead. For instance:
    for (int i = 0; i < sizeof(m_rx_buf); i++)
        NRF_LOG_PRINTF("%02x", m_rx_buf[i]);
  • For this:
    Output is : FFFFFFFF00000000000000000000"
    complete code:
    /* Copyright (c) 2015 Nordic Semiconductor. All Rights Reserved.
     * The information contained herein is property of Nordic Semiconductor ASA.
     * Terms and conditions of usage are described in detail in NORDIC
     * SEMICONDUCTOR STANDARD SOFTWARE LICENSE AGREEMENT.
     * Licensees are granted free, non-transferable use of the information. NO
     * WARRANTY of ANY KIND is provided. This heading must NOT be removed from
     * the file.
    #include "nrf_drv_spi.h"
    #include "nrf_gpio.h"
    #include "nrf_delay.h"
    #include "nrf_log.h"
    #include "boards.h"
    #include "app_error.h"
    #include <string.h>
    #if defined(BOARD_PCA10036) || defined(BOARD_PCA10040)
    #define SPI_CS_PIN   29 /**< SPI CS Pin.*/
    #elif defined(BOARD_PCA10028)
    #define SPI_CS_PIN   2  /**< SPI CS Pin.*/
    #define SPI_SCK_PIN 4
    #define SPI_MOSI_PIN 1
    #define SPI_MISO_PIN 3
    #else
    #error "Example is not supported on that board."
    #define SPI_INSTANCE  0 /**< SPI instance index. */
    static const nrf_drv_spi_t spi = NRF_DRV_SPI_INSTANCE(SPI_INSTANCE);  /**< SPI instance. */
    static volatile bool spi_xfer_done;  /**< Flag used to indicate that SPI instance completed the transfer. */
    long long MISO = 0x8000000008;
    #define TEST_STRING "0x8000000008"
    unsigned char val0, val1, val2, val3, val4;
    static uint8_t       m_tx_buf[] = {0x80};           /**< TX buffer. */
    static uint8_t       m_rx_buf[sizeof(TEST_STRING)+1];    /**< RX buffer. */
    static uint8_t m_length = sizeof(m_tx_buf);        /**< Transfer length. */
     * @brief SPI user event handler.
     * @param event
    void spi_event_handler(nrf_drv_spi_evt_t const * p_event)
        spi_xfer_done = true;
        //NRF_LOG_PRINTF(" Transfer completed.\r\n");
    	  //NRF_LOG_PRINTF(" address: %x %x %x %x\n", val3, val2, val1, val0);
        if (m_rx_buf[0] != 0)
    void sendDataToSPI(uint8_t address, unsigned long datagram)
    				APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &address, m_length, m_rx_buf, m_length));
    	      NRF_LOG_PRINTF(" address: %x\r\n",address);
    				val0 = (datagram & 0xFF);
    				datagram >>= 8;
    				val1 =  (datagram & 0xFF);
    				datagram >>= 8;
    				val2 = (datagram & 0xFF);
    				datagram >>= 8;
    				val3 =  (datagram & 0xFF);
    				APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &val3, m_length, m_rx_buf, m_length));
            NRF_LOG_PRINTF(" val3: %x\r\n",val3);
    				APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &val2, m_length, m_rx_buf, m_length));
            NRF_LOG_PRINTF(" val2: %x\r\n",val2);
    				APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &val1, m_length, m_rx_buf, m_length));
            NRF_LOG_PRINTF(" val1: %x\r\n",val1);
    				APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, &val0, m_length, m_rx_buf, m_length));
            NRF_LOG_PRINTF(" val0: %x\r\n",val0);
    void sendSPI(unsigned long datagram)
    	static int length= sizeof(datagram);
    	APP_ERROR_CHECK(nrf_drv_spi_transfer(&spi, (uint8_t *) &datagram, length, m_rx_buf, length));
        LEDS_CONFIGURE(BSP_LED_0_MASK);
        LEDS_OFF(BSP_LED_0_MASK);
        APP_ERROR_CHECK(NRF_LOG_INIT());
        NRF_LOG_PRINTF("SPI example\r\n");
        nrf_drv_spi_config_t spi_config = NRF_DRV_SPI_DEFAULT_CONFIG(SPI_INSTANCE);
        spi_config.ss_pin = SPI_CS_PIN;
    		spi_config.miso_pin=SPI_MISO_PIN;
    		spi_config.mosi_pin=SPI_MOSI_PIN;
    		spi_config.sck_pin=SPI_SCK_PIN;
    		spi_config.mode=NRF_DRV_SPI_MODE_3;
    		spi_config.bit_order = NRF_DRV_SPI_BIT_ORDER_MSB_FIRST;
        APP_ERROR_CHECK(nrf_drv_spi_init(&spi, &spi_config, spi_event_handler));
    				sendDataToSPI(0x80, 0x00000008);
    				sendDataToSPI(0xEC, 0x000100C5);
    				sendDataToSPI(0xB0, 0x00011F05);
    				sendDataToSPI(0xAC, 0x00002710);
    				sendDataToSPI(0x90, 0x000401C8);
    				sendDataToSPI(0xB2, 0x00061A80);
    				sendDataToSPI(0xB1, 0x00007530);
    				sendDataToSPI(0xA6, 0x00001388);
    				sendDataToSPI(0xA7, 0x00004E20);
    				sendDataToSPI(0xA0, 0x00000001);
    				sendDataToSPI(0x21, 0x00000000);
    				sendSPI(0x80000008);
    				sendSPI(0xEC0100C5);
    				sendSPI(0xB0011F05);
    				sendSPI(0xAC002710);
    				sendSPI(0x900401C8);
    				sendSPI(0xB2061A80);
    				sendSPI(0xB1007530);
    				sendSPI(0xA6001388);
    				sendSPI(0xA7004E20);
    				sendSPI(0xA0000001);
    				sendSPI(0x21000000);
        while(1)
    				unsigned long i_datagram;
            // Reset rx buffer and transfer done flag
            memset(m_rx_buf, 0, m_length);
            spi_xfer_done = false;
    				sendDataToSPI(0xA4, 0x000003E8);
    				sendDataToSPI(0xA5, 0x0000C350);
    				sendDataToSPI(0xA6, 0x000001F4);
    				sendDataToSPI(0xA7, 0x000304D0);
    				sendDataToSPI(0xA8, 0x000002BC);
    				sendDataToSPI(0xAA, 0x00000578);
    				sendDataToSPI(0xAB, 0x0000000A);
    				sendDataToSPI(0xA0, 0x00000000);
    				sendDataToSPI(0xAD, 0xFFFF3800);
    				sendSPI(0xA40003E8);
    				sendSPI(0xA500C350);
    				sendSPI(0xA60001F4);
    				sendSPI(0xA70304D0);
    				sendSPI(0xA80002BC);
    				sendSPI(0xAA000578);
    				sendSPI(0xAB00000A);
    				sendSPI(0xA0000000);
    				sendSPI(0xADFF3800);
            while (!spi_xfer_done)
                __WFE();
            LEDS_INVERT(BSP_LED_0_MASK);
            nrf_delay_ms(200);
  • Perfect. Then that is the content of the m_rx_buf at the point where you print it. (Note that you could always beautify it if you want by for instance splitting in bytes and prefixing each byte with 0x by changing the print statement to this: "NRF_LOG_PRINTF("0x%02x, ", m_rx_buf[i]);").
  • Thanks for the reply.
    However, its always printing “FFFFFFFF000000000000000000000000”
    i assume m_rx_buf should have printed the data which is written over SPI right?
    In code, i am trying to write:
    0x80000008
    0xEC0100C5
    and so on...
