NFC and LFCLK initialization
I'm experiencing a problem with the NFC.
I'm trying to make a simple read-only tag, and I've used the NFC Text Record Example to build upon. That worked without a problem.
However, when I integrated the NFC code in my project, I wasn't able to read out the tag any more, the reader said it was empty. However, I got no error code from the nfc library/code.
When I shuffled my code around, I found out that the problem has to do with the low frequency clock configuration I used:
void LFCLK_Config(void)
    ret_code_t err_code = nrf_drv_clock_init();
If I configure the LFCLK first, the program runs, but the NFC tag is empty. If i configure the NFC first, I'll get a NRF_ERROR_MODULE_ALREADY_INITIALIZED error from the nrf_drv_clock_init() call. Unfortunately, I need the LFCLK to drive my RTC.
I havn't found anything in the documentation that forbits the use of LFCLK when using NFC (using nRF52840, there shouldn't even be the timer 4 restriction).
Is there a way to solve this?
I'm using a nRF52840 and SDK version 15.
I've found the Patch for nrf_nfct_field_event_handler() function and applied it; it made no difference.
     Lasse
