Hi i used nRF52840 Preview-DK and i try many example with SDK provided.
the problem is the range of transmission too short . can you help how to set power transmission of this module ? for zigbee, BLE Mesh, Thread...
thanks
thanks
Tread and Zigbee SDK2.0:
In ble_gap.h,you can find the follow introduction:
/**@brief Set the radio's transmit power.
* @param[in] role The role to set the transmit power for, see @ref BLE_GAP_TX_POWER_ROLES for
* possible roles.
* @param[in] handle The handle parameter is interpreted depending on role:
* - If role is @ref BLE_GAP_TX_POWER_ROLE_CONN, this value is the specific connection handle.
* - If role is @ref BLE_GAP_TX_POWER_ROLE_ADV, the advertising set identified with the advertising handle,
* will use the specified transmit power, and include it in the advertising packet headers if
* @ref ble_gap_adv_properties_t::include_tx_power set.
* - For all other roles handle is ignored.
* @param[in] tx_power Radio transmit power in dBm (see note for accepted values).
* @note Supported tx_power values: -40dBm, -20dBm, -16dBm, -12dBm, -8dBm, -4dBm, 0dBm, +2dBm, +3dBm, +4dBm, +5dBm, +6dBm, +7dBm and +8dBm.
* @note The initiator will have the same transmit power as the scanner.
* @note When a connection is created it will inherit the transmit power from the initiator or
* advertiser leading to the connection.
* @retval ::NRF_SUCCESS Successfully changed the transmit power.
* @retval ::NRF_ERROR_INVALID_PARAM Invalid parameter(s) supplied.
* @retval ::BLE_ERROR_INVALID_ADV_HANDLE Advertising handle not found.
* @retval ::BLE_ERROR_INVALID_CONN_HANDLE Invalid connection handle supplied.
SVCALL(SD_BLE_GAP_TX_POWER_SET, uint32_t, sd_ble_gap_tx_power_set(uint8_t role, uint16_t handle, int8_t tx_power));
enum BLE_GAP_TX_POWER_ROLES
BLE_GAP_TX_POWER_ROLE_ADV = 1, /**< Advertiser role. */
BLE_GAP_TX_POWER_ROLE_SCAN_INIT = 2, /**< Scanner and initiator role. */
BLE_GAP_TX_POWER_ROLE_CONN = 3, /**< Connection role. */
There are three roles when you call "sd_ble_gap_tx_power_set".
So according to the role,call "sd_ble_gap_tx_power_set" after adv_init or scan_init .
And use "BLE_GAP_TX_POWER_ROLE_CONN " when connected.
Maybe like this:
void test_set_tx_power(void)
uint32_t err_code;
if(m_conn_handle != BLE_CONN_HANDLE_INVALID)
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_CONN ,m_conn_handle,8);
//BLE_GAP_TX_POWER_ROLE_ADV for peripheral advertising.
err_code = sd_ble_gap_tx_power_set(BLE_GAP_TX_POWER_ROLE_SCAN_INIT,0,8);
nrf_802154_tx_power_set(8);//
This is the way I am using for test . Hope it can help you.
i see commandsd_ble_gap_tx_power_set(); for BLE but i don't know where can i add this command
That's covered in the link I posted earlier!
thank you Longrain :)
Thank you awneil
