I am new to nrf52832. I am using pin change interrupt. I want to know that how to mask pin change interrupt?
Thanks in Advance
Thanks in Advance
nrf_drv_gpiote_in_event_disable which in turn calls nrfx_gpiote_in_event_disable seems to be disabling the interrupt in nrfx_gpiote.c (SDK15.2)
sorry for late reply. I am using sdk12.3.0 and pca10040 board. I have already tried with nrf_drv_gpiote_in_event_disable but interrupt is not disabled.
Hey,
Here is what the documentation of the in_event_enable function says.
/** * @brief Function for enabling sensing of a GPIOTE input pin. * * @details If the input pin is configured as high-accuracy pin, the function * enables an IN_EVENT. Otherwise, the function enables the GPIO sense mechanism. * Note that a PORT event is shared between multiple pins, therefore the * interrupt is always enabled. * * @param[in] pin Pin. * @param[in] int_enable True to enable the interrupt. Always valid for a high-accuracy pin. */
Note that a PORT event is shared between multiple pins, therefore the interrupt is always enabled.
Maybe you can try using uninit before going to sleep and init it back again when the device wakes up.
void nrf_drv_gpiote_in_uninit(nrf_drv_gpiote_pin_t pin);
thanks for quick response. i will check it using void nrf_drv_gpiote_in_uninit(nrf_drv_gpiote_pin_t pin)
