Nor memory QSPI efficient data logging
Dear Nordic,
For my application I am now using a NOR memory with my nRF52840.
This memory needs the FAT file system as my device implements USB MSC and uses regular files.
My app needs to log data every second (about 20 bytes per write), and this logged data can amount to several MB in total before it is unloaded.
I have noticed that using a file in append mode in the NOR memory takes (very) long processing times... and can also crash the system !
My question is the following:
How an I efficiently store this data in my NOR flash memory using the nrf_qspi library ?
  • Hmm the Page program time (256 bytes) is a maximum of 1800µs according to its datasheet.
    "The data that is saved is a copy of the data used by the program, which indeed is used in A LOT of floating point operations. But what would be the relation to the issue ?"
    -I'm just wondering if you're including the data processing in your flash write routine.
    Do you have a scope of the SPI lines?
