if yes how can i choose between S=2 and S=8, where the change should take place, at the advertising init ?
Hi.
I can't compile neither of these projects, and I don't see that you have called sd_ble_gap_adv_set_configure() in either one of them.
Andreas
thanks for your reply
in order to compile these projects you need to add them to the SDK 15.2 as the other examples.
the function : sd_ble_gap_adv_set_configure() is called by ble_advertising_init() that called by the advertising_init() in main.c
I appreciate your help
Best regards
Jawad
Hi.
I was able to compile the projects in SDK 15.0, and debug them. But I did not get any errors, here is my output:
Central:
<info> app: BLE UART central example started. <info> app: ADV. report <info> app: ADV. report <info> app: ADV. report <info> app: ADV. report <info> app: ADV. report <info> app: ADV. report <info> app: ADV. report <info> app: Connecting to target 914819FB65EE <info> app: Connected to target <info> app: RSSI : -35 dBm <info> app: ATT MTU exchange completed. <info> app: Ble NUS max data length set to 0xF4(244) <info> app: Discovery complete. <info> app: Connected to device with Nordic UART Service. <info> app: RSSI : -25 dBm <info> app: RSSI : -36 dBm <info> app: RSSI : -26 dBm <info> app: Disconnected. <info> app: ADV. report <info> app: ADV. report <info> app: Connecting to target 914819FB65EE <info> app: Connected to target <info> app: RSSI : -24 dBm <info> app: ATT MTU exchange completed. <info> app: Ble NUS max data length set to 0xF4(244) <info> app: Discovery complete. <info> app: Connected to device with Nordic UART Service.
Peripheral:
<info> app: Debug logging for UART over RTT started. <info> app: Connected <info> app: Data len is set to 0xF4(244) <info> app: Debug logging for UART over RTT started. <info> app: Connected <info> app: Data len is set to 0xF4(244)
Is the problem still NRF_ERROR_INVALID_PARAM? I'm a bit unsure what the problem is now.
Andreas
Hi , now there is no problem regards the range I get after testing Long Range
In long range I got 75 meter range between two ntf52840 ...
In normal with BLE_GAP_PHY_1MBPS I got the same range ( 75 meters )
Is there any problem with the code ?
Regards
Jawad K
Hi.
I don't think you have configured the PHY correctly then. Can you use a sniffer to sniff for BLE packets? They should be marked with CODED_PHY if they are CODED_PHY.
The worst case range you should expect in open air is atleast double distance from BLE_GAP_PHY_1MBPS
Andreas
