Reading WS2812b leftover data through I2S
Hello there,
I am currently trying to read the leftover WS2812b LED strip data which was sent using a single channel I2S. The data sent from the board (through I2S) looks like this:
with around 34 mV for high and around 2~6 mV on low. I decided not to send FFF, but 888 instead.
I am aiming to calculate the length of the LED strip. Each LED chip will read the first 24 bits of the data, cascade (discard) it, then pass it to the next one. Therefore, the strategy is to get the data after being cascaded by the last chip and calculate the length of it (which later will be divided by 24 to see how many are left).
The question is: How will I be able to read those data? I tried reading as usual (set a buffer for the i2s, start it, listen for it (delay), stop it, then check its buffer), but I got my buffer filled with all FFF instead. and a thing is that... when I tried to read anything from the pin, although I am not sending any data (the LED strip is not powered on, but connected to other's ground), there will be data, which should not happen. I assigned pin 22, 23, 24, 25 to be the i2s input pin (which will be assigned and unassigned when used or unused), and they are configured as follows:
nrf_gpio_cfg_sense_input(DIN1_PIN, NRF_GPIO_PIN_PULLDOWN, NRF_GPIO_PIN_SENSE_HIGH);
Thank you in advance.
    Winz said:
    hmm, I don't quite get it. (Is the variation expected?)
    There will be some variation between the input signal and output signal, as the input signal is not synchronized to the 16 MHz peripheral clock, but the output signal is.
    Winz said:
    Are you saying that I let GPIOTE to handle this accidentally? But I remember that GPIOTE is not fast enough to handle it. Therefore, I do not think it is GPIOTE.
    In my case, one pulse (one high and one low) 1.24 us (~ 1240 ns). Is that what you mean?
    I did not get this. I am sorry, but am still unable to get a proper understanding of the previous question, context and test setup. I suggest you create a new question starting with absolutely all the information you have in a single post, making it stand alone and not referring to this thread.
    Winz said:
    I also read another question that (I think) is achieving the similar thing. If I am asking PPI to transfer the data to a timer, will I need to make 2 timers that does:
    1. one records high (HT) and one waits for low (LT)
    2. once a transition to low is sensed, PPI calls LT. LT stops and captures HT's duration and save it
    3. once a transition to high is sensed, PPI calls HT. HT stops and captures LT's duration and save it
    Yes, your points about what you want to achieve are sensible. You need to calculate the pulse durations by hooking up the GPIOTE input to a timer so that you start the timer on one event and capture it on another (or capture bot start and stop in different CC registers, depending on what suits you best).
  • ahh.. let's leave the second question alone.
    Okay so what I'm achieving now is to capture all the pulse's timing. I am really curious about this: will I be able to capture all rising edge and falling edge using one PPI channel and set GPIOTE's task to sense toggle?
    And I would like to know how to store the data in. Will you be able to provide me some info on how to do that? I've searched anywhere but did not really see how to store the value when it detects transitions.
    I referred here, and the example code provided was able to capture the time. I adapted here, but I was able to capture (at most) the periods of 16 data, when I expect 24. I guess it's GPIOTE, not PPI.
    It should be possible. You could configure the GPIOTE channel to generate an event on toggling, and hook that up to a timer via a single PPI channel and use it to capture the counter value. Then you can use a short in the timer to reset the timer. You should also enable a interrupt whenever a new timer value is stored.
    The downside with this is that you have to process the interrupts rapidly, between every toggle. You could half this by for instance using two GPIOTEs, two PPI channels and hooking them to separate CC registers (on the same timer or on two different timers). Essentially this is like LEGO, so you can hook things up in different ways and still achieve the same basic end goal.
    The data sample (time) is stored in the CC register of the timer. You would typically configure the timer to generate an interrupt so that you can read the data sample form the CC register and clear the interrupt (being ready for the next sample).
    Yes, this demonstrates much of what we have discussed. You can use it as a reference. I did not understand what you mean by only being able to capture periods of 16 data, though. Can you elaborate?
