How store large amount data 73Kbytes into flash using FDS?
We are using nRF52840 with sdk 15.0 version & segger embedded studio. We are able to store some small amount of configuration data into flash using FDS. But now we want to store large data array near about 73Kbytes into flash. I am writing example code for storing this data and created one dummy array of size 73728 bytes. But I getting following ERROR:
FDS_ERR_RECORD_TOO_LARGE
I am confused for configuration of FDS for storing 73Kbytes
Here is bellow edited in sdk_config.h
FDS_VIRTUAL_PAGES 10
FDS_VIRTUAL_PAGE_SIZE 2048
FDS_OP_QUEUE_SIZE 4
Will you please help me how i use this above configuration for storing 73KB data. & how i fixed FDS_ERR_RECORD_TOO_LARGE ERROR?
Is it possible to store this data in one fds_record_write (...) call request?
Thanks in advanced..!!
  • What are the connection parameters in this case? FDS will try to schedule flash operations between BLE events, but it might be difficult if you have a short connection interval.
  • Hi Ashish & Einar,
    Yes i am using nrf_fstorage_sd.c lib
    Sorry for this wrong library said, actually this lib included in my project not used for write data into flash. But for writing data into flash i am using fds.c & fds.h library.
    Here is below screen shot of  our set connection parameter:
    #define NUS_SERVICE_UUID_TYPE BLE_UUID_TYPE_VENDOR_BEGIN /**< UUID type for the Nordic UART Service (vendor specific). */
    #define APP_BLE_OBSERVER_PRIO 3 /**< Application's BLE observer priority. You shouldn't need to modify this value. */
    #define APP_ADV_INTERVAL 64     /**< The advertising interval (in units of 0.625 ms. This value corresponds to 40 ms). */
    #define APP_ADV_DURATION 0   /* Set 0 for contineous advertisng time & handle their timeout by sperate app timer.*/
    #define MIN_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS)   //20           /**< Minimum acceptable connection interval (20 ms), Connection interval uses 1.25 ms units. */
    #define MAX_CONN_INTERVAL MSEC_TO_UNITS(7.5, UNIT_1_25_MS)   //75           /**< Maximum acceptable connection interval (75 ms), Connection interval uses 1.25 ms units. */
    #define SLAVE_LATENCY 0                                      /**< Slave latency. */
    #define CONN_SUP_TIMEOUT MSEC_TO_UNITS(4000, UNIT_10_MS)     /**< Connection supervisory timeout (4 seconds), Supervision Timeout uses 10 ms units. */
    #define FIRST_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(5000) /**< Time from initiating event (connect or start of notification) to first time sd_ble_gap_conn_param_update is called (5 seconds). */
    #define NEXT_CONN_PARAMS_UPDATE_DELAY APP_TIMER_TICKS(90000) /**< Time between each call to sd_ble_gap_conn_param_update after the first call (30 seconds). */
    #define MAX_CONN_PARAMS_UPDATE_COUNT 3                       /**< Number of attempts before giving up the connection parameter negotiation. */
    #define DEAD_BEEF 0xDEADBEEF      /**< Value used as error code on stack dump, can be used to identify stack location on stack unwind. */
    #define BOOTLOADER_DFU_START 0xB1 // Bootloader DFU
    #define UART_TX_BUF_SIZE 2048 /**< UART TX buffer size. */
    #define UART_RX_BUF_SIZE 2048 /**< UART RX buffer size. */
    Thanks..
  • Hi ,
    I am sorry for the late reply. Somehow I forgot about this thread.
    I see you configure 7.5 ms connection interval. I assume you are making a peripheral, so weather this is used or not I don't know. the same for slave latency and supervision timeout. Can you check what is actually used on the link when you test? After all the peripheral can only request it, the central decides. If it is as low as 7.5 ms and the supervision timeout is short (not 4 seconds as shown here, then it might not be possible for the SoftDevice to schedule a flash operation.
    Reading over the tread again the connection interval question might be irrelevant, as you do not even enable the SoftDevice in the code you posted earlier. At the same time there is talk about NUS etc. In fact, I am not able to understand the context here. Can you write current question in a new post and include all relevant information there so that we know in detail how your application looks like, what it is supposed to do and how it does not work. Please add all relevant code. Please make that post stand-alone so that it contains all relevant information.
  • Thanks Einar for your suggestion..!!
    I will create another thread for this problem.. But now i have question regarding flash data storage Is it necessary to define fds write data buffer as static. Because my data length wan to write is 74000 If i define as static then RAM used more. In ca if not define this buffer as static then some last data is not write correctly.
    Will you suggest other way instead of using static buffer.
    Thanks....
